Which international (Europe bound) airlines allow the plastic bag bike as luggage?
That center support is smart. I'll have to remember that. Even better if the parts for such, can serve another purpose on the tour. I think my folder seatpost and seat, over 60cm, would be too long, otherwise I could use that and fab a flat part and plug to fit in the lower end.
Bikes: Corvid Sojourner, Surly Ice Cream Truck, Co-Motion Divide, Co-Motion Java Tandem, Salsa Warbird, Salsa Beargrease, Carver Tandem
Quoted: 534 Post(s)
Liked 435 Times
To be clear…I have4 bikes with S&S couplers and 4 S&S suitcases and my goto bike travels packed in those but this case is for two touring bikes I left in Europe years ago and I want to bring them back hone
https://www.welovecycling.com/wide/2...ing-your-mind/
https://www.rossmancycles.com/rinko
https://www.bantambicycles.com/blogg...ko-vs-couplers
That last link says that rinko will not get you below max checked bag size for airlines, but the airline may fly bikes as oversize without extra charge (although perhaps only one per passenger), and rinkoed, they are certainly easier to carry than full-boxed bikes.
Bikes: Custom built LHT & Troll
Quoted: 877 Post(s)
Liked 155 Times
For me, Rinko is the way. Thing is, reading this thread raises the question of conformity. Transparent plastic bags used to be widely accepted, now boxes are becoming officially mandatory for most if not all airlines.
I am not worried about damages to the bike - our bikes are old school steel tanks and cardboard provides marginal additional protection over padded bags as illustrated by anecdotes in this thread.
But I start to worry about the possibility of being denied boarding by a zealot who believes in the sanctity of the rules book. I'll read again this and other threads because I don't recall instances of actual denials. But if this were to be a thing, it would mean more time and energy for little if any gain.
[re-read this thread - no mention of denial; googled and nothing came back]
I think rinko, in combination with an airline that is bike-friendly (no oversize charge), should mean it gets accepted. If not, you can politely and nicely say you packed it down small to take up less space, versus putting it in the typical bike box, which takes up a lot more room, and you did this to be considerate of others, because you would not have been charged for the large bike box. Put on your friendly face and communicate only the best of intentions.
Quoted: 9 Post(s)
Liked 6 Times
My worst experience was not with an airline but TSA in the US. They ripped my carefully packaged bike box open and of course didn't make any effort to repack it properly, so just shoved it all back in with half the bike sticking out and a few bits of tape and TSA stickers holding it together. When I went to complain and ask how to claim compensation if anything was damaged they laughed and gave me a piece of paper that basically said that under some terrorism act they can pretty much do whatever they like to luggage, with no recourse
Quoted: 3522 Post(s)
Liked 1,499 Times
If your goal is to minimize packing duties, check if Air Baltic flies on your route. A few years ago I needed no packing at all - my bike survived it completely without a problem.
S.
S.
Write a letter to your congressman. They get flooded with e-mails because computers can easily generate them. Letters have to go through screening first (do not include white powder), so letters are not handled quickly either, but probability is high someone will actually read it.
aka Timi
Bicycles are accepted for transportation with the pedals removed, handle-bar turned and tires deflated. Maximum weight: 25 kg.
Some airports require that bike must be packed in a hard protective case or box, which is meant for transportation of bicycles. Cardboard bike boxes are sold at the airports. Please note that if your bike is not packed appropriately, the airport may not accept it for transportation. Please contact airport for more details
Likes For simonthread:
Quoted: 9 Post(s)
Liked 6 Times
But it does raise the interesting argument that if it is not packaged well and they can clearly see that it is fragile they will handle it carefully, whereas if they just see a big solid box they will chuck it around
luck of the draw I reckon, not to mention stuff can fall off conveyor belts all by themselves, no humans involved.
Yes, i am in Australia. This happened a few years ago and as my bike was undamaged and I was at the end of my trip and going home soon I didn't take it any further.
If I ran the world, I'd have inspection be first right inside the doors, then have a secure area downstream with tables for people to repack, or take down or fold their bike there for packing, then directly to airline baggage check. The problem is the airline ticket counters are first, where they take checked luggage, and then that is screened somewhere in the bowels of the airport, while you then proceed to security check of you and your carryon baggage. This is stupid. Screen everything first, with the passenger there to undo any locks, repack, etc, proceed to checkin and baggage check or directly to departure gate. Not that hard to figure out, if they wanted to make things better.
Honestly, I wish it was like in the soviet union, they didn't have baggage handling systems; You brought all your luggage to the gate, and handed off directly to baggage handlers, or, on some soviet aircraft, you brought it all into the passenger compartment and it was lowered by hand into the cargo space space below; From wiki for IL-86:
The Soviet solution to the airport capacity issue involved passengers loading and unloading their own luggage into and from the aircraft. This was eventually called "the luggage at hand system" (Russian transliterated: "sistyema bagazh s soboy"). Soviet aviation journalist Kim Bakshmi described it (at its ultimate) thus: "One arrives five minutes prior to departure, buys oneself a ticket on board the aircraft, hangs one's coat next to the seat and places one's bag or suitcase nearby.".
Taking suitcases into the cabin, as in trains, was studied, but necessitated a 3 m fuselage extension with a 350-seat capacity. To avoid this, passengers were to deposit their luggage in underfloor compartments as they entered the airliner.
aka Timi
Possibly, but that question becomes irrelevant if the airline refuses to take your bike because it's not in a suitable box as specified in their baggage policy... One hour before check-in closes, what will you do with your bike then?
this is all that matters, what a specific present or current airline policy is.
My perception is that Emirates has been rapidly expanding as much as possible in the past decade, well beyond their traditional routes, and that may mean they are trying harder to accommodate passengers. Other large corporations, when in growth mode, seemed to try harder, only later when their growth leveled off and management and/or stockholders demanding higher profits, did they start cutting corners in service and benefits, like going cheaper on flight meals or eliminating them altogether, charging for checked luggage, etc.
Bikes: 1974 Masi GC, 1982 Trek 728 (aka 720), 1992 Trek Multitrack 750
Quoted: 123 Post(s)
Liked 225 Times
I'll be flying Condor Airlines in a few months: LAX to Frankfurt. I'll be taking a Bike Friday folding bicycle and using their canvas bag.
From https://www.condor.com/us/flight-pre...-equipment.jsp :
"....bicycles are only transported packed. We recommend bicycle cases or bags as packaging"
"Dimensions: max. length 200 cm x width 40 cm x height 100 cm or length 300 cm x width 40 cm x height 60 cm. Anything higher, longer or wider must be registered with customer service (phone / WhatsApp).
Weight: up to max. 30 kg."
I like Condor's new livery design (broad vertical stripes in various colors against white backgroud), high visibility and fashionable in a J. Crew catalog kind of way.
Quoted: 123 Post(s)
Liked 225 Times
Funny you should mention that (the new livery designs). Half way through the flight the captain got on the horn and announced that they were celebrating their 2 year anniversary of the new livery. In celebration they were offering savings on their in-flight catalog merchandise of up to 30% off. It includes cosmetics and cigarettes. I just found it kinda weird that the person flying 260 souls across the Atlantic was hawking cosmetics and cigarettes over the P.A. Then came the flight attendants wheeling their carts stacked high with cartons of cigarettes. 49 Euros a carton, good deal, I guess.
