On the Road Again Project Challenges - Again
Bikes: 2017 Sage Skyline, 2015 Co-Motion Periscope Tandem, 2012 Soma Smoothie, 2006 Kona Jake, 1978 Richard Sachs, 1977 Peugeot UO18c, 1977 Peugeot PRN10, 1974 Allegro Schweitzermeister Model 76, 1972 Hugo Rickert Spezial, 1971 Fuji Finest
Quoted: 120 Post(s)
Liked 638 Times
From the frame up Fuji Finest
This project started after I acquired a mystery frame from my friend Addison after he closed the Bicycle Repairium in Sacramento. There was a thread on this where the BF hive mind helped me identify the frame as a June 1971 Fuji Finest.
This is a true from the frame up project after I stripped it down to bare metal and have been acquiring parts and building it up. Spent the last couple of weeks building wheels for it, painting the frame and applying period and model accurate water slide decals from Gus Salmon. Letting the decals cure for a few days and then it is time for the 2k clear coat. Here is a sneak preview:
Frame as received from Addison.
After media blasting.
Found a head badge that matched the rivet holes in the head tube
Tracked down a Fuji branded Belt saddle
Some assembly required!
Primer coat done!
Finished the wheel build.
First coat of paint.
Hade enough left over to paint a matching set of fenders.
Primer coat done!
Edumacator
Quoted: 2533 Post(s)
Liked 3,352 Times
Awesome job on that Fuji!
1987 Crest Cannondale, 1987 Basso Gap, 1992 Rossin Performance EL, 1990ish Van Tuyl, 1985 Trek 670, 2003 Pinarello Surprise, 1990ish MBK Atlantique, 1987 Peugeot Competition, 1987 Nishiki Tri-A, 1981 Faggin, 1996 Cannondale M500, 1984 Mercian, 1982 AD SuperLeicht, 1985 Massi (model unknown), 1988 Daccordi Griffe , 1989 Fauxsin MTB, 1981 Ciocc Mockba, 1992 Bianchi Giro, 1977 Colnago Super, 1971 Raleigh International, 1998 Corratec Ap & Dun, 1991 Peugeot Slimestone
Quoted: 2622 Post(s)
Liked 3,162 Times
Well I finished hooking it up and it stops the bike, so I guess I'll stick with it for now. I am not sure I want to go the centerpull route it would just look even funnier to me.
My next question is, what common vintage rear derailleur can work with a 9 speed cassette? I tried a cyclone mk-II long cage and it only goes up to the 8th cog (2nd gear). I think the cable is tight enough, and the adjustment screw is all the way out. The shifter is a Shimano BS50 in friction mode. I have a deore dx somewhere, would that work? Or is it the shifter? This is actually the first time I've tried anything over 7 cogs, so I've no clue.
Alternatively, if I use a smaller cassette such as a 7 or 8 speed, would I need to stick a spacer on the hub? Or no?
An easy test: with the bike on a repair stand, turn the cranks with your right hand while pushing the bottom of the rear derailleur parallelogram inward with your left hand. With the inner-limit screw backed out all the way, the chain should easily reach the cassette's largest cog. (Be careful not to overshoot and push the chain into the spokes!)
If the chain does indeed reach the largest cog, that tells you that the problem would likely be solved by replacing the index/friction shifter with a shifter from the pre-indexing era.
Quoted: 3871 Post(s)
Liked 3,468 Times
one can only wonder how the heck they got him mounted up thar!
unlikely to have been helicopters extant at that epoch...
perhaps ein kranischer gigante
Liked 3,468 Times
I'm thinking of participating in this challenge so I started looking for suitable candidates. I came across a FB Marketplace ad for a "Burleigh road bicycle". I've come up empty trying to find information on this bike. Has anyone ever seen or heard of this bike before? Is it bike shop quality or was it sold at Toys R Us in 1970s? It appears to have a lugged frame and there is a downtube sticker that says "Chrome Molybdenum".
Here are a couple of images from the ad:
Ach Du lederkrans!
Krautkraft im farben.
Perchance a perpetration of someone such as Kalkhoff...
Bikes: There is always room for one more.
Quoted: 191 Post(s)
Liked 401 Times
Tearing Down the Ross
I dismantled the Ross yesterday, cleaned the frame and components and applied a light coat of boiled linseed oil to the frame this morning.
Ross frame and fork wiped down with boiled linseed oil.
No polishing - just a basic cleaning.
During the tear down I determined a new headset, chain and rim strips were needed. Mucho Cheapo of course. I would normally opt for rim tape but there is that budget to consider.
Expenses so far:
Mucho Cheapo Ross - $10.00
Mucho Cheapo Neco headset - $9.90
Mucho Cheapo 7-speed chain - $9.96
Mucho Cheapo Amazon rim strips - $7.49
Mucho Cheapo expenses to date - $37.35
Expenses so far:
Don
Don
Likes For GeezyRider:
StillNewbieButInGrey
Bikes: 1982 Austro Daimler SLE, Eastern Alpaka 29er
Quoted: 116 Post(s)
Liked 207 Times
Can I play? Frame up.
Started with 1982 AD SLE frame and fork with Tange headset.
Has shimano Hubs, freewheel, RD,crankset, BB,chainrings, brakes, levers,and shifters.
Suntour ARX FD
Araya rims
BELLERI St. Etienne Bars with ATAX quill stem.
Galli Mallard pedals
Continetal ultra sport tires
ANPI seat post.
Suntour ARX FD
Araya rims
ANPI seat post.
