Keeper?
Quoted: 2588 Post(s)
Liked 4,827 Times
DD -
I chose the method of riding w/o sealant until I flatted. (I have about 1000 miles on the 2 set now, and the first flat was last week). The argument I followed was, the sealant will add rotating weight and "change the feel". Made sense. And I have no regrets.
I used Stan's. I keep a 2oz bottle in my saddle bag along with a valve wrench. When I flatted, I put about 1/2 the bottle in, rolled it around a bit, put in some additional air ~20psi, rolled it around some more (not sure if it was needed , but it seemed like the right thing to do), then pumped it up fully. had a bit of bubbling from the hole, I put that side facing down, and 5-10 sec later it was fine.
DD
Liked 4,827 Times
On my main ride I only have a tubular wheelset. I have never tried tape, but glue works great and is easy to apply without much mess. I typically use a rubber glove to apply the glue to the tire and rim.
All tubulars were easy to mount. I always have mounted them first with air to "stretch out" and had no trouble once gluing.
Centering the tire can be tedious but not to difficult and gets centered in about 5min of adjustment.
I have tried the 3 for $50 tubulars from Yellow Jersey. They are great for the price but wear fast and failed me on a small glass cut in the tire.
I have had similar experience with Vittoria Rally Tubulars too, just ok
I spent a little extra on some Veloflex tubulars and they are working great. Very nice ride and puncture resistance so far (knock on wood). Ridden them all last season and they are still in great condition. Although the sizes were a bit off (25's measured 22-23mm and 28's measured 25mm)
In terms of dealing with a puncture, I have tried Vittoria Pit Stop and Stan's
Vittoria Pit Stop - when it works it works great. when it doesn't your out $15 a pop. Sometimes the head doesn't seat correctly on the valve causing a mess. Also had the can not inflate the tire enough to be rideable.
Stan's - Works great most times (better results than Vittoria & smaller to carry in saddle bag). If you pre add you have to top off or it will expire in the tire after some months. I find it best to add when needed and fill up with a pump of CO2.
So, I have a few tires to play/test with. While I plan to put some high-end rubber on the wheels eventually, since this will be a re-learning process, it would be smart to begin the journey with what I have. Based on the advice here, I'll also be getting some Stan's and a valve core remover and add them to the flat-repair kit.
Thanks for your comments and suggestions - much appreciated!
DD
Liked 4,827 Times
You mentioned reading the tubular thread. If you do you will see all the various methods. It just becomes a personal choice.
My choices changed over time. Started with Tufos and Tufo tape for a low cost entry point. Easy to use but found it very very hard to change a tire and would never attempt it on the road. Quit using tape and relegated my Tufos to spares since I did not like their ride.
I now use Veloflex and Vittoria. Not the most expensive tires but still up there. I decided if I am going to do this I wanted to enjoy the ride.
And I learned to fix a flat the traditional way. Not a big deal especially if you have sail stitching experience.
If I flat now I just swap in a spare to get home. Later I glue on a good tire. I did try Vittoria Pit Stop till I almost got stranded. I’ve only flatted three times. I have more peace of mind changing out a tire and not worrying if the sealant will hold. It’s easier than fixing a clincher flat.
Yes, I took a quick peek at the Totally Tubular thread and it's 60 pages long and counting! Found out I posted back in 2019 looking for some answers, too - I noted that I've always had others do the gluing/taping then and it's high time for me to get on with it myself.
I must admit to wondering about the ride of different tires. My go-to choice bitd were Vittoria Squadra Prof in 22mm and I remember the rear end chattering around corners vice being planted - something I'm not sure my aging reflexes will still be able to deal with. While I run pretty high pressures with my open tubular Vittorias (120psi), the rear wheel is always stuck to the road. Very confidence-inspiring. While I liked the lack of rolling resistance, the road feedback was kinda...harsh. This was in the mid-to-late 90s; from what I read, plenty of improvements have been made to the modern, high-end stuff. Personal choice, indeed; what specifically did you not like about the way the Tufos ride?
DD
Liked 4,827 Times
Jeff, Great looking bike! Ride it like there is no tomorrow! 18lbs?
WRT sealant. I don't use any. Tried it once, using the green stuff. The hole was to big for it to seal. If you need to add every year, when does the tire become solid? Sounds really messy to me. I would rather patch myself. This requires some investment in the tire stock.
The more I read here and in the Totally Tubular thread, the consensus seems to wait until I get a flat, then add sealant. Remember that post recently with the tube that had blobs of sealant dried up in it? Looked sorta like link sausage - don't want that, and as you note, at some point the liquid is going to solidify, then the wheel will have misplaced "weights" which would make for fun descents! But I'll go that route vice repair because this will be my only tubular user set and I already have one very-slightly-used and two NOS pairs of tires already.
Yes, when I last weighed the Alpina with tubulars it was 18lbs and something. I even have photographic proof somewhere - I'll try to dig it up.
Heading out today to get a brass brush wheel to remove the glue residue and some tape (I'm going to go that route to begin with). Not sure if I will make the attempt to mount them tonight, but if I do I'll post the results. Probably not a ride report as the weather still sucks!
DD
“Senior” Member
the difference in ride was indeed dramatic when I first rode a new set of Vittoria Corsa G+ 25mms. Heaven. Even better when I setup another wheelset with 28s. I got two actual flats on this brand —over a lot of miles so no worries—but I noticed whenever the road was wet the tread picked up road gunk too easily.
so I tried Veloflex Vlaanderens in 27/28mm size. My favorite all time now. None of the tackiness on wet roads and sublime ride quality.
but again these are personal choices. Like one may like a race care that telegraphs every bump in the road or another a smooth riding town car for Sunday driving!!
(neither of these ride like town cars by the way)
I learn best by doing. I really over thought the flat tire thing. (I hardly ever get them.) Read advice all over and was real scared about getting one. ;-). In the end I got rid of sealants because of the above complaint AND I observed a friend (riding a gorgeous 70s De Rosa which he raced back then) casually whip a flat tubular tire off and flip a worn spare back on faster than any club clincher rider ever could.
Liked 4,827 Times
A couple of things: 1) the Tufo S33 pro I chose was very narrow. 21 mm I think. So they felt hard. 2) Tufos are sort of bonded together construction-wise so that also contributed to the hard ride. There is no suppleness at all in the side wall. I have previously described them as riding like a brick. And you cannot open and resew them. You have to use their goop. At least I did. It worked on a pinhole fine but I watch the container over time change into a ball of rubbery gunk and I did not like having that inside my tires. Lastly 3) aesthetics were terrible. I wanted and got a skinwall version but over a short time they darkened to essentially a black wall.
I do realize everyone will have their favorites, but I will be honest and say if they felt like a brick to you they probably would feel the same to me - and exhibit that dreaded skipping/chattering vice being planted in a turn.
As far as speed when doing a tire change goes, it's been my experience on group rides that a flat provides an opportunity for rest/relaxation/conversation/criticism/helpful tips while watching...you know the drill. It's almost as though the longer a tire change takes, the better for some! But, just for the record, I once changed out a tube and was almost done pumping it up - in less than 3 minutes - when the valve stem snapped off. Oops
Oh, and I'm the same way: learn by hands-on. I'll be having fun playing with these and seeing what I come up with for the best workable solution.
DD
Liked 4,827 Times
I have a pair of tires stretching inflated on a Colnago right now. The last three bikes I have been riding are clinchers.
if Clement Red was still being produced, the tires would be glued on the Colnago.
I have a few cans of Vittoria glue.
bought very cheap along with a case of tires, while it works fine, an on the road tire exchange falls short.
change the tire and ride gingerly home.
