Vintage Peugeot
Bad example
Quoted: 898 Post(s)
Liked 425 Times
markk900 I sympathize with you, I'm cheap, and my blue Peugeot is cheap. I decided that the most fun part of the project is doing all the work myself and learning some new things. The bike has plenty of other work that needs to be done in the mean time.
I hope to work on the bottom bracket tonight. A work buddy who is into vintage Italian bikes loaned me a bottom bracket tool.
Likes For Aubergine:
Quoted: 486 Post(s)
Liked 664 Times
edit: I am assuming what RustyPeugeot meant by “bottom bracket tool” was in fact a crank arm puller: most of the SR cranks I have worked with came off just fine with a Campagnolo puller.
Likes For markk900:
1. Good news is I got the cranks off and opened up the bottom bracket.
2. Cleaned the cups and greased the bearings.
3. Got it back together. Snugged it up so there was no play on the shaft, but spins freely.
4. Bad news is there isn’t enough threads on the cup to screw the lock nut back on.
I’m guessing that means the bearings, shaft, or cups are worn out and need to be replaced.
Likes For RustyPeugeot:
Quoted: 486 Post(s)
Liked 664 Times
I suspect it means whoever did the conversion to cotterless cranks used an axle that was too narrow. That’s likely why there was play in the bottom bracket.
You’ll need to take it apart again to measure the axle, and then find one that is longer (measured between the flanges where the bearings run). In the photo below you can see two axles I have used in Peugeots; they both measure 51mm to the outer edges of the bearing flanges; but they are slightly different in other dimensions (thickness of the flange etc).
Quoted: 486 Post(s)
Liked 664 Times
Found this picture of the key dimensions:
I also noted a good selection of inexpensive options online….lots of 3SS with 52mm ‘B’ dimensions which should work for you.
Likes For markk900:
markk900 thanks for helping. Last night when I was working on it I was thinking the axle was too short and they messed up the conversion.
Since I’m new to working on these old Peugeot bikes, what is the best website to purchase axles from?
I guess I could also go with a sealed bottom bearing bracket.
Quoted: 486 Post(s)
Liked 664 Times
No special website - the crank axle is not a Peugeot part nor is it proprietary. Depending on your measurements I saw them on Amazon, and a few bicycle suppliers online. You want a JIS taper as the cranks are SR (Japanese) not anything French.
One of the axles I showed had the following dimensions: A and C = 36mm, B=52mm (I mismeasured the first time),D = 124.5mm. You can probably get away with a non-symmetrical axle as well with A being 35mm and C being 37.5mm and it should work (longer side holds the chainwheel crank). Look for 3SS or 3S axles and see what you can find. Also check Sheldon for some good background info on axle sizing. https://www.sheldonbrown.com/bbsize.html
You can check with your current axle: how much of a gap between the crank arm and the bottom bracket cups on each side. That will give you an idea of how much tolerance you can afford for the A and C measurements (take into account the arm has to clear the chainstay on the NDS, and the sprockets have to clear the DS stay.
You can indeed also upgrade to a sealed bottom bracket but I have no experience of doing that.
Bad example
Quoted: 898 Post(s)
Liked 425 Times
Rusty, I use sealed BBs from Velo Orange on many of my French bikes. They work very well, although they are not exactly cheap. I think Shimano offers a French threaded BB as well that probably is cheaper.
Quoted: 486 Post(s)
Liked 664 Times
Aubergine : I had a look at the VO site and the sealed bb is much more reasonably priced than I expected. However in the reviews I saw mention of people using 107mm spindles for UO-8s. That seems awfully narrow to me - what have you used? I would have expected to use a 118mm at least.
Bad example
Quoted: 898 Post(s)
Liked 425 Times
Measured the bottom bracket axle tonight. I’m confused what’s going on, so hopefully you guys can help.
The axle has 3S stamped into it.
A = 35mm
B = 52mm
C = 38mm
D = 124.5mm or 125mm
The bottom bracket on the bike frame is 68mm.
The lock ring is about 4.5mm.
It’s like I need B to be 5mm or 6mm wider so there will be some threads to secure the lock ring down.
The adjustable cup on the non-drive side does seem a little worn inside. So a new cup might help too. I’m guessing it is French thread, but I have no idea how to tell.
