Wiki list of Gravel tires
Ride First, Work Later!!!
Bikes: Specialized Tarmac, Trek Superfly, Raleigh Rush Hour
Quoted: 27 Post(s)
These issues really become a concern when you start looking at sizes that may be too big, if they end up bigger than advertised, or not big enough, should they come in smaller. Of course there are many differences that can change a tire size, internal rim width for instance. But when one is comparing two same branded tires on the same rim and getting varying sizes it can make it hard to know what will fit when looking at max width.
Bikes: 2015 Ridley Fenix Ultegra, 2016 Ridley X-Trail
Quoted: 29 Post(s)
Maxxis Rambler 40c and 38c tubless
Size: 40c, actual measurement at 37mm
Size 38c: actual measurement 34mm
tread pattern: small knobs for dry conditions
construction: 120 tpi, flat protection, tubeless ready.
performance on pavement: excellent. Similar to road tires.
performance on firm and smooth gravel. Excellent – easy to transition from dirt to grass to pavement
performance on deep or soft gravel: Not bad.
durability
ride: reputed to be compliant for a tubeless tire. The don’t feel particularly firm or harsh to me, but it is winter time.
durability
On top of the width variation, my mechanic friend was telling me that lots of cross and gravel tires have problems with non-straight treads and carcasses. Perhaps the relatively large size magnifies the distortions. But yeah, the size printed on a tire is only vaguely connected to the actual width of that tire.
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
I don't get much variation with rim width, but these specific rims are 19mm internal width. I do get a little rubbing in the rear under full power.
Quoted: 29 Post(s)
I've been using the Challenge Gravel Grinders (marked 38mm width and about true to size) that came stock on my Ridley X-Trail and really like them but planning on going tubeless with my new wheelbuild. Also looking for a little bit smaller tire since I also have some tire rub on the frame on the chainstays (on both of them).
Thanks for getting back to me chas58!
Edit: At least with the Gravel Grinder tires, there was no noticeable difference in tire width between the stock DT Swiss R23 Splines and the new wheels which have Belgium+ rims. I was a little surprised to see that since I've heard wider rims usually mean the tire will get a little wider as well.
Have bike, will travel
Quoted: 910 Post(s)
Liked 288 Times
700x36 tubeless Clement MSO: X'PLOR MSO | Clement Cycling, Cyclocross Tires, Adventure Tires, Mountain Bike Tires, Road Bike Tires
The tubeless MSO is easy to mount. I've installed the tire on two rims, one from Alex and another from Impulse. Both tire installations were easy using a conventional floor pump. I coated the rim and tire in the bead area with soapy water and the tire seated itself quickly.
The tubeless version of the MSO is more versatile than the tube version. It fits more bikes, including most Cyclocross bikes, due to the smaller size. It feels much lighter and is. It rolls faster at 55psi and has excellent soft gravel performance at 40psi. It rides smoother than the already smooth 700x40.
The tire is a great all-around performer.
- size: 700x36, about 37.1mm wide
- tread pattern: tightly packed small knobs for mostly dry conditions
- construction: unknown tpi, has flat protection, tubeless
- performance on pavement is excellent for a knobby tire. It's like most touring tires this size with secure cornering on wet or dry pavement.
- performance on firm gravel is excellent, with excellent cornering and braking
- performance on deep or soft gravel is very good with good control and sufficient volume over rough surfaces. Excellent braking in soft conditions. Cornering performance and float on soft surfaces is limited by the lack of bigger knobs on the shoulder.
- durability: good so far
- ride: smooth and plush
Quoted: 27 Post(s)
Liked 415 Times
I have liked mine so far, however, after mounting them on a new set of rims I noticed an "imperfection" on one of the tires in the pattern. It has a very obvious deviation to the pattern, almost appeared the wheel was severely out of true, possibly wouldn't have noticed but I was spinning the wheel in my hand to spread the sealant. Putting the wheel in the truing stand showed it was the tire itself. I don't think it will cause any real issues but it is very obvious, and on the front wheel now...