My thought now is to purchase the Miyata tape and have it as the on the road bond method so I do not need to turn around after a puncture.
DD
Quoted: 2376 Post(s)
Liked 2,904 Times
my 2 cents to the Dude
I am still pretty much a rookie with tubulars, but the ride is clearly better. noticed the difference when I switched from conti gp5000 28mm (which are a great tire) to Vittorio Corsa Control 30mm on my 85 team miyata. (wheel build similar ultegra hubs and mavic open pro rims) and my 84 team miyata with challenge elite tubies at 25 is the best ride of any bike I have but part of that may be the light gel 330 rims
I have done tape and glue. Tape is easy, but Glue really is not a big deal, IMHO there is way to much fuss and feat generated here is the best video I have found on that subject Tubular Tire Mounting Cement Gluing Adhesion by Yellow Jersey; Thoughts on a Front Wheel
brass brush wheel is great for removing old glue without damage
I like the cafelatex sealant
suggest 27 to 30 mm tires you can get good deals still from uk bike shops.
If you wanted some green contrast with the tires the pave here would be a option, and many people speak highly of the pave and bemoan that is is discontinued....https://www.merlincycles.com/road-bi...yre_width=30mm
enjoy
enjoy
Liked 4,827 Times
+1...
Been riding tubulars since I first began cycling back in the 70's. Started w/ Vittoria's, but switched to Veloflex & haven't looked back. Great riding tire & durable. I like the 'Sprinter' & 'Criteriums' in particular.
A friend once brought me back a pair of Signature Veloflex's on his return trip from Italy in the 90's since I owned a Colnago. They read 'Colnago Master' on the sidewalls. I treasured these tires for years & 1 tire still is OK...
I've always glued my tubulars on & use Vittoria Mastk 1. Stuff is very sticky & really don't relish the task, but it's always held strong.
I'll have to look into Tufo Tape? Sounds easy~peasy. How difficult is it, removing taped tubulars from the rims?
Jeff: as much riding as you do, I think you'd luv the ride tubulars can give...
Rich
Rich
At some point it seems I need to pick up a pair of Veloflexes - the name comes up constantly as a high-end tire that's a performer worth the money. Oh, and one thing I learned in my reading during the past 24 hours is to leave about 1" or so without tape opposite the valve hole to help in removing a flat tire. Makes sense to me, because my understanding is the tape holds well, to the point it could end up pulling off the base tape of the tire. Slowly but surely is how I will approach both putting them on and taking them off. I'm not in a hurry; I'm retired, after all
I certainly hope there will be a noticeable difference in ride; I know this bike will feel differently on the road simply because it's at least 2lbs lighter than anything else I own. Since I'm pretty happy with the ride of my favorite Vittoria clinchers (open tubulars), I'll be happy enough if they match that feel and performance.
Hopefully I can get a good mix of durable, supple and provide sound road feedback. We'll see soon...
DD
Liked 4,827 Times
Tufo tape holds strong. When I tape a tire on, I leave approximately one inch of the rim opposite the valve stem without Tufo tape. I carry a small slotted screwdriver in my tire sock. On the very rare occasion where I needed to change a tubular on the road (once in the last 5 years and I ride around 5,000 miles a year), I use the screwdriver to help get the tire started for removal. Once you get a little bit of tire peeled off it is easy to remove it the rest of the way.
Back in the day, I used Wolber tubular glue and never had a tire roll off, but there are more steps to mounting a tubular with glue. I find that Tufo tape makes mounting and running tubulars much quicker and easier. Plus, as I mentioned in my earlier post, tire sealant takes the fear out of having to throw away a tire with a minor puncture. I have been getting an easy 1,000 mile plus out of Veloflex tubulars used on the rear wheel. Of course, YMMV.
At least once in my life I need to repair a tubular (and build a wheel). Perhaps I'll get to do both this year, maybe even on the same wheelset
Got a nylon wheel to take the residue off the rim, so I'll get that done tonight I think - but will have to call around, find out where I can find the tape since my LBS doesn't carry any.
