Waxing chain, benzene a cancer risk?
Once you get set up on a chain wax system where you rotate 2 or 3 chains, then waxing or changing chains after every ride would not be that time consuming. So long as you use quick links, changing out a chain takes about the same amount of time as putting air in your tires before a ride.
Quoted: 7740 Post(s)
Liked 3,685 Times
Oi.
There are so many things which could cause our inevitable deaths, and people are worrying about chain wax? Have you ever been in a rook=m with a candle burning? Ever eaten cooked meat? You have a lot more chance of dying from injuries while crashing on a bike than from chain wax. And a vastly greater chance of dying from a slip and fall in the bathroom --- so do you not shower, and relieve yourself in a hole outside? Oh, No! the risk of dysentery!
Use a liquid wax, wear a ventilator, or best of all --- stop riding, It is just too dangerous.
And by the last post you are saying waxing takes too long---which is certainly a s serious an objection and "Waxing is fatal." "Waxing is deadly---and it takes too long."
I am taking you seriously, believe me.
Oi.
Quoted: 20810 Post(s)
Liked 9,456 Times
I just read that heating paraffin creates benzene. What do you all think? Here's where I read it. Search on benzene.
https://zerofrictioncycling.com.au/w...-FAQ-v1.3a.pdf
Likes For WhyFi:
What exactly does "fuming" mean? At some point in the heating process, the wax does begin to give off an door. Is that fuming? Actually, the writer talks about heating the wax too quickly, not to too high a temp. That's how I read it at least.
Bikes: Yes
Quoted: 1883 Post(s)
Liked 1,549 Times
I have the Connex link, so it's quite quick to pop off the chain. I've waxed my chain with plain old Gulf paraffin about 4 times before and after gravel rides so far. It's not just the waxing that takes time. After the wax dries hard, breaking free 118 links takes a while, and then I have to run each link over my single chain ring at least once. I was getting pretty good at it. After each ride, the chain looks clean, but apparently appearances deceive. I melted my wax today and dumped it, and there was a good amount of black debris in the bottom of the crock pot. I was going to try the Silca wax. Not sure what I'll do now.
Paraffin wax: Just heat it up slowly until it melts enough to be as 'workable' as you need it, and do it in a ventilated area. Frankly, I'd be more worried about the fumes from the heating device your using to melt the wax (natural gas, propane, maybe 'white' gas in a camping stove?)
Likes For skidder:
Liked 3,685 Times
I have waxed a lot of chains, and heated a lot of wax, and at no time did the wax give off a door.
You are just playing here. if you really cared you would have googled the actual facts about paraffin, instead of asking here on BF. But only here on BF can you get so much attention. Doping actual research is dry and dull. Of course, that is what you have to do if you want to learn.
Since you are not doing that, you don't want to learn. Therefore it seems what you want is attention from BF.
Good strategy, i guess.
But yeah ... how's it living under that bridge?
Likes For Maelochs:
And you accuse me of incoherence?
Liked 9,456 Times
Don’t get your wax way too hot – ie slow cooker on low, lid off, or instant pot set to 90dg c, and again things are no more dangerous than boiling your kettle.
No the scent is not toxic. Candles have a scent too, and the scent is not toxic, but the candles will be releasing a tiny amount of benzene gas, your not burning wax will not be. As long as it is not too hot so that it is fuming, it is just basically a lubrication candle – without the burning.
Likes For WhyFi:
Quoted: 18596 Post(s)
Liked 16,096 Times
Like I posted before, just use NFS if you’re so concerned that you needed to start a thread after all you (assumed) research. It’s the best lube in the galaxy. No lie.
Quoted: 810 Post(s)
Liked 1,887 Times
remember when it was all the rage that eggs were bad for you , and then they weren't.....LOL.... yea me too
Mad bike riding scientist
Quoted: 6296 Post(s)
Liked 4,332 Times
Smoke is a fine solid formed by incomplete burning. Fumes are fine airborne particles produced when a solid vapourises and condenses, eg during welding
Lots of people use a Crock Pot for heating the oil which isn’t a bad idea since you can’t get up to the point where you can burn the wax. If you don’t have a Crock Pot, at least use a double boiler. The condensing steam will provide enough heat to melt the wax without overheating it. Do not put a pan on direct heat to melt the wax. That’s will allow for overheating. Crock Pots and double boilers are easy to find at thrift stores.
Stuart Black
Stuart Black
Quoted: 4083 Post(s)
Liked 7,671 Times
Likes For tomato coupe:
Liked 9,456 Times
Likes For WhyFi:
Liked 3,174 Times
Likes For Troul:
Quoted: 980 Post(s)
Liked 779 Times
How shocking that a paranoia thread about the potentially deadly effects of waxing a bike chain devolved so quickly.
And who knew that the folks at a for-profit Australian chain testing website were such experts in carcinogens…
![Thumbs Up](https://www.bikeforums.net/images/smilies/thumb.gif)
Likes For downhillmaster:
Liked 16,096 Times
Liked 3,685 Times
The guy is equally concerned about nonexistent toxic fumes and taking too long for bike maintenance. Let's let Darwin decide this thread.
Likes For Maelochs:
Not all. Some (most?) are emulsions. That is wax in water. Emulsion waxes are readily available on amazon if anyone cares to experiment.
Thanks cyccommute...Your posts always stand out in these threads....informative, expert advice. You obviously know what you're talking about....as opposed to a few here who have no clue! Thanks for stopping by.
Not “fuming”. Smoking. Fuming is different. This description is a good explanation although I would say that “fumes” are more something that is caused by reaction with air like you find with nitric acid or a pyrophoric compound.
Things start to get funny when material starts to burn. You can have incomplete combustion which causes the formation of different compounds. Just heating the wax to the melt point is enough to get very small amounts of the wax to volatilize (evaporate) but that’s not hazardous.
Likes For Bald Paul:
Quoted: 1814 Post(s)
Liked 923 Times
PTFE is a problem because it basically never breaks down, and is accumulating in the environment, including in your body.
Using your bike to spread large amounts of it is irresponsible.
https://greensciencepolicy.org/harmful-chemicals/pfas/
I would also argue that scent added to candles is toxic.
https://greensciencepolicy.org/harmf...ls-phthalates/
"...The words “fragrance,” “perfume,” or “parfum” often mean phthalates are present."
![](https://cimg6.ibsrv.net/gimg/bikeforums.net-vbulletin/756x1024/pfas_infographic_b0dffb79afc3a870e9f50aa90b64f12f9ca77266.jpg)
Likes For Bholz:
Liked 3,174 Times
my DS leg might be all that my chain will ever need for lubrication as PTFE might be readily available from the pores. Payback time to the chain after all these years of smearing it's alpha grease on my limb!
-YMMV
-YMMV
Likes For Troul:
