#6776
Bikes: 91 Ritchey Ultra, 1992 Specialized Stumpjumper, 1990 Klein Rascal, 97 Trek OCLV9700, 90 Minnelli Eclipse, 95 Marin Bear Valley SE, 1991 Breezer Lightning Flash 1991 Diamondback Axis 1992 Stumpjumper Comp 1983 Stumpjumper Sport
Quoted: 103 Post(s)
Liked 686 Times
Struggled with this seatpost for the last month but today victory was mine. Let the rebirth commence!
Likes For victorm:
#6777
Quoted: 1631 Post(s)
Liked 2,723 Times
Likes For curbtender:
#6779
Thinking out loud, are there small ball homes that would clean up old tubes? I have a wire brush I put in drill to clean them up a bit
"It's a fine line between absolute genius and sheer stupidity"
#6780
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3935 Post(s)
Liked 6,597 Times
Almost completed this Falcon I picked up as a frameset. Right from the start, had sorta a tough time installing the headset when the upper race went on smoothly, but I installed it on the bottom of the head tube. Then it wouldn't go on straight after two attempts.
The 1990 Record rear derailleur is also a bit of a pain to setup. It reaches the big 28t cog of the 7-speed easily, but the low limit screw isn't long enough. This model comes with two different sized limit screws, which is weird to see for this old guy.
Left the brake cables long, which really pains my delicate sensibilities, but I'd like to find some 40cm Cinelli bars so I can use a longer 100mm stem and possibly add some Chorus aero levers.
Likes For SurferRosa:
#6781
Quoted: 4558 Post(s)
Liked 6,519 Times
#6782
Quoted: 1157 Post(s)
Liked 1,828 Times
A cleansing of the brake hoodsand the re-install is complete,and these clips are Christophe that originally had leather, I redid those as well.
Now I need to go to the local tack and saddle and get some matching strap.
Likes For Mr. 66:
#6783
Liked 2,723 Times
#6784
#6785
Just finished today: Colnago
I finally got the white Campagnolo cable and housing set and the white bar tape, so I finished off the red / white color scheme. I think this is going to be my primary distance bike for the near future.
White bars tape, housings, and saddle. gotta work on a different front wheel.
Likes For mgopack42:
#6786
Quoted: 100 Post(s)
Liked 445 Times
The Litespeed Project-continued
Well,
I’ve been working diligently in the Secret Underground Laboratory on the Ti22(my son named it) … We now have a Roller operating at about 10% Litespeed. I’m waiting on the FY ‘24 budget approval for funding for the cassette, chain,cable set, and handlebar tape …
JD, Dallas
2002 Litespeed Arenberg … in progress
JD, Dallas
Likes For jim dandy:
#6787
Liked 6,519 Times
Big silver Merz daily driver with worn out 9 speed Campy, changed out bars, stem, cables, brake levers and shifters to analog for the joy that is Eroica.
Dialed, test ridden, locked, loaded and ready? to roll.
Likes For merziac:
#6788
Quoted: 3466 Post(s)
Liked 2,840 Times
Well,
JD, Dallas
JD, Dallas
#6789
Quoted: 343 Post(s)
Liked 637 Times
Jeunet
I am currently upgrading a vintage 63 cm French Jeunet Franche Comte. 10 speed. Original lime green paint and decals are like new with minimal fading. I upgraded the cottered crank to a Sugino Mightyand the bars and stem to Chinelli. I spread the 120mm dropouts to 126 and the steel wheels were replaced with Mavic open Pro rims, Schwalbe delta cruiser 700 x 28 tires, and an Ultegra front and Dura Ace rear hub. currently I have a 11 x 28 seven speed hyperglide free hub at the back. I took the fork into the Bike exchange Saturday to try and straighten the chrome fork but upon closer inspection realized that the blades weren't bent . it was the steer tube. No way to fix it so I rumaged around in our fork collection and found a new unicrown fork that fits and is much lighter as well. Only problem is that it is red. I decided to paint it silver metalic and did that today. It looks much better that the red one with the lime green metalic. This has brought up a new dilema . The beutiful Mafac brakes from the Jeunet no longer work. I substituted some Shimano RSX dual pivot calipers and now all is good. I will save the Mafac levers, with their excelent condition half hoods for something else. The bike has morphed from a vintage with a few upgrades to now a complete custom. I will probably add aero hoods and bar end shifters to complete the resto mod look.The Suntour arx long cage rear derailleur doesn't like shifting the 7 speed cassette so I may change it out with a shimano rsxand see if that works better. As soon as I have it all together I will post some pics.
News Flash
I also picked up a Bertoni Saturday. curently it is hanging in the garage. will start in on it when the Jeunet is done.
9/19/23
Well, the Jeunet is done.
By the time I finished with it I had replaced everything but the frame . It went from a heavy bike boom drop bar 10 speed to this , a 63 cm, 27.5 lb. classic looking city bike with 700 c tires, light weight rims, dual pivot brakes, a springer saddle, 14 speed indexed drive train, and upright bars. Pics were taken in the parking lot of the Bike Exchange in Palo Alto.
P.S.
Does anyone know if this old frame pump is rebuildable. The seal on the plunger is wasted . I looked but couldn't see how to take it apart. For now it is just for looks. I have it's twin in the shop and would love to make it functional again.
News Flash
9/19/23
P.S.
#6791
Liked 2,840 Times
I do not think the high wing really was beneficial. Outlawed soon enough.
I was handed a suspension arm, totally expecting a heavier part, amazingly light.
I appreciated that the rule book was looked at as something to be read and worked around. No CFD, just smart hunches.
#6792
Steel IS Real
Do you like the Panaracer Gravelkings? (it looks like they're Gravelings from what I could see...)
#6793
ambulatory senior
Quoted: 1957 Post(s)
Liked 3,673 Times
Very cheap and low end lemond tourmalet. Had to remove a bad rivenut. Got the 8 speed brifters working but the left one is not responding. Besides I hate the gear ratios it calls for on the crank. I'll put something else on and use a barcon on the front. I will say for 525 it's fairly light. This might make a nice fair weather ride.
Likes For 52telecaster:
#6794
Quoted: 2347 Post(s)
Liked 5,270 Times
This morning I just fixed one minor issue with the Motta. It was only setup for one bottle cage which is a problem for me. I need two on almost all my rides and hate carrying one in my jersey pocket.
So this morning I took a couple of the Velo Orange cage clamps and mounted a second one while also swapping out the other one so I have a matched set on it. I always take precautions to keep these clamps from marring the paint. Today I took of piece of the soft rubber Bontrager finishing tape and cut it to size to line the inside of the clamps. Then I put more tape on the clamp area of the bottle cage. Mounted it with the same pink bolts I used for the other bottle cage. Looks ok but would have blended in better if the clamps were black. I may need to move it up just a tad if it interferes with removing the back tire but for now it's staying there.
Yesterday I finished sorting out the old Merlin. New shift cables and swapped saddles and seat posts. The shifting of the long cage MB RD is lazier than I like on the test stand but seemed to actually work ok on the ride yesterday. The Wickwerks 53/34 chainrings work flawlessly as is always the case when I put them on a bike. Oh and matching bottle cages on this one too with red bolts to accent the other red on this bike and make it not quite so boring looking.
Steel is real...and comfy.
Likes For jamesdak:
#6795
Quoted: 113 Post(s)
Liked 215 Times
Overhauled the headset on a recent find.
Early 80's Schwinn mtb. Steerer tube is marked Ishiwata and it has Suntour forged dropouts so I'm wondering if it was made in Japan.
#6796
Quoted: 755 Post(s)
Liked 741 Times
Back to the scrap yard for this one. Top tube is dented and bent. But everything else was salvageable. I may try and roll out the dent for S+G's. And now I've got a full LX group to play with.
#6797
Cantilever believer
Quoted: 566 Post(s)
Liked 1,956 Times
#6799
Liked 5,270 Times
My 1972 Raleigh Pro has no bottle bosses (or even bottle middle managers), so everything has to be held on with clamps. When I installed the seat tube bottle cage, I ran into the same problem - the clamp bolts did prevent the removal of the rear wheel. And with my frame size (20.5/52), moving upward wasn't an option. So I had to swallow my pride a bit and use (egads) stainless hose clamps, but with the clamp screw offset to the side above the front derailleur where it isn't so clunkily obvious. But it works.
Likes For jamesdak:
#6800
KiwiAmerican
Bikes: 1993 Specialized RockHopper Comp. 1992 KHS Montaña Pro. 2018 Cannondale CAAD 12. Raleigh Seneca Mnt Tour.1987 Nishiki Prestige. 1993 GT Karakoram.
Quoted: 9 Post(s)
Liked 27 Times
Another 90’s Mnt Bike Project
Have been hovering over this guy for a few months. I was tempted by condition and price even though it’s not an entirely novel bike. Super happy with it upon pick up. I already have a faithful steel mnt do-it-all so not sure what direction I’ll go with this. Still needs to be cleaned, gutted, greased, and replace consumables before I get there. Any ideas are welcome!
