Cooling off with water splashed on body
Klaatu..Verata..Necktie?
Quoted: 10632 Post(s)
Liked 12,255 Times
The through the helmet method is perhaps the best, if you are careful you can get all the water on your body with zero waste. It is also doable while moving on the bike without too much difficulty.
My current favorite method is to find a safe stretch on the ride, look way up, pour a ton through the helmet at the mid-back point, and keep looking up for ten seconds. The excess will then flow on to the back. Too much and it will get all the way to the pockets and too little will wet too little so it takes some practice to get right. There is no water wasted this way. If you don’t look up long enough some excess will drip down in front and get wasted.
I also will spray a small amount on front and shoulders but there is more waste so I don’t use too much there. Of course if a refill station is coming soon, let ‘er rip!
Quoted: 4033 Post(s)
Liked 7,601 Times
I like bike
Bikes: Roubaix Comp 2020
Quoted: 267 Post(s)
Liked 283 Times
This plus top pros doing it is all the evidence I need. But doing it myself the difference is obvious. I had a 92F humid ride yesterday and it felt like 70s to me with the extra water cooling.
Liked 7,601 Times
Likes For tomato coupe:
I like bike
Quoted: 267 Post(s)
Liked 283 Times
Only absolute idiots would forego drinking. Let's stick to reasonable hypotheses.
Liked 7,601 Times
If no one should forgo drinking, then your initial post is just stating something that's been known for centuries -- evaporative cooing is an effective way to lower body temperature. Do it if you have extra water after you are finished drinking.
I like bike
Quoted: 267 Post(s)
Liked 283 Times
BTW I looked again for studies, here's one not of athletes but it shows that self-dousing in really hot weather lowers heart rate by 5bpm and halved the perceived discomfort: https://jamanetwork.com/journals/jam...rticle/2752456. Here is one about workers obtaining a measured advantage from wearing water-soaked T-shirts: https://www.frontiersin.org/articles...medium=twitter. When I do yard work in 90+F weather I have a special shirt I soak and put on. Its awesome until it dries and I hit it with the hose soon after.
Liked 7,601 Times
BTW I looked again for studies ...
I like bike
Quoted: 267 Post(s)
Liked 283 Times
Yes but I wonder if people are thinking that drinking and sweating is just as good as drinking plus adding some extra water on top.
Liked 7,601 Times
Putting a piece of wet sponge or even a cloth rag in the helmet can help keep the head a little bit cooler. It will do nothing for the reflected radiant heat from the pavement and that is what is doing the most to heat the rider and not the ambient air temperature. In a room if one stands close to a wood fire they will feel considerably hotter and this is from the radiated heat. In Arizona where so many died the ambient temperature was at 120 degrees but the surface temperature of the pavement was 170 degrees. With the poorly insulated homes with single pane windows in Arizona the indoor ambient temperature could be at 75 degrees but the radiated heat from the walls, ceiling, and windows could be greater than 120 degrees for the occupants.
When I lived in southern California my riding during the summer months was at night when it was cooler and now sun rays to contend with in terms of body temperature or increasing my risk of skin cancer. Drivers tend to be less harried and less aggressive in the evening hours after the end of the commute period.
I like bike
Quoted: 267 Post(s)
Liked 283 Times
Re: evaporative cooling, any evaporation will help cool from any kind of heat (it is an endothermic reaction) so it should still help with radiant heating. In the east I think the radiant heat is relatively less of an issue compared to the west, it doesn’t get quite as hot but we have much more humidity so 90F air alone can be extremely annoying. I plan most of my routes on wooded roads so I am maybe a third of the time in the sun on average.. another way to stay cooler.
Putting any kind of water-holding sponge or towel etc on seems like it would also help with cooling, I personally prefer with the super tight bike outfit how the evaporation is less than a mm from your skin so there is less insulation from the cooling, you get nearly all of that endothermy cooling your core. But you have to continually re-ante on the water coating.
don't try this at home.
Quoted: 988 Post(s)
Liked 534 Times
Here in the midwest, one of the nice things toward the end of a hot ride is having more water remaining in the bottles than I will want to drink. A quick squirt on my knees and left forearm is so refreshing in the airflow as I ride along. It only lasts 30 seconds or so, and doesn't solve the hot weather problems, but I like it. That's why I top off both bottles at the mid ride store stop -- I won't drink both of them in the last 20-30 miles. I like having extra.
