Electronic Dura Ace Di2 not worth?
Bikes: 99 Klein Quantum, 2012 Cannondale CAAD10 5, Specialized Tarmac Comp, Foundry Thresher, Fuji Sportif
Quoted: 98 Post(s)
I decided to go mech as well after test riding the Di2. Don't get me wrong there was NOTHING wrong with the Di2. It just didn't "feel" right to my hands/brain. Too old school I guess. I do think you could get use to it pretty quickly though, and if you only have one bike it should not be an issue. Don't know that I would want to switch back and forth, but then I don't like switching from one groupo to another anyway. You get use to the good stuff and dropping down can be frustrating.
Bikes: Cannondale Slate and the rest don't matter anymore.
Quoted: 11 Post(s)
No it doesn't. At least to me. What road feel do you get from non electronic? It's not like a car where shifting is turned over to an automatic. The rider controls the shifts. In the case of manual you push a lever for one direction and hit a button release for the other. With electronic you push a bottom for both. The rider does it all. So where's the connection and feel difference?
I'm not against Di2 BTW, for racers especially, it's superior technology. I just get more tactile satisfaction shifting gears myself rather than what amounts to clicking a mouse button.
I'm in the process of going a step further by setting up a bike with bar end friction shifters. Maybe I'm getting a little too Grant Petersony for the the 41.
EDIT: Sorry, I just echoed WalksOn2Wheels
Quoted: 22 Post(s)
I get no satisfaction from shifting gears whether I use the Di2 Ultegra on my current bike of the mechanical Ultegra on my previous bike. I'm just shifting gears. If the gear changes appropriately, quickly & under whatever condition I subject it to, then it's a win. There is no feeling of satisfaction for me depending on the "click" or "cable weight" of the shift. Shifting is just something that I'm required to do sometimes to maintain my desired cadence & power under the changing conditions of the road. My Di2 works effortlessly & requires minimal maintenance. It allows me to make errors in judgment regarding when I should be shifting & shifts regardless.
For the OP, it makes a lot of sense to me to have at least tried Di2 prior to plunking down any money for DA Di2. How hard could that have been? Your previous experiences with Trek frames is irrelevant to your choice of a new tech drivetrain.
Old Fart
Bikes: '97 Klein Quantum '16 Gravity Knockout
Quoted: 163 Post(s)
Some of us prefer downtube shifters. Simple as dirt (and cheaper!); You get ALL of the feedback; You can skip as many cogs as you choose to, instantaneously; and, unlimited trim positions. All at the flick of a lever (And only ONE flick...). Using switches and servo motors and computers and batteries and wires to accomplish the same thing, is ridiculous. It's a case of technology being used for the "wow factor", and of needlessly complicating a very simple function. I wouldn't have Di2 if it were free!
Why have a human-powered vehicle...and then have to use a MOTOR just to nudge your chain over an eighth of an inch?
Bikes: Gilmour road, Curtlo road; both steel (of course)
Quoted: 273 Post(s)
Liked 10 Times
Specifically, there is a much more tactile response with mechanical vs. Di2. This is the reason Campy put a bit of a "click" in their EPS group. But it's still electronic. The difference between EPS and Di2 is a bit like a full on mouse click, vs. a tap on a touchpad. Both have the same result, but the tactile response is very different. This is why lots of phones have that slight buzz when you type onto the screen. It gives the user a sense of feedback.
Now compare both to mechanical and it's very different, yet again. Especially for something like Di2 vs. any 9000, 6800, or 5800 group. You're actuating a cable, and need to move the shifter X amount to accomplish anything. As stated earlier, the brake lever doesn't even move on Di2. And the push button have little to no travel when compared to the shifter throw required to pull a cable.
Taking it back to cars, it's not really manual vs. automatic, but closer to something like a stickshift vs. a paddle shifter on the steering wheel. Both have the same effect and require user input, but they are very different experiences.
I think I'm sort of talking around what you already acknowledge as fact, that the input is different but the end result is the same. But for lots of people, removing the mechanical push-pull system does reduce feel and changes the experience. Just go over to C&V and tell those guys they're idiots for complaining about indexed shifting vs. friction. Both have the same end result, so what's the big deal, right?
Today, I believe my jurisdiction ends here...
Vain, But Lacking Talent
Old Fart
Quoted: 163 Post(s)
Is your purpose in life just to complain about me expressing my dislike for electronic shifting?
Yes; when technology is used gratuitously- just for technology's sake; when it degrades something, rather than improving it; and when it needlessly complicates something which can be done better and more efficiently with very simple technology.
Bikes: 199? Landshark Roadshark, 198? Mondonico Diamond, 1987 Panasonic DX-5000, 1987 Bianchi Limited, Univega... Chrome..., 1989 Schwinn Woodlands, Motobecane USA Record, Raleigh Tokul 2
Quoted: 1131 Post(s)
You can shift while sprinting and putting down lots o' power.
You can shift while going up a hill and putting down lots o' power.
You don't have to do any maintenance on cables/housings and your cable pull will never make your rear derailleur hesitate.
You can be then envy of everybody in your Monday night club ride given that you can ride that bike like it should be ridden.
As for maintenance? Well, properly maintained = 10 seconds every thousand miles or so? Every once in awhile I have to move the barrel adjuster a bit, which I generally do while sitting at a stoplight. Once every few years I have to replace the housing and cable. I think that amount of time is still shorter than taking the time to charge the batteries (once a week like shimano suggests.)
