Racer Tech Thread
#5876
Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,569 Times
Got it fixed. Finally no spacers in the crank shaft to avoid hitting the brake. Found a used direct pull. I have the bike as 1x so utilized the spare cable exit to route the brake that way. Reversed the side the pull acts from. Bingo.
Also, the Selcof pdq bars are on. The comfort change of the bull bars alone was worth it. Also, now instead of a fixed position I have adjustable parts. I also now own each stem length possible for a Bayonet system.
Next step is to ride it and adjust accordingly.
Pics after I ride it and confirm it works.
#5877
Nonsense
Bikes: Affirmative
Quoted: 880 Post(s)
Liked 541 Times
Yes. Love it so far.
I have a Red 22 carbon 165mm GXP arms paired to P2M NGeco crank, BB30 in my new S-Works Roubaix....what to do?
Popped out the CeramicSpeed BB30 bearings, pressed in the BBInfinite GXP/BB30 adapter, spins like mad. No creak, no fuss.
I even ordered the wrong one at first, got a no questions asked refund and relatively quick replacement of the right BB.
#5881
Globo Gym lifetime member
Bikes: Fast ones
Quoted: 410 Post(s)
Liked 614 Times
It takes a pretty good whack or two to get them out. I wouldn't heat it all because it's a Madone (bearings mounted directly into the carbon shell).
#5882
Just call me Carrie
This thread turned up when I searched for "trainer tires" I'm sure somewhere in the past 236 pages, someone mentioned them.
I need to swap a trainer tire onto 700cc rims and get my bike into the CyclOps trainer. What tire should or shouldn't I use?
Likes For topflightpro:
#5885
Just call me Carrie
I don't have any currently. At least, not in the size I need. I'll check out the orange contis, thanks.
#5886
Newbie racer
Liked 1,569 Times
I want to upgrade/consolidate my wheelsets. I'll start by posting the "inventory":
-Renn disc, 11spd conversion, tubular, 23mm Corsa Speed tire
-HED trispoke all carbon, front tubular, 19mm track Vittoria on it
-Giant PSLR-1 wheelset, 11spd conversion, clincher, 4000s2's that need replaced, I think in 46mm, probably 2012 vintage
-Giant PA2 alloy wheelset, round spokes, I think 35 or 38mm, clincher, 2015 model year, I think about 23mm outside width? maybe 25mm
-Velocity USA A23's in a seemingly narrow width on the cross bike, looks like a Clydesdale build.......my cross bike was owned prior by a guy around 90kg
For now, I'm thinking of keeping the TT bike disc/trispoke. For good days and good pavement at my weight/speed that setup is fast AF for the money.
Money wise, none of it is worth a lot. The PA2's are 16/24 I think, which to me is too few for cross/gravel use on the front wheel.
Enough for all three of those sets..........I'd probably buy a set of brand new Jet 6 HED's and a brand new set of "chinabay" deeper section cross/all arounder wheels. I'd even be OK with a 20 count up front, that's the count that bothers me about the PA2's to convert their usage.
The reason for not keeping the PSLR's would be the tire sizes, I want to try out 25mm tires. All that CRR and comfort stuff. The PSLR's can certainly run them, but they're not optimized for that whatsoever. The reason on the Velocity wheels is wheel width and volume.
The only requirement here would be that I'd keep one setup for road, and one for off road. Also, I could maybe get the all-arounder off road setup TL. I'd love that. Kinda tired of getting flats on gravel and bumpy stuff on clinchers.
What would you do with that "stable"?
#5887
Quoted: 4273 Post(s)
Liked 2,995 Times
I'm assuming you're not also changing bikes, so even your gravel use would be with rim brakes?
#5888
Version 7.0
Bikes: Too Many
Quoted: 1362 Post(s)
Liked 2,521 Times
Money wise, none of it is worth a lot. Maybe $100 for the Velocity set. Maybe $200 in the PA2's. Maybe $300 for the PSLR's. The PA2's are 16/24 I think, which to me is too few for cross/gravel use on the front wheel.
If I could get the $600 for all three of those sets..........I'd probably buy an $900 set of brand new Jet 6 HED's and a brand new set of "chinabay" deeper section cross/all arounder wheels for $350. I'd even be OK with a 20 count up front, that's the count that bothers me about the PA2's to convert their usage.
#5889
Quoted: 2953 Post(s)
Liked 3,106 Times
#5890
Newbie racer
Liked 1,569 Times
I'm interested in the options of what I could replace them with, not selling them here.
People ask advice about n+1 and n-1 on the types of bikes they own, so why not wheels?
FWIW, the FS section here is so slow, I'd never even really list here anyway. ST and my local FB group is where I'd go for that. It doesn't make sense anyway to not do it local only if they're not worth much and shipping wheels is expensive.
Or........trainer wheels or giving a leg up to a local on the cheap/free
#5891
Version 7.0
Bikes: Too Many
Liked 2,521 Times
IMO, the fastest TT setup in the disc / tri spoke assuming reasonable wind conditions and high performance rubber. For general mass start racing, I like the 45 mm rim depth and 22.5 mm rim width - Specialized, HED, Fast Forward, Zipp and etc. For steeper hill climbs the lighter the better but 45 mm are pretty good and IMO, optimal for most HCs. And one can use the 45 mm for time trials if windy.
IMO, deeper section wheels quickly become the equivalent of having a crooked knife in ones toolbox that is essential when you need it but one does not need it very often. And I do not like heavy wheels per se.
#5892
Quoted: 1853 Post(s)
Liked 680 Times
Honestly, the benefits you'd gain by buying new wheels are going to be pretty small. It's probably not worth the cost or effort to sell and buy new wheels. You can certainly go with wider rims on the cross bike, but just be sure that your bike can run the larger tires. Also, if you really do like cross, what are the chances you upgrade to a disc-brake bike in the near future?
#5893
Newbie racer
Liked 1,569 Times
That's a good point on the disc brake part. People seem to love their disc brake bikes for good reason.
I forgot that. Good point.
The reason I mentioned the 60mm stuff was if it was windy enough I could run the good roadie set on the TT bike in a race also. I'd currently relegate the front to one of the Giant wheels if the pavement was junk or really windy.
But, remembering the cross/disc thing throws a wrench in it. As I've no doubt that disc brakes would eventually be nice since I do like both cross and gravel. Both from a race standpoint and just day to day riding standpoint.
Considering that, I probably would rather send the money over towards that as a project eventually.
See, this is why you don't spend too much free time clicking links and looking at shiny stuff instead of thinking.
#5894
Liked 2,995 Times
#5896
Newbie racer
Liked 1,569 Times
I notice the new shimano RD's go to 11-30 and have the matching cassettes.
It's about time for a cassette/chain on the roadie, not bad, but time to think about it. Is there any logic for someone like me having a road bike I race and do hammer rides with having a 50/34 setup versus a 53/39 or 52/36?
I think the only difference I'd notice is for longer local hills I may need to finally shift into the small ring. Hills here are 3min or less and often not very steep for long. Maybe 9% for a very short distance then overall 4-5%. I usually never leave the big ring on the hammer ride.
You all have more experience in this. Is there any real downhill speed gain, or flat riding efficiency gain?
Why's it matter? Is there something to it, or is it a "my peen is bigger" kind of thing?
I generally spin a higher cadence, which is why I probably don't notice it.
#5897
Version 7.0
Bikes: Too Many
Liked 2,521 Times
burnthesheep I am no longer do mass start races but I do HC races either mass start or time trial from time to time. I have a 50/34 on my road bike and an 11 speed 11/32 cassette. I may switch to an 11/25 for some hill climb like the GMR that has a steady 6% grade or I am looking for a particular gear combination that yields the cadence I want for the speed I can maintain. The only time I would like a 53 on the front is for low cadence interval work on flat terrain and in general, I do that on my time trial bike. Setting up gearing on bikes seems to me race specific if one is going to optimize gearing selection. Big gear in the front and big gear in the back is the lowest friction and least drive train losses.
#5898
Version 7.0
Bikes: Too Many
Liked 2,521 Times
My road bike has developed a clicking sound. I took it to the bike shop and they did a clean, lube check and etc. The bottom bracket bearing are going. The did a re-lube / clean and the clicking sound is less. I had them order an Ceramic Speed bottom bracket.
For training, I ride on GP4000s with light weight Specialized butyl tubes. I purchased some Michelin latex tubes and put them in for yesterdays ride. I thought the ride was much more supple for the same tire pressure. Wattage savings...who knows...probably saved a couple of watts at higher speeds. However, they lose about one PSIG per hour. So there is that.
#5899
Bikes: Fast ones
Quoted: 410 Post(s)
Liked 614 Times
Newbie racer
Liked 1,569 Times
It’s nice. I’m used to a 54t 1x setup on the TT bike so no biggie doing 53/39 on the road bike.
Got a gold chain also, lol. Bling bling.
