Stairs.
Sophomore Member
Quoted: 1628 Post(s)
Liked 1,059 Times
How do people that are out of shape handle that? I would have enough trouble, and I would hope with all the hill climbing I do I would at least be in as good of shape as the average German. And hauling your groceries up there every week too, along with your drinking water? I could probably handle it with great difficulty for a short period, maybe.
People here will circle a parking lot for 10 minutes, to find a spot that's a few feet closer to the door.
Old fart
Quoted: 3617 Post(s)
Liked 3,454 Times
That's what I do for some bikes. Doesn't work so well if the bike has full mudguards, though.
That can also work.
on the way down you can roll it backwards ... assuming over the shoulder doesn't work for you.
Quoted: 7 Post(s)
I grab the top tube where it meets the seat tube and lift the bike and it naturally tips forward when going down. Other hand is on the handrail.
Up is one hand on the bars, the other in the same spot as down. If the stair trim stands proud of the wall I rest the front wheel on it and push it up. If not I just carry it.
Whatever you do be careful not to leave tire marks on the walls of the stairhall. Everyone will know who did it. If it does happen clean it up yourself before the janitor or landlord does.
Much of my life was spent living in 3rd floor apartments. Being a dedicated cyclist I always thought it had no effect on me. Now that we have a first floor with use of basement the bikes are used more than ever.
Bikes: Wahoo of Theseus, others
Quoted: 428 Post(s)
Liked 67 Times
Quoted: 1467 Post(s)
Liked 1,495 Times
What about a solution to park the bike outside so you don't have to carry it up/down (except for occasionally)?
Would your building allow something like this outside?
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,099 Times
That doesn't work at my house because the ceiling on the entrance stair case is oddly low. so I have to carry it lower on my body. Basically, figuring out where the center of gravity is and holding it with one hand there works pretty well.
Quoted: 1324 Post(s)
Liked 927 Times
I live on the second floor of an apartment building with one elevator which is often out of service*.
When going down the stairs I hold the handlebar of the bike and squeeze the rear brake lever to stop the bike from gaining to much speed.
When going up the stairs, I'll sometimes get the two wheels on the side section that supports the stairs and push the bike up that whilst holding the front brake lever so I can stop and rest a bit if needed. That's my dropbar MTB with front and rear racks and panniers. My road bike is a lot lighter and I just carry it up or down the stairs. I'm 68 years young.
Cheers
Cheers
In Real Life
Bikes: Lots
Quoted: 3203 Post(s)
Liked 599 Times
Roll it down.
Rowan
My fave photo threads on BF
Machka's Website
Photo Gallery
Rowan
Machka's Website
Photo Gallery
Likes For Machka:
Quoted: 1085 Post(s)
Liked 1,348 Times
Things generally are not that hard when you do them all the time. Also, relating to drinking water, why does anyone need to purchase and transport drinking water? I can never understand why so many people will only consume water purchased in a bottle. Most tap water is fine to drink, and if you want or need to purify, one of the many available filter options available seems like a much better solution.
Grocery stores had water dispensers, and that is where most people got their water. The apartment complex also had a water dispenser. So yes, most tap water is good to drink, but there are exceptions.
As for stairs. I would not want to carry my bikes up my stairs, since they have a turn which makes it difficult to get my bike around without hitting the wall. Thankfully, I have a garage.
Bikes: Devinci Millenium, Gary Fisher Joshua
Quoted: 73 Post(s)
Liked 29 Times
Make a simple lift like they use to lift furniture into apartments. Basically a rope out the window with a triangular three pole that extends the roipe away from the outside wall, with a pulley on the end.
The triangular three legged pulley holder could be put out of a large window or patio.
Not great photos but:
https://www.pinterest.ru/smokefree13/pully-system/
I have seen a similar thing used at a university where you put a coin in a lock and this releases the front wheel holder which you attach to the bike wheels to pull the bike up the wall for locking it to the wall. Sort of like a lock box. You bring it back down by putting the key in the lock to release the wheel to be lowered down. Hard to explain but easy to figure out when you see it.
This is a very complex version https://www.wired.com/2011/04/bike-h...-of-buildings/
Quoted: 73 Post(s)
Liked 29 Times
I found a picture with plans on how to make. Very inexpensive and easy
https://makezine.com/projects/swiveling-balcony-hoist/
Quoted: 4882 Post(s)
Liked 4,049 Times
The other issue can be shoes. I lived in a 2nd floor apartment when I raced. Going down with the bikein my plastic soled race shoes was a challenge. (And I was a young and indestructible 24 yo.)
Give real thought to the shoes you will be riding in, especially if you go clipless. (Systems that use the 2-bolt SDP pattern fit MTB shoes, many of which have excellent walkable soles. 3-bolt road racing cleats and shoes are a much bigger challenge. I like and use two different 3-bolt cleats. On one pair, I had a local cobbler glue on sole around the cleats. Huge help. (Not easy for him. Told me he'd never do it again for the $50 he quoted me. But his work was very good and has given me zero problems over years.)
Ben
Ben
Young man:
Up-Grab the seatpost as close to the BB as you can with one hand, other hand on the bars. Walk up stairs.
Down-Pull up on the bars so the bike balances on the rear wheel. Hold the rear brake and walk the bike down the stairs slowing down with the rear brake.
Il faut de l'audace, encore de l'audace, toujours de l'audace
1980 3Rensho-- 1975 Raleigh Sprite 3spd
1990s Raleigh M20 MTB--2007 Windsor Hour (track)
1988 Ducati 750 F1
1988 Ducati 750 F1
Quoted: 5234 Post(s)
Liked 3,609 Times
Bikes: 1999 Giant ATX MTB, 2002 Lemond Zurich, 2018 Fuji Transonic 2.3, 2019 Specialized Tarmac Disc Expert
Quoted: 175 Post(s)
Liked 402 Times
Just hoist that bike up on one arm and take the bike up and down the stairs. Use your free hand to guide the front wheel around corners if you need to. Consider it cross training. Pretty soon you'll be so adept at it you won't think twice about it.
I think I know nothing.
Quoted: 233 Post(s)
Liked 290 Times
Happy Birthday Mesher!
Something like this might help: Google "Steerstopper"
Bikes: 2018 Roubaix Expert Di2, 2016 Diverge Expert X1
Quoted: 482 Post(s)
Liked 151 Times
if you have a hand rail, use the hand opposite the rail to carry it this way and use the other hand to hold the rail.
Bikes: Current: 2016 Bianchi Volpe; 1973 Peugeot UO-8. Past: 1974 Fuji S-10-S with custom black Imron paint by Stinsman Racing of PA.
Quoted: 215 Post(s)
Liked 204 Times
I am 67 and walk the bike up the stairs holding the handlebars. I do up one or two steps at a time and then apply the F&R brakes, then go up the two steps while still keeping it locked, and walk it up two more, do it again. When I get to the landing, I lock the rear wheel and pivot the bike vertically and turn to the next set of steps and go again.
Our basement steps have 8 steps, a landing the 8 more steps in a zig-zag. I have used this technique since college and city apartment days.
Advantages, no marked walls, no marked floors, no falling, and bike can be lightly loaded.
To go down, I lock the rear wheel, pull it upright, and walk it down on the rear wheel using the rear brake.
During the biking season, the bikes stay in the spare bedroom, unless guests come.
I can't believe no one else has told you this tip. Always carry the bike in your right hand so the chain is away from your cloths. (Assuming it is facing forward.) It is a waste to put chain lube on cloths.
Last edited by RidesaCarlton; 05-14-20 at 06:50 PM. Reason: I just thoughgt of an amusing comment to add.