My biggest thing is this. Electronics have a lifetime. They do. Especially electronics made to go outside. Heat cycling causes boards and solder to heat and cool, causing loose solder joints over time. Sure, you could make similar aging arguments for old derailleurs, but let's put it this way. Yesterday someone donated a 1940s schwinn that sat in a garage for a long time. I put air in the tires and rode it. The shifters still worked. Not well mind you, but they worked. Could you say the same for Di2? Do you think you'd still have the charger after 80 years? No. It's because Di2 isn't made for bikes that'll be around forever. It's made for racers who replace their bikes often.
I have nothing against Di2, I'm just poor and will never use it. I don't need the latest technology to go fast and enjoy my rides. I really don't something so critical on my bike controlled by a battery. I use batteries for my lights, they're a pain as it is. (Will be upgrading to a dynamo soon though!) I'd like my shifting to remain completely mechanical thank you very much.
Besides, I'm poor.
I'm confused. How does the electronic shifting change the fact that when you're putting down a ton of power, the derailleur isn't going to be able to move the chain very easily? Are you saying that it's just easier to hit the button? Or are you actually saying that the derailleur works better in those situations?
Besides, I'm poor.
Besides, I'm poor.
So there is an advantage depending on the rider. I suck anyway, so shifting that much better won't matter.
When you're using mechanical, the linear (linear meaning left-right in the direction of derailleur travel) force you can put down via a small cable is smaller than the linear force of a powerful servo. Under load, a servo doesn't care and moves exactly X millimeters regardless of how much power you're putting through the drivetrain.
Old Fart
Quoted: 163 Post(s)
I'm just pointing out the fact that when you had the Venge, all you did was whine about the Venge and all carbon fiber. That's a very common theme for you. And now you're talking about how awesome downtube shifters are compared to everything else. I just thought I'd do you the favor of letting you know that this is "road cycling" subforum and that a "classic & vintage" subforum exists for those individuals who are not into the current road scene. They're lovely people over there.
And i didn't whine about the Venge- it was a nice enough bike- it just wasn't any better than my old Klein- nor as durable. At least I gave it a try, right? Actually, it made me feel a little more confident about CF; it's just not for me.
I'm doing it wrong.
Bikes: Rivendell Appaloosa, Rivendell Frank Jones Sr., Trek Fuel EX9, Kona Jake the Snake CR, Niner Sir9
Quoted: 9742 Post(s)
Liked 2,812 Times
Now, don't get me wrong...I personally prefer the mechanical. I can work on them myself and I know what is going wrong when an issue comes up. I'm terrible with cleaning my bike though, and I fear that causes my cables to need replacing more often than others. This kind of thing doesn't bother me though...certainly not enough to go electronic. I do see the appeal for others though.
I don't think that's right. When I'm downshifting under load (up a hill) the derailleur still moves exactly where it is supposed to be (indexed shifting makes sure of that), it's just that since you're putting a lot of power through the chain, it can't make space between itself and the cog it's on to shift. No amount of "powerful movement" will fix that. Unless the derailleur detects that you're shifting under load and overshifts by a wider margin (something that most people familiar with bikes would do instinctively under the conditions.) Yes, rear derailleurs SHOULD be able to shift under load since they deal with the slack part of the chain, under real world conditions that's not always true.
Just go to your local shop and test ride a Di2 bike for kicks. Take it to a small hill, put it in a stupid high gear and slam it through some gears while you mash the pedals. You'll see what I'm talking about.
I do post occasionally in C&V- it is "my bag"-I just seem to find more entertainment here on the 41- and I like to keep abreast of the new stuff (Although, considering the direction in which the new stuff seems to be going, I'm not finding it very interesting anymore...)
Meh. I've ridden Di2 a bunch of times and was singularly unimpressed. Not because of something amiss in function, but rather I actually *enjoy* the feel of shifting a mechanical drivetrain. Just as I enjoy driving my manual transmission car more than my girlfriend's automatic. It's beyond just tactile. It's something, for me, wholly elemental. A connection to the bike, and to this activity we love.
In addition, I didn't like the feel of the little binky button, or its shape and placement. Also: with mechanical, you can feel the shift, or mis-shift, before you can hear the result of the shift through chain noise. Not the case with the Di2. You'd only know it mis-shifted after the fact.
NB: I'm no luddite. I love the disk brakes on my Domane, and would now never buy a bike without them. And I knew that from the first time I squeezed the brake lever on a disk-equipped bike.
A treat for the freaks!
All I'm gonna say is that certain groups just belong on certain bikes. And to me, at least the Madone 9.x and Di2 seem to go together. Just like a shiny silver Athena group just belongs on an lugged-steel Italian bike.
I would think that the same personality who walks into a bike shop and walks out with the latest Madone is the also the same kind who would want an electronic group. Didn't someone call it a bike designed by Apple for Batman?
I got my first Di2 bike this spring when I built up a custom framed bike. I went with Di2 just because it's a much cleaner look on the frame and bars if done right. At first I thought it wasn't that big of a deal. Then when I consider I haven't made a bad shift since I got it. Plus, I can simultaneously shift both the front and rear derailleurs. Now, I really really like it much more over my mech bikes. Would be really no fun going back.
J.
Expired Member
Quoted: 3784 Post(s)
Liked 5,773 Times