Likes For Strawbunyan:
Bikes: Raleighs (International, Super Tourer, Gran Sport, Super Course), Miyatas (610, Alumicross), Bianchi Eros, Fuji Cross Pro, Lotus Excelle, Paramount Series 7 Carbon, Univega Super Strada, Wheeler Tremosine,
Quoted: 22 Post(s)
Liked 60 Times
re (It started with a part) I just had-to-get one of those 3-pulley derailleurs last November!
Likes For darnet:
Bikes: Bicycles? Yup.
Quoted: 502 Post(s)
Liked 1,676 Times
Yup, the 2024 build is going to be weird, since it started that way.
A Swedish bike with French BB and ISO steerer. High quality tubes (Vitus 971) and lugs, yet crudely assembled.
The horrible paint removal of this tough stuff is nearly done. Next is the braze-ons; bottle cage mounts, shifter bosses, cable stop under the chainstay, and housing covers for internal routing of the rear brake cable.
Cresent Pepita 318
Cresent Pepita 318
Likes For BTinNYC:
PeopleCode delaminator
Clarification needed...
I've stalled out on this heap over multiple Clunker challenges:
The frame was picked out of a trash heap and the wheelset was $25.
EDIT: While I think I can bring it in under the mucho-cheapo budget the result will fit MUCH better in Frankenbike
Likes For RandolphCarter:
Quoted: 22 Post(s)
Liked 60 Times
I'm in! I guess I'll go for the "mucho cheapo" category again, although I'm going to feel a little bad because I know I'll be replacing some stuff with parts that have been in my possession for quite some time which adds $0 to the total.
Anyway....
I picked up a Motobecane Grand Record at the local bike thrift store a a couple weeks ago for $37.50 ($35 plus tax).
As purchased, loaded up at the thrift store:
Here is a "before" pic:
The only thing I've done to it up to this point was air up the extremely dry rotted tires and rode up and down my short driveway a couple times. I also gave hardware and some components some lube, in preparation for teardown during The Challenge timeframe. I'm happy The Challenge has begun, because I've been itching to get working on this.
I began disassembling some things today, the rack was the first thing to go!
Anyway....
Looks a bit like a bike I found last fall at my town's transfer station re-use table (except for it's a Huffy; might be my ride this year). Pics as-found, plus bonus pic of re-use table from up above....
Likes For darnet:
Bikes: Aluminum and Steel
Quoted: 124 Post(s)
Liked 441 Times
Why not… 1974 Schwinn Continental. Picked it up for $13. Was supposed to be a quick flip. The snowball started rolling with the chrome fork crown cap. The original was cracked. I found one on ebay. I paid a ridiculous $30. Evaporust, Bar Keepers friend, Flitz, clay bar, rubbing compound, liquid carnuba wax, new decals, Schwinn cables/housings, Hunt-Wilde bar tape, etc. I stopped keeping track after $100. Restoration? Close to being on the road again. The most over restored Schwinn on BF for the year award?
“Ride like the wind boy! Ride like the wind…”
-The Voice inside my head, circa 1982
Likes For IdahoBrett:
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 544 Post(s)
Liked 1,071 Times
I wish they had something like that where I live. The closest thing would be the people who set things out by the road a few days before trash day. The township has a large item collection a couple times a year, but everything goes straight in a dumpster. They have one for metal and another one for everything else. A couple weeks ago I was going past the township building while they were having a collection and I spotted a girl's bike hanging off the back of a truck as they turned in. A couple hours later, I was buying one at a flea market to fix up for my niece. It was a '92 Schwinn CrissCross for $20. I was scrambling to get it finished in time for my next trip over there and forgot to get a picture.
Likes For Pompiere:
Likes For BTinNYC:
Señor Member
Quoted: 1511 Post(s)
Liked 1,131 Times
Señor Member
Liked 1,131 Times
That's not the absolute best condition that I've seen one of those in, but it's close to it.
Likes For USAZorro:
Quoted: 120 Post(s)
Liked 638 Times
More Progress on the Fuji Finest
Frame is now ready for the build. In checking the frame before the final polish, I found that it needed to be cold set back to 120 from 126 and the hangar needed to be aligned. Pretty happy with how it came out. I’m no Jack Trumbull but this came out pretty sharp for a rattle can job. Good prep and a lot of sanding makes all the difference.
Likes For Sactown_Albert:
Quoted: 191 Post(s)
Liked 401 Times
Don
Don
Quoted: 120 Post(s)
Liked 638 Times
Quoted: 124 Post(s)
Liked 441 Times
I'm not certain if it is an artifact of the camera angle, or whether it's the positioning of the cap, or if the fork is truly a bit cock-eyed, but if you haven't already measured it, it couldn't hurt to check it.
Awaiting shipment of the last part. Some more housing for the derailleur cables. No pics from today. But I did set up the brakes. Then I realized I shoulda put the rear rack on first. Oops.
A full body shot from the other day just because:
The Huffmeister
Bikes: '79 Trek 938, '86 Jim Merz Allez SE, '90 Miyata 1000, '68 PX-10, '80 PXN-10, '73 Super Course, '87 Guerciotti, '83 Trek 600, '80 Huffy Le Grande
Quoted: 1300 Post(s)
Liked 3,759 Times
Wow, that turned out freakin' nice!
There were 135 Confentes, but only one...Huffente!
Likes For AdventureManCO:
Quoted: 22 Post(s)
Liked 60 Times
Our small town does not provide for trash pickup. We bring ours to the town dump (transfer station).
We were once featured in a New York Times article!! https://www.nytimes.com/2007/11/13/us/13dump.html
Back then, the re-use table was up top on the same level as the other disposal and recycling. After the table caught fire, they moved it to the area down below.
Señor Member
Liked 1,131 Times
Actually, the cap was what I thought was most likely. Hope that's what it was.
Likes For USAZorro:
