Caring for a road bike soaked from rain
Old 03-08-15, 10:51 AM
Fatty McFatcakes
velociraptor's Avatar
Bikes: Aero Cheeseburger w/ Sr(h)am eBacon
Quoted: 245 Post(s)
Liked 2 Times in 1 Post
Originally Posted by Pirkaus
FIFY, because things need to be in order
Thank you for that – I feel like a tremendous weight has been lifted.
velociraptor is offline
Old 03-08-15, 10:52 AM
cale's Avatar
Bikes: Kuota Ksano. Litespeed T5 gravel - brilliant!
Liked 4 Times in 4 Posts
Originally Posted by Jiggle
It is tragic how intentionally ignorant you are. I named the exact spot that I apply the product and the exact need. It fits that need perfectly.
Also what @gregf83 said. WD-40 is an excellent product.
Look, I said I was writing to be nice. Now you bring up the "ignorant" nonsense. I don't like your manner and will let you stew in WD 40 rather than encourage your blather.
cale is offline
Old 03-08-15, 10:55 AM
cale's Avatar
Originally Posted by basqueonacaad
The Nazis are coming to this party.
Spelling nazi.
cale is offline
Old 03-08-15, 11:48 AM
Jiggle's Avatar
Bikes: BH, Cervelo, Cube, Canyon
Quoted: 212 Post(s)
Liked 6 Times in 6 Posts
Tragic, but not unentertaining.
Jiggle is offline
Old 03-08-15, 01:06 PM
Stand and Deliver
FLvector's Avatar
Bikes: Cannondale R1000, Giant TCR Advanced, Giant TCR Advanced SL
If your chain is wet, why not dry it off with a shop rag? Using a chemical to remove water from a wet chain sounds like EXACTLY the sort of use that the makers of WD 40 would hope you would do. It is like using oil to push water out of a bath tub. It's just not necessary to discharge that many pollutants into the atmosphere. We're supposed to protect the earth, not use it for our own purposes. If you get my meaning, and I mean it in the sincerest non-argumentative way possible.
Riding in wet conditions will reduce the life of the chain and drivetrain since many people don't bother doing the maintenance that has been suggested. Even after you go the extra step and brush with soapy water, then followed by a rinse, you can't get inside the roller and pin on the chain to flush out the embedded grit and grime. If you wipe the chain perfectly clean, then spray it with a liberal amount of WD-40, GT-85, Boeshield T-9 or your favorite chain lube, you'll notice the dirt oozing out between the links. The additional cleaning is necessary to remove the grit or it will eat into the internal part. Rather than use a liberal amount of chain lube, there's nothing wrong with using something like WD-40, then following with the lube.
I don't know what your issue is with WD-40, but your preaching about saving the planet isn't what people want to hear. The conservative amount being used is miniscule.
FLvector is offline
Old 03-08-15, 01:24 PM
Quoted: 5999 Post(s)
Liked 2,940 Times in 1,629 Posts
As I said earlier, I consider weather proofing (resisting) in advance preferable to dealing with water later. My commuter bike is set up for all weather riding, partly through selection of components and greases and oils known to handle rain well. Dirt and grit can be a problem, so I either rinse (rinse, not wash) with fresh water from a hose, or leave the bike outside in the rain, on the theory that if God got it dirty, he can clean it again.
BTW- one major factor in how the bike handles rain is front wheel spray. Fenders, or a tire that sprays wider is important so you don't direct a jet of water at the bottom bracket or chainrings.
One trick for making a DIY all weather BB is to cut donuts from sheets of urathane foam, cover in grease, and trap between the crank arms and BB cup face.
FB
Chain-L site
FBinNY is offline
Old 03-08-15, 01:35 PM
Bikes: Cannondale six-13
Quoted: 144 Post(s)
Liked 108 Times in 24 Posts
Well, bikes are well sealed and made to be used outside. They perform better if they are clean so cleaning them is a good idea. A better idea is to cheaply invest in a beater bike that is used specifically for "weather " rides. After the initial investment it pays for itself easily in time and money. I am reasonably certain that the workout you can get from a beater bike is at least 99 percent as good as what you will get from your top bike. It's noisier and a little less comfortable but it gets the job done and the cleaning done to keep it going is much less arduous and requires way less attention. Been doing this for a long time now. It works quite well.
Ray9 is offline
Old 03-08-15, 02:00 PM
cale's Avatar
I used to think like this but then I realized that if I going to be in the humanity-existence business, I might as well follow my own path. It's not a lonely path.
cale is offline
Old 03-08-15, 02:01 PM
cale's Avatar
Ain't it?
Funny, I mean.
cale is offline
Old 03-08-15, 02:13 PM
Trakhak's Avatar
Quoted: 2664 Post(s)
Liked 3,230 Times in 1,845 Posts
On behalf of the next owner(s) , grease the seatpost and stem (probably more important for quill stems than threadless stems). You'll be doing your part to conserve BF bandwidth in the future.
Trakhak is offline
Old 03-08-15, 02:17 PM
cale's Avatar
Originally Posted by Trakhak
Grease the seatpost and stem (probably more important for quill stems than threadless stems). Be kind to the future owner and thus save future BF bandwidth.
Isn't bandwidth perishable? I say use it while we've got it.
cale is offline
Old 03-08-15, 02:34 PM
Quoted: 3405 Post(s)
Liked 240 Times in 185 Posts
Sure the bike can withstand the rain, but its not just the rain, its all the road salts and corrosive chemical that get mixed with it. And lets not ignore the fact that the bike is painted.
After a heavy rain, wash the bike; and use lube as needed. Some foul weather brands can last through several rain storms or even a season. But I found WD 40 can come in handy as a quick fix, until you get around to the more long-lasting fix.
When are we ever sure the weather will turn foul? Maybe 50% of the time. But yeah, if its already turning nasty out, the beater is a better alternative.
KraneXL is offline
jskash
Bicycle Mechanics
33
09-03-18 02:06 AM
Bikerdave222
Commuting
10
11-19-14 11:32 AM
daddyto3
Road Cycling
9
08-20-10 12:51 AM
ziggydcat
Bicycle Mechanics
8
07-11-10 03:42 PM
bergjm
Commuting
7
04-09-10 05:26 PM
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