DD
“Senior” Member
Sources I have used are almost always the typical UK vendors: lordgun, probikekit (all over) and most recently Merlin cycles which I just saw has some Veloflex and Vittorias in stock in the 50-60 buck range. Most are models phasing out which you will note if you watch things. I bought all my vlaanderens at good prices because they were moving them out. On a tip from this board I bought 5 more after not being able to find them anywhere for a while. I would not hesitate to buy their newer models.
this thread needs more pic and more of your alpina . Love the color. Below is my Bruce Gordon with pretty sure vlaanderens.
Likes For obuckler:
Veloflex tubulars at Merlin are the remaining stock of some of the models that are goin to be phased out I believe? Don’t think the prices they’re selling for will last. Better jump on a few while they’re still available.
IIRC: my riding bud has snapped-up about 12 of the
Criteriums...
That beautiful Alpina deserves them . . . 😎
Liked 4,827 Times
enjoy
enjoy
What I remember liking best when I helped Wildwood mount a pair was that once we had the tire on and semi-inflated we could mess around and spend plenty of time getting it perfectly centered on the rim without worry that the cement would set before we did. Once to his liking, we just pulled the clear-red covering and the tire was set. The older I get, the more I like Easy Street
Lastly, I am on the lookout for Challenge Elites in 25mm - those would make me very happy. Should've bought them months ago when I saw them for $45 per on Ebay. I used their Elite clinchers and they were fantastic at 260tpi. Wouldn't be surprised if their tubular version is even better.
DD
Liked 4,827 Times
I will add the above-mentioned retailers to my search and see what I can find. Although I currently have 3 pair (and really, this will be my only tubular-wheeled bike), I do want to put a nice, modern pair on at some point. Veloflex, Vittoria, and Challenge are all on my short list.
Oh, for sure I'll be posting more pics; this bike has truly been neglected when it comes to sharing here. I'll fix that in the next couple days, always assuming I can pick up the tape locally. I may look online, too, see if I can save a little coin that way. Then, the completed wheels will sit and mellow for an entire month while I'm out of town; the test ride will hopefully go down early April.
DD
Liked 4,827 Times
For now, here's a close-up of one of the fork tangs:
I believe a certain well-respected American framebuilder still has these in his inventory - and uses them.
DD
DD
smelling the roses
Quoted: 7081 Post(s)
Liked 901 Times
Timely. I have no advice to offer. After years of consideration and rims/hubs/tires collection, months of stretching and hand wringing, this morning I decided today is the day. I will be using Hutchinson glue and either a Veloflex Challenge Elite or YJ tire(I have only one wheel ready). Mavic Monthlery Pro rim and Campy Record hub.
Edit: That is if I can find said Hutchinson glue.
Likes For seedsbelize:
Quoted: 1618 Post(s)
Liked 2,234 Times
This thread inspired me to review my stock. I was thinking that I had too many 32 hole rims and not enough 32 hole hubs. After looking through the stash, many more 36's than 32's. What a relief!. Need spokes and more tires. I did find a new pair of Challengier Parix-Roubaix in 25 size. And I may have a wheel set ready for them that I can put on the Bottecchia and later either the 610 or 760. Well the 760 might require Veloflex!
Thanks all for the inspiration!
Likes For SJX426:
Bikes: miyata 83 1000,84 1000,83 610,88 ridge runner ,Schwinn 84 high sierra,88 Cimmeron,86 Passage,84 Stumplumper ,83 Mt Whitney,83 Trek 850,Merckx Century,PX10, RB1,XO 1 XO 4,bunch of stuff like that
Quoted: 57 Post(s)
Liked 51 Times
keeper
I was just thinking about my keeper bikes.When you like something you cant help it .You just like it.Its not an intelligent decision its emotional.You can get attached to anything for no reason at all.Its only a real keeper to you and no one can convince you otherwise.If you think its the best bike in the world, then it is. Sometimes our fantasies are more real than reality .Ive always had good luck with tubular tires ,use to ride them all the time , still do but not so much.practical, durable ,dependable, actually easy to change ,great ride ,a little harder to find, bit more expensive, Ive never tried tape but if you use glue ALWAYS bring gloves on your ride,PS clean machine
Likes For homelessjoe:
Liked 2,904 Times
Thanks for giving me some more points to consider. Size-wise, It looks like I won't be able to fit anything larger than a 28 - anything bigger is likely to foul both brake pivots. Interesting that the YJ article shows to stretch the tire while mounting; I assume everyone is pre-stretching them nowadays because if I were to go with glue I'm positive I wouldn't have to stretch any of my current tires while mounting them.
DD
DD
CHALLENGE ELITE PRO 220 TPI TUBULAR ROAD TIRE
$32.99- Use: Road Training
- Tire Width: 25 mm
- Internal Rim Width: 13-15 mm
- Weight: 295 gr
- TPI: 220
- Casing: Poly
- Flat protection: PPS
- BAR: 7-12
- PSI: 100-175
- Inner tube: butyl
Liked 4,827 Times
- Tire Width: 25 mm
- Weight: 295 gr
- TPI: 220
- Casing: Poly
- BAR: 7-12
- PSI: 100-175
- Inner tube: butyl
They'll be here in just a couple days, so I am going to hold off mounting any of the other pairs and just go with these right off the bat. Still have to snag some tape today.
DD
Liked 4,827 Times
Yesterday I took apart the tubular wheelset that came with the Bianchi - gonna sell the Phil Wood hubs and Ambrosio rims separately. Saved all the spokes and the nipples as well. I cleaned them up best I could, and they're presentable, but they do have "patina". A bonus is they came from wheels that saw little mileage.
DD
Liked 2,234 Times
If you need some spokes, and you don't mind galvanized and kinda ugly, I have some for you. 72 of them, in fact
DD
DD
If the Ambrosio rims were tubular and Nemisis I would negotiate with you!
Liked 4,827 Times
DD
Liked 4,827 Times
Got a crapload of pics during this afternoon's photoshoot before the rains came. A quick trio for now:
DD
DD
Liked 4,827 Times
Okay, finally, a boatload of detail photos of my seldom-seen and almost never-used Alpina.
1979 coded Super Record RD; drilled jockey plates by yours truly. Regina Oro chain and BX freewheel:
Jon milled the long slots onto the spring collar of the RD; note the chain peg taken down to bare metal at the top of the photo:
Bog-standard Record hub with curved early QR blade:
Jon also did this custom-milled post. At the time it was early days of Drillium Revival and he was just getting started listing items on Ebay. We'd already established a relationship; I wanted one of his modified posts, but wanted a mix of features that his Ebay spec items didn't offer complete. He said he had this less-than-perfect one (one or two minor pits, but I didn't care) he could use, and we agreed to a milled head and long, round-cut flutes. He even went to town to polish it up beautifully - that's not my work! I've been toying with the idea of infill painting the milled area, but then I think no. What do you think?
A good look at the milling of the head from the rear; again, would some black infill paint add to the effect or spoil it?
The filing around the brake bridge reinforcements was so good I left them alone; I did remove a little meat from the brake caliper, tho:
The little flourishes on the cable guides are mine; I did them with a sanding cuff on the Dremel. I further filed all the points on the BB shell as well:
Rings are cut down and shaped Record units with the obligatory drillings. "Mexico" treatment on the crankarms taken to the extreme - not by me - and highly polished, too. Front derailleur band has been milled out in front and rear:
Some have deemed the rings' look "Medievel":
Yes, I even drilled the alloy toe clips:
DD
DD
Likes For Drillium Dude:
