putting longer cages on short cage nuovo and super record rear derailleurs...
What??? Only 2 wheels?
Liked 658 Times
AH, photogravity, I was meaning FreeWheel, not FW IGH. ![Smilie](https://www.bikeforums.net/images/smilies/smile.gif)
Our tandem has a Suntour F(ree)W(heel) stamped Tandem which I assume implies larger pawls.
The rattle on the Masi has me puzzled a bit. There is nothing loose (nothing too loose and nothing to lose
). When I bounce the rear tire at home I hear nothing special. It isn't chain slap on the top of the stay because I hear it even when I'm under power. Perhaps it is chain slap underneath, but I don't think so. When I shift gears it has a decidedly industrial cha-click sound as if amplified by the plates of the cage. By comparison the Cyclone on the Bianchi is eerily quiet. I can also rattle the chain by hand in the cage and have it make some noise. In any case, it works.
FW indeed!
![Big Grin](https://www.bikeforums.net/images/smilies/biggrin.gif)
FW indeed!
Real cyclists use toe clips.
jimmuller
jimmuller
I don't think I have seen anyone use a 34t with a FW and I hope you're not using that with your tandem because you are probably going to blow out the sun and planet in the hub with all the torque being applied through the gears. Can you enlighten me on the chain rattle? It seems if you have your chain adjusted properly, you shouldn't really get any chainslap to speak of. Are you dropping the chain a fair bit?
About the only way you're going to get a lighter FW is if you find one with an alloy shell. They are not too difficult to find, and an AW will work, though the stamping will be incorrect.
I think I may have a FW around (maybe two actually) if you are wanting a different one. I'd imagine a FW built into a tubular wheel will be a blast to ride!
incazzare.
That's Photogravity's M.O.!
![Wink](https://www.bikeforums.net/images/smilies/wink.gif)
FWIW, I also have had no trouble using a NR derailleur with a 28T big cog.
1964 JRJ (Bob Jackson), 1973 Wes Mason, 1974 Raleigh Gran Sport, 1986 Schwinn High Sierra, 2000ish Colian (Colin Laing), 2011 Dick Chafe, 2013 Velo Orange Pass Hunter
Liked 658 Times
For the OP's benefit, I don't doubt a NR could be made to handle a 28T cog if positioned carefully. But the other half of the question is how much chain take-up it can do. With, say, a 14-28 FW (not IGH!) and 42-?? rings, maybe. With a smaller BCD crank to run 34T, or with a triple to run 28T, it wouldn't work. Time to start counting teeth...
jimmuller
jimmuller
Old fart
Liked 3,460 Times
Hopelessly addicted...
Bikes: 1949 Hercules Kestrel, 1950 Norman Rapide, 1970 Schwinn Collegiate, 1972 Peugeot UE-8, 1976 Raleigh Sports, 1977 Raleigh Sports, 1977 Jack Taylor Tandem, 1984 Davidson Tandem, 2010 Bilenky "BQ" 650B Constructeur Tandem, 2011 Linus Mixte
Liked 10 Times
FW indeed!
FW indeed!
![Group Huddle](https://www.bikeforums.net/images/smilies/2419_group_huddle.gif)
![Stick Out Tongue](https://www.bikeforums.net/images/smilies/tongue.gif)
For those of us interested in using FW hubs, the use of it when you are referring to freewheels makes it incredibly difficult to find relevant information on the IGH.
Liked 10 Times
Liked 658 Times
Then, jimmuller, please cease and desist from using FW when you really mean freewheel!
Think of what you're doing to the children! ![Stick Out Tongue](https://www.bikeforums.net/images/smilies/tongue.gif)
jimmuller
jimmuller
Liked 10 Times
Freewheel Medic
Liked 2,253 Times
...and one with a great sense of humor and humility
especially when realizing the whole SA-FW-IGH verses "freewheel" BF search function dilemma.
![Thumbs Up](https://www.bikeforums.net/images/smilies/thumb.gif)
![Twitchy](https://www.bikeforums.net/images/smilies/twitchy.gif)
Bob
Bob
Liked 658 Times
Heatherbike, I do hope you are learning something from all this. 'Cuz otherwise it would all be for naught.
jimmuller
jimmuller
Thanks for the link to the tripilizer @ redclovercomponents. The chainrings on the bianchi are big and bigger, so the current set up is difficult, even for my husband who does not have granny gears on any of his bikes. I would like to use the original cranks, but the second chain ring is of no help to me. the arms are 170, but I need 160...sigh.
Bikes: '73 falcon sr, '76 grand record, '84 davidson
Liked 22 Times
i fully agree on looks ... but am curious what the smallest chainring one can use with a nuovo record rd with a short cage, given a 52t big ring and a 14-28t freewheel. does anyone know? for proper tension, i'd guess the lower limit is not much smaller than a 42t ring.
Bikes: 61 Bianchi Specialissima 71 Peugeot G50 7? P'geot PX10 74 Raleigh GranSport 75 P'geot UO8 78? Raleigh Team Pro 82 P'geot PSV 86 P'geot PX 91 Bridgestone MB0 92 B'stone XO1 97 Rans VRex 92 Cannondale R1000 94 B'stone MB5 97 Vitus 997
Liked 49 Times
Supposing 53/39/30 triple and 12-26 freewheel, capacity required is (53-30)+(26-12)=37 which is of course larger than the Nuovo Record's listed 28 capacity, but just don't make a habit of riding 30x12 . . .
Liked 658 Times
Think of it this way. If you were on the little-little combo (assuming the chain was short enough for the RD to accommodate it) and you shifted to the big-big combo, how much chain would the RD have to give up?
Or conversely, if you were on the big-big combo (assuming the chain was long enough for the RD to accommodate it) and you shifted to the little-little combo, how much chain would the RD have to take up?
It just the amount in front plus the amount in back.
You may decide never to use either extreme combo, but you might always do it accidentally.
jimmuller
jimmuller
That is correct. I once shifted onto the big-big combo when my chain wasn't long enough to handle it. It was interesting to do once but I would not want to do it again.
www.redclovercomponents.com
--Ogden Nash
--Ogden Nash
Liked 49 Times
You'd size the chain to handle big/big, and avoid using small/small.
Liked 658 Times
If you can remember not to do that.
I confess I've hit big-big occasionally when I shifted down in the rear without thinking or shifted up in front when I'd forgotten which cog I was on, but I've never hit little-little. (Of course I use the little cog so infrequently.) Even so, I set up all my bikes to handle both combinations if I do it accidentally. Needless to say, I've got long-cage RD's on them all. Better not to have to worry.
jimmuller
jimmuller
Liked 658 Times
This may be a dead thread by now but I'll post this followup anyway. I found the cause of the rattle on my Masi. The long cage on the RD has nothing to do with it. The 4 largest cogs on the FreeWheel are free enough to rock forward and back by a mm or so on the FreeWheel carrier. That's causing a bunch of clicking. I've put in a note to Pastor Bob, or resident FreeWheel expert. I've never seen this happen before.
jimmuller
jimmuller
Liked 2,257 Times
Intersting. I would like to know the findings!
I have had a 28 on my 52/42 with an NR. I avoid the big/big completely. I tried a 30 but just didn't like the risk level based on my age induced memory slips! I do have one of the longer cages for the NR. May have to try it at some point.
very old thread, but thought I'd see if any of you are still monitoring this posting.
just bought an early 80's colnago superissimo and want to put my 1st gen campy rally on it so I can run a 28 or 30 on it comfortably.
the issue on my other vintage ride is the cage hitting the largest freewheel cog, w/no d screw. with the rally, which hasn't been used, will this work with a double crank and appropriate length chain?
the current group is the campy victory, I don't believe I can go any larger than 26 in the rear.
Liked 3,667 Times
Putting longer cages on short cage nuovo and super record rear derailleurs
Happy to say I have just completed transplanting some Rally parts to my SR rear derailleur.
My SR derailleur was working good but I wanted to replace a 40T chainring with a 36T one. I learnt from various posts of Bike Forums that a longer Rally cage would have allowed more chain wrap.
With some waiting, and hunting, I have replaced the following:
- the stop pin
- the spring inside the derailleur body
- the cage plates and the jockey wheels
Result:
- still enjoy the SR titanium bolts' lightweight benefit
- wonderfully smooth shift with the new Rally spring
- quite and smooth new pulleys
- a shiny stop pin
The longer cage has allowed me to replace my 40T front chainring with a 36T ring, which has made climbing so much easier.
It was a NOS Rally. When it arrived, it took me two days to accept the look. However, after the transplant, and it particular the test riding, I was satisfied with my project.
In hindsight, it was feasible and much cheaper buying a brand new Rally cage than bit and pieces of the cage plate. Only the Rally cage plates are available on website but not the screws (screws of SR and Rally are not compatible.) . Buying a whole Rally also gives me a new spring and sets of jockey wheels.
Am very happy with the project.
- the stop pin
Result:
- a shiny stop pin