I don’t want to make a mistake and order parts that won’t work.
I also have not removed the fixed cup from the drive side. I need a bigger wrench or special tool.
A = 35mm
B = 52mm
C = 38mm
Quoted: 486 Post(s)
Liked 664 Times
I’m confused too, as that axle with those dimensions worked fine in my own Peugeot when I was running cotterless.
Dumb question but are the bearings in the right way round? I did some looking and apparently the 9-ball caged bearings go the opposite to the 11-ball caged bearings (see Caged bottom bracket bearing direction.), specifically JohnDThompson ’s comment:
“9-ball retainers generally have the open side facing into the cup. 11-ball retainers have the open side facing the cone on the spindle.”
Since from the photo you have 9 ball caged bearings, and the one in the cup is the opposite to the one still on the shaft, try putting both bearings open side out….. couldn’t hurt!
Likes For markk900:
OK I flipped the sealed bearings around and it fits and there are enough threads to put on the lock ring. However the bearings are not smooth. If I loosen the adjustable cup to make the bearings smooth, then there is play in the axle shaft.
Maybe new bearings are worth a try.
Quoted: 486 Post(s)
Liked 664 Times
Glad to see mystery number 1 is solved. I think you might want to just go to uncaged bearings since as you pointed out they’re cheap and I think work better than caged.
Also sometimes there is a fine line between no play and roughness in the bearings: especially when you go to tighten the lock ring. It’s been many the time I have fiddled with adjustable cups/wheel cones and locking rings to get it just right. Try leaving just a smidgen of play in the axle before doing up the lock ring (or conversely “loosen” the adjustable cup against its lock ring).
Likes For markk900:
Bad example
Quoted: 898 Post(s)
Liked 425 Times
My preference in any case is to use loose bearings because you can add a couple of balls. The extra balls make the mechanism stronger and smoother. I use 11 1/4 inch balls on each side. Sheldon is helpful: https://www.sheldonbrown.com/tooltips/bbadj.html
Aubergine I think you might be right about the caged bearings causing the binding. I ordered some ball bearings last night, so hopefully that resolves the problem. If not, I think I need to purchase some new bottom bracket cups, but I have no idea what size they are or where to source them from.
Edumacator
Quoted: 2544 Post(s)
Liked 3,369 Times
1987 Crest Cannondale, 1987 Basso Gap, 1992 Rossin Performance EL, 1990ish Van Tuyl, 1985 Trek 670, 2003 Pinarello Surprise, 1990ish MBK Atlantique, 1987 Peugeot Competition, 1987 Nishiki Tri-A, 1981 Faggin, 1996 Cannondale M500, 1984 Mercian, 1982 AD SuperLeicht, 1985 Massi (model unknown), 1988 Daccordi Griffe , 1989 Fauxsin MTB, 1981 Ciocc Mockba, 1992 Bianchi Giro, 1977 Colnago Super, 1971 Raleigh International, 1998 Corratec Ap & Dun, 1991 Peugeot Slimestone
Likes For jdawginsc:
I'll post some photos when I take the thing apart to put in the loose bearings.
So where does a guy buy new bottom bracket bearing cups for his early 1970's Peugeot UO-8?
Edumacator
Liked 3,369 Times
From another UO-8 mostly. Haha. Those things were tough though. A little cleaning and judicious use of an abrasive will make them serviceable...probably.
Quoted: 486 Post(s)
Liked 664 Times
I honestly would be surprised if the cups are worn: I have seen them badly corroded but not worn out. And yeah another Peugeot is the best source.
However I should add that the cups are somewhat standardized (standards are great when there are so many to choose from) so if you really want replacements they don’t have to be Peugeot. When I put my Sugino crank on my Peugeot back in 1974 I bought cups with it.
I believe (someone correct me if I am wrong) that the 35xP1 is the correct type for Peugeots of the early 70s.
Likes For markk900:
Awesome guys, this is what I was looking for. haha. I have two rusty UE-18s that I might be able to pull a cup from. They have the cotter pin cranks though, so not sure if they would work.
Bad example
Quoted: 898 Post(s)
Liked 425 Times
Yeah, they were tough. The French usually used decent equipment on their bikes, outside of those Simplex front derailleurs. If you decide you do need new cups, I'll send you a couple that I snagged from an old French bike,