Winter tights on a warming day: if the ride gets a lot warmer than I originally expected, splashing water on the knees is very cooling. (It lasts longer than the summer bare knees splash too)
Quoted: 919 Post(s)
Liked 2,107 Times
I'm often wearing sun sleeves on hot sunny days; a bit of water squirted directly to the sleeves feels super cool for a few minutes, as it evaporates. Obviously only done when water availability is not an issue.
On hot days I wear a cycling cap under my helmet to keep sweat out of my eyes. I've found soaking the cap in water is nice, as well. Typically I've done that at a stop, not while riding.
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2723 Post(s)
Liked 6,036 Times
Most bikes can hold two water bottles, so those would be good simply for hydration. For cooling, partially freezing a third bottle and putting it in your middle jersey pocket would provide a bit of cool as well as water for your head. read under Marginal Gains (Josh Poertner), the third bottle would add a bit to being more aero IF you are taking an aero position on the bike. Extra weight might be a slight penalty,
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Quoted: 833 Post(s)
Liked 1,979 Times
On one uncharacteristically hot beach ride a few years back, I was overheating and in danger of heat exhaustion.
At Seal Beach in SoCal there are outdoor showers for the surfers and swimmers.
With my full kit on, I showered with the cool water and that saved the day.
Quoted: 377 Post(s)
Liked 444 Times
Thanks for this thread, scottfsmith. I've noticed this summer that, riding during the hottest days, I find myself slowing down, feeling weaker, and becoming more irritable. Reserving one bottle for splashing water on my head and back would probably have helped immensely. I'll try it during my next ride when it's an over-eighty-degree day.
I usually return from a four-hour ride in the heat having drunk all of one 24-ounce bottle of water and a few ounces of another, so I'm probably not drinking enough. But even if I were to use up both bottles by drinking and wetting my helmet and jersey, I could always plot a course that brought me past a convenience store where I could buy another bottle of water before the second bottle is empty.
IMO, you're crazy in the head. I'm not a doctor, but you could be flirting with some serious health issues if you ride with the type of fluid and electrolyte deficits you're talking about.
I'm serious. You could die.
Super-duper Genius
Quoted: 768 Post(s)
Liked 984 Times
I said further up in this thread that I prefer to drink my water rather than spray it on my body. (I'll spray some on my face if I have plenty.)
But there's a third option I find useful, similar to Calsun 's suggestion to use a wet sponge or rag in the helmet. I have a thin scarf with highly absorbent gel beads sewn into it. I don't remember who makes it, but it's a commercial product, not just a DIY. I leave it soaking for a few hours before a ride, then take it along in a ziploc bag. About mid day or whenever I start to get hot, I can tie it around my neck. It helps a little, by cooling through evaporation and transferring that effect through my neck, where lots of blood flows. Because the beads hold much more water than a plain fabric scarf, it is effective much longer.
I like bike
Quoted: 267 Post(s)
Liked 283 Times
I just did a ride in 95F and I hardly sweated at all. I hosed myself down before starting and kept myself continually drenched.
Liked 12,255 Times
This is why, when I overheated on a ride and someone offered me water to drink, I asked her to pour it on my head instead.
Bikes: Litespeed Firenze, Spot Acme, Specialzed S Works Pro Race, Davidson Stiletto, Colnago Superissimo
Quoted: 147 Post(s)
Liked 324 Times
Interesting topic.
Here, our heat is combined with low humidity, e.g., hottest day this year was 106 and 20%. Riding in that I sweat so much I can't keep up with the drinking side of things and will use all of two bottles, water and some kind of sports drink. There's nothing extra to dump on myself.
Good way to monitor if you're drinking enough is a before and after weight comparison. Water is a little more than 1 pound/pint, if you've dropped several pounds then you need to drink a lot more.
Was surprised to learn during the Tokyo Olympics that warm water distance swimmers must be monitored for heat exhaustion/stroke. Lucky me, I'll never need to plan for that.
The Wheezing Geezer
Bikes: 1976 Fredo Speciale, Rivendell Clem Smith Jr., Libertas mixte
Quoted: 427 Post(s)
Liked 1,010 Times
I used to wet down my denim vest for AC on my motorcycle - works great. But to ride across Phoenix on a hot summer afternoon required head-to-toe, full clothing soak-downs with a hose, at one end of town, and a refresh at the other end an hour later.
I absolutely agree with the OP about the effectiveness of smart external coolant application. On my bicycle, I've long spritzed my ears for comfort, and if I start getting seriously hot, do exactly as the OP says, pouring some down the back of my head.
On a really hot day yeah a wet jersey will keep you cooler and should dryout quickly so you don't get swampy. However the better play for most rides unless it's serious hot is just a cold towl on the neck