Put soapy water along the tire bead, this allows it to slip into place without getting hung up.
Bikes: 1997 Rivendell Road Standard 650b conversion (tourer), 1988 Schwinn Project KOM-10 (gravel/tour), 2013 Foundry Auger disc (CX/gravel), 2016 Cannondale Fat CAAD 2 (MTB/winter), 2011 Cannondale Flash 29er Lefty (trail MTB)
Quoted: 167 Post(s)
Liked 5 Times
Yeah I had that problem a lot when I first had tubless tires/rims. I didnt' realize it at first, but the bead was not seating evenly against the rim. It can be a nightmare to get right, until I read of a simple trick:
It can happen with tubeless rims and tires, or with standard rims and tires.
Lubricating the bead when mounting helps a lot. I use laundry soap, because the laundry is close to my bench. I just dip my finger in the half-filled cap and drag it across the bead.
It also helps to check the bead when the tire pressure is still low, like 15-20 psi. At that pressure, you should be able to massage the tire bead up into its channel with your thumbs.
Quoted: 27 Post(s)
700x30 Michelin Cyclocross Jet and 700x30 Michelin Mud2.
Both these tires are closer to 32 mm in practice. These tires in theory work pretty well tubeless, though they're not intended to be. I've only used them with tubes. The Jet is a modern take on a file tread tire, not tons of tread. The Mud2 has some more serious side knobs, but still rolls pretty well because the tread doesn't really protrude that much. Both are fine on firm packed dirt/gravel. The Mud2 is about 1000x more confidence-inspiring when cornering on gravel thanks to actually having some side knobs. The Mud2 is also still quite capable when things get tacky or wet. The Jet is pretty poor in those conditions. I don't think most people will be happy with the low volume of either one. They do roll fast. Of the two, I prefer the Mud2, it feels a lot more secure. Ride is fine as far as I'm concerned, but it is only a 32 mm tire.
IME it happens quite a lot with tubed tires on tubeless-ready rims. It's caught me off-guard because I have a wheelset with Velocity A23 rims that I didn't buy with any thought toward using them tubeless, at the time, didn't even know they were tubeless compatible. So I was confused when they turned out to be so darn sticky.
Quoted: 167 Post(s)
Liked 5 Times
That's not always the case, sadly.
Personally, none of tubeless-ready rims (Pacenti PL23, Stan's Iron Cross, and Sun Ringle Mulefut) have problems with the tire bead getting "captured" down in the channel. But they're all difficult in other ways; they're tough to get the tire over the bead. And the Mulefuts are crazy difficult to remove a tire from.
My worst rims for bead seating problems have been cheapo Weinmann ZAC19. These rims have gained a reputation for this problem. Even with soap on the bead, I usually need to stop inflation around 20 psi and manually persuade the tire bead up into the bead seat on the rim in several spots on each tire. Exasperation.
Some have solved this problem by adding a second layer of rim tape, to give the tire less room down in channel. Fat bikers have long used foam strips down in the channel when setting up non-tubeless-ready rims, for the same reason.
Quoted: 167 Post(s)
Liked 5 Times
I've been doing this the 3 years I've been running tubeless and it usually helps quite a bit, however this tire has been mounted multiple times by multiple people with the same result... It was also checked at low pressure the last time, throughout the process. The Iron Cross rims are only rated to 45 psi and I've yet to go over 40 in setting them up or using them. After multiple attempts at "correcting" the deviated bead I took them to my LBS and we went through the whole process again with the same result. Maybe one spot continues to not seat evenly but that would seem rather strange when going through the process multiple times?
I wouldn't ride the Iron Cross rims at 70 psi, but it was safe enough for mounting. YMMV
Quoted: 910 Post(s)
Liked 288 Times
@canklecat @Tim_Iowa , This thread is going way off topic, can we get back to tire reviews, please?
The following thread is a better place for tubeless installation discussions: https://www.bikeforums.net/recreation...xperience.html
Quoted: 27 Post(s)
Last night, I helped my girlfriend mount a 700 x 40 Gravel King (42 actual) on an Iron Cross rim (with a tube). The tire bead was down in the channel in a couple spots. I lowered the pressure and tried to massage the bead in place, to no avail. Eventually, I pumped the tire up to 70 psi and that snapped the bead in place all around.
Quoted: 27 Post(s)
Quoted: 167 Post(s)
Liked 5 Times
Thanks! I had not thought about/considered this due to the recommended max pressure being 45 for the rims. However, this may be something to try to see if it will correct the "problem". Once you had them seated did you lower the pressures back down and everything still looked good?
@Barrettscv sorry about the thread drift.
Quoted: 910 Post(s)
Liked 288 Times
Schwalbe S-One 700x30
size: 700x30, about 32mm wide
tread pattern: tiny dots, like on a ping pong paddle
construction: 127 tpi, flat protection included, tubeless
performance on pavement is excellent, like most road bike tires
performance on firm gravel is excellent with very good cornering grip on a hardpacked fine gravel
performance on deep or soft gravel is deficient, float and traction is limited, it's practically a slick.
durability: very good so far
I set it up tubeless on Velocity A23 rim. The tire was eventually easy to install tubeless with a standard floor pump. I did pre-fit the tire using a tube and let it take shape at 80psi for 48 hours. This allowed the tire to seat quickly and hold air with 30 ml of sealant.
The Schwalbe 700x30 S-One is lightweight and very fast rolling. The S-One helped me maintain the same kind of speeds I produce on my road bike with 700x25 Rubino Pro tires. At 80 psi rear, 70psi front, The Schwalbe is not as plush as the open tubular tires, but it rode more smoothly than 700x25 Vittoria Rubino Pro tires. I'm sure it becomes super plush at 20% lower air pressures, I'll experiment with the air pressure in the future.
The S-One is almost 32mm wide. The micro-dot texture and compound provides super high levels of traction on pavement. The tire is wide enough for all the firm gravel near my home in Illinois. It will also work well as a 50/50 pavement/gravel tire in Missouri when the gravel is mostly firm.
Thread Killer
Quoted: 3237 Post(s)
Liked 1,794 Times
Schwalbe S-One is 127tpi and uses Level 5 (of 6) V-Guard puncture protection. It is 330g.
For '17, apparently S-One is rebranded as G-One Speed. They are expanding the line with a 60mm model, apparently adapting the textured tread pattern to the slick Big One's casing. The S-One moniker has been dropped from Schwalbe UK and Schwalbe International websites.
I have been very happy with my S-Ones on hardpacked gravel roads and they are really good on pavement, feeling solid and hooked-up even when cranked over; they're quiet and do not buzz on tarmac. Performance on shallow, loose surfaced gravel is good, as they're supple to conform to irregularities and narrow enough to cut down a bit to the firm underlayer. Snow performance is good for this reason. Sticks to dirt pretty good during unseated, power climbs.
Very nice tires, IMO.
Quoted: 62 Post(s)
I noticed that a lot of the tires mentioned in this thread are on the narrow side (relatively speaking). Do folks run them because of limited frame/fork clearance or because they just prefer that size (range)?
Quoted: 910 Post(s)
Liked 288 Times
I run 700x45, 700x36 and 700x30 depending on the bike and condition of the gravel.
700x30 is light and fast rolling on pavement, while providing a large enough volume for firm gravel.
700x36 fits most Cyclocross bikes and has enough volume for all but the softest gravel roads.
700x45 is capable on very soft round gravel, but is slowest on pavement.
Most gravel rides are a mixture of pavement and gravel and most gravel is reasonably firm. A big tire is not always the best tire, depending on the type of gravel and if pavement is a factor.
The only all-around tire I've used that was fast on pavement and stable on a wide range of dry gravel was a 700x37 Vittoria Hyper (slick). This tire is light enough and rolls easily for fast pavement rides and has enough volume for soft gravel. See: https://www.bicyclerollingresistance....ger-hyper-2016
Gotta throw out the cream/gum panaracer pasela 38s you can get on velo orange as well. They're smooth, but thick enough to ride well in gravel.
Some sorts of equipment only exist out to certain sizes. For instance, if you want to run deep aero wheels, 30mm tires are about as wide as you can go; no rims currently exist that are aero when coupled to tires bigger than that.
There are some surfaces where narrow tires can offer better traction. For instance, on some kinds of mud, it's better to slice through the shallow soft slick layer than float on it.
And, plain old weight-weenieism.
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Tire: Schwalbe G-One Allaround (Evolution/MicroSkin/TL-Easy).Advertised Size: 35-622 (700 x 35C)
Actual Size: 38.1 mm actual width on American Classic 29" MTB Race wheels with 24mm inside width.
Tread: tiny dots, like on a ping pong paddle
Construction: 127 TPI, tubeless ready, folding bead
Performance on Pavement: Fast. Feels like a road tire.
Performance on Firm and Smooth Gravel: Fast.
Performance on Deep/Soft Dirt and Gravel: Tends to spin on loose surfaces due to lack of proper knobbies. Sand and mud can be troublesome.
Durablity: Wears fast. I don't think I'll get 1500 miles out of the rear tire but I'm not easy on them.
Ride: Coming from a road background and having ridden mostly clinchers such as Michelin Pro 4, Vittoria Rubino Pro and higher, etc., these tires impressed me. I was expecting them to be a lot worse on the road. A little more sluggish than a road tire due to the extra weight but good when paired with a light wheelset. They fly on packed dirt and smooth cross country running trails.
Initial install with tubes was difficult. Wheels and tires sat for a few weeks while the bike was assembled and subsequent setup tubeless was easy. I have a compressor and cannot comment on how they would install with a pump.
These have a great ride on pavement. I would recommend them for a roadie getting into gravel who is worried about poor traction or poor ride quality with gravel tires. Get these and don't worry about it.
-Tim-
-Tim-
Non omnino gravis
Tire:
Panaracer Gravelking SK 700x35. Mounts to exactly 38mm wide on 17mm internal wheel.
Tread pattern:
3 rows of ~3mm knobs with ~3mm spacing between knobs, then two rows of bar-block knobs on the rest of the tread surface. Sidewalls are smooth.
Construction:
Panaracer makes no mention of tpi (that I can find) but they are as supple as your usual Panaracers. Dual-compound tread, "anti-flat casing" is bead to bead. Tubed or tubeless, limited to 70psi tubed or 60psi tubeless. Actually alarmingly light for such a big, treaded tire-- 380g.
Performance on pavement:
Surprisingly good. The width, suppleness, and tread combine to give a little bit of resistance in what I call the "transitional phase" between say 13-18mph. At least more than a smooth tire, anyway. Above 20mph, they cruise along as if they were 700x25 slicks.
Performance on firm and smooth gravel:
We have little in the way of gravel here, but we do have hardpack/loose-over-hard dirt in the shape of fire and access roads. The Gravelkings feel exactly the same on hardpack and loose-over-hard as they do on clean pavement. Have taken them up some fairly steep dirt trail, and even out of the saddle, they are firmly planted.
Performance on deep or soft gravel:
Can't say. I also haven't taken them into sand, but don't really plan on it.
Durability:
Too early to tell. Ordinarily I don't even start to think about any review/opinionating until I've god a good amount of miles on them, but straight out of the box they have thoroughly impressed. Even riding right through fields of visible tribulis terrestris, they didn't pick up a single thorn.
Ride:
Running them tubeless @ 60psi, haven't even thought to tinker with pressures. They are exceptionally comfortable on road and off. They outroll the Maxxis ReFuse TR that they replaced, despite mounting 6mm wider and being covered in knobs.
I didn't buy them specifically intending them for gravel, as we don't have that here-- they're intended for pavement (and those vast sections of what we dare to call pavement) and scrabbly SoCal hardpack... and washed out hardpack. It's far to early to say they're perfect, but at first blush they sure look perfect.
Tread pattern:
Construction:
Durability:
Ride:
