#7101
1991 PBP Anciens
Bikes: 1954 Robin Hood, 1964 Dunelt, 1968 Raleigh Superbe, 1969 Robin Hood, 197? Gitane, 1973 Raleigh SuperCourse, 1981 Miyata 710, 1990 Miyata 600GT, 2007 Rivendell Bleriot
Quoted: 77 Post(s)
Liked 362 Times
I had to get creative today to get a stubborn drive side BB cup out.
That's a Suzuki GS550 transmission gear and a 3/8" bolt keeping my cup wrench on the boggered up cup. The cup broke loose unexpectedly and I almost knocked the stand over.
Likes For bikamper:
#7102
Happy With My Bikes
Quoted: 887 Post(s)
Liked 2,354 Times
#7103
Bikes: Teledyne Titan, Bob Jackson Audax Club, Bob Jackson World Tour, AlAn Record Ergal, 3Rensho Katana.
Quoted: 215 Post(s)
Liked 623 Times
The 753OS Land Shark build is complete and runs like a Swiss watch.
Untitled by nemosengineer, on Flickr
: Mike
: Mike
Booyah Hubba-Hubba!!!
Likes For Nemosengineer:
#7104
Quoted: 477 Post(s)
Liked 1,104 Times
BTDT. Now when the torque forces get really high I take the bike down and work on the floor. I have a rubber mat in front of the work bench so put the frame there and lean on the tool or even the pipe that’s on the tool. I’d much rather, if the fittings going to “break loose”, have the tool moving towards that rubber mat vs towards me or something breakable.
#7105
1991 PBP Anciens
Quoted: 77 Post(s)
Liked 362 Times
#7106
Quoted: 249 Post(s)
Liked 474 Times
Nothing much lately...only at the bike shop sporadically as it is winter in northern ny. I've recently built an Aethos with Ultegra 12 speed Di2...came out great.
I barely work on my bike...sigh...Di2 requires no maintenance and a waxed chain only gets replaced with another one once a month...compared to fiddling about with my old Ultegra mech system and oil based lubes on a weekly or so basis just because...it is actually a bit boring but i'm not complaining lol my bike works flawlessly, is near dead quiet and only needs a 'dusting and polishing' now and then to keep her happy is a loverly thing indeed.
So I've built an SWorks SL8 with Dura Ace Di2 12 speed and an Aethos with Ultegra Di2 12 speed and comparing the drives to my Di2 105 system on my Aethos...no difference at all...I can not feel any difference shifting any of the bikes and i've tweaked the drives to the same level of my Aethos...no synchro at all. So i've basically got a top of the line drive on my Aethos at a very low cost and as long as i'm not looking at it...lol...i have Dura Ace...love it...
#7107
Quoted: 1637 Post(s)
Liked 2,728 Times
Got me thinking...
#7108
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3939 Post(s)
Liked 6,631 Times
Likes For SurferRosa:
#7109
Quoted: 3397 Post(s)
Liked 3,750 Times
My Grand Jubile has been a single speed or fixed gear the entire time I’ve owned it.
I finally built a 120mm 5 speed freewheel wheelset for it and installed its namesake derailleur.
Shimano 60 FD since I haven’t gotten around to tracking down a matching front.
Likes For abshipp:
#7110
Bikes: Motobecane C41, Matsu$hita Nashonaru
Quoted: 215 Post(s)
Liked 439 Times
Wouldn't call it wrenching. Measuring and checking options.
I was looking for a BB I can use with SR Royal ESL crankset. Two requirements: 1. unless I decide to use a totally different frame, I need Swiss threading. 2. SR Royal ESL requires 112mm (or therabout) ISO taper BB.
Swiss threading is easier. IRD still makes their Swiss threaded cups (for now) and once in a while one can find Swiss threaded BB's with a bit of luck. Got a set of cups, but unfortunately IRD's bottom brackets are JIS. As are most cartridge bottom brackets out there. A perfect solution would be to find SR, old fashioned, cup and cone BB with Swiss threading,112mm spindle and ISO taper, but I'm guessing I have a higher chance of buing a winning lottery ticket
I found out that Tifosi make their "Carbon" BB with ISO taper and close enough spindle length (111mm). That's 0.5mm too short on each side, which shouldn't be too much of an issue (especially with friction shifting). So I got myself one and decided to try IRD cups with it. Looks like it might work. My rubbish digital caliper shows internal diameter of both adjustable cups as 30.6mm. IRD one feels a bit looser on the BB, but the Tifosi one is not exactly snug, so I'm guessing this should be fine. Fixed IRD cup internal diameter 30.4mm, but the Tifosi one is very snug and I didn't remove it yet. It might be a few months before I actually get to test this combo in an actual frame, but I decided to post it here in case anyone out there is looking for Swiss threaded BB options and is willing to try it.
I still don't know how I feel about IRD cups having no seal, so that's something to look into. I'm planning some maintenance on the bicycle where I use IRD bottom bracket, so I will check whether they put something between the bearing cartridge and the cup (simply don't remember at this stage). But this might take me closer to actually pushing forward with the Motobecane Superbe project. I mean I still have some parts to find or decide on (stem, handlebar, brake calipers) and build a wheelset for it, but thankfully there's no rush.
IRD Swiss NDS cup (no seal) and Tifosi NDS cup (with seal0
Cup sizes are basically the same
IRD cups (both sides) and Tifosi NDS (with seal)
Likes For VintageSteelEU:
#7112
Quoted: 215 Post(s)
Liked 623 Times
"Known as the "Los Angeles Wheelman Club and formed in the summer of 1882'
https://calisphere.org/item/e4606aa1...d16c5ea8252cf/
Mike
#7113
Palmer
Quoted: 1704 Post(s)
Liked 1,889 Times
Likes For tcs:
Likes For spclark:
#7116
Bikes: 1964 Huffy Sportsman, 1972 Fuji Newest, 1973 Schwinn Super Sport (3), 1982 Trek 412, 1983 Trek 700, 1989 Miyata 1000LT, 1991 Bianchi Boardwalk, plus others
Quoted: 589 Post(s)
Liked 706 Times
Working on wheels and gearing on my 1983 Trek 700. The stock low flange Campy hubs with 13-20 rims were fine with a freewheel and 32mm Gravel Kings, but I didn’t like the looks. I came into some nice Shimano wheels with Uniglide 6 speed freehub and Mavic G40 rims. Some NOS Super Champion 58 rims were used to replace the skinnier Mavics and only 1mm larger in ERD. The 32s look more appropriate on the 58 rims.
The wheel change was to get the freehub. I converted the Uniglide to the Uniglide/Hyperglide compatible freehub, and can now run 7 speeds. I have a box of Uniglide cogs and got a co-op 8 speed cluster to use the spacers. This all allowed me to build a 7 speed uniglide with gears spaced at just slightly under 5mm. I bet it would even index, but the Suntour power ratchet shifters shifts it wonderfully. Building my own cluster got me 15-17-19-21-23-26-30 and a 36-47 front. Nice for an old guy in flattish terrain who doesn’t need high speed.
Likes For sd5782:
#7117
Quasi homeostatic system
Bikes: '81 Fuji America, '82 Team Fuji, '85 Nishiki Bel Air, '98 Klein Stage Comp R
Quoted: 48 Post(s)
Liked 205 Times
Oof! I managed to post this to the wrong thread yesterday...
What I had mistakenly started as a quick upgrade turned into a month and a half of downtime. Finally thanks to the CV for sale forum, fleabay and Koolstop, I've got new(er) and improved braking. Third set of calipers was a charm: it turns out the America doesn't have enough clearance for 32mm tires and dual pivot calipers. Updated the levers for spring return and aero hoods, added Blue Lug's variation of Nitto/Riv Mark's rack.
Next up: attach a head badge, get a ride in to confirm lever position, wrap bars and order a bag for the front rack.
Likes For MrGastrognome:
#7118
Quoted: 1629 Post(s)
Liked 2,250 Times
@Nemosengineer - What bars are on the Land Shark? Look similar to Cinelli 65s. I like
Playing around with accent colors. Going to try blue too. More appropriate for Campangolo parts and the blue on the frame.
PXL_20231123_140537905 on Flickr
#7119
Quoted: 215 Post(s)
Liked 439 Times
#7120
Quoted: 48 Post(s)
Liked 205 Times
I have a Suntour variant of these calipers (Superbe 4700) on one bicycle and I find them very effective. And I didn't get round to replace the pads yet (so the ones I'm using are about... 40 years old now, unless they were replaced, because they had barely any wear). They squeal like all demons, so perhaps I should replace them finally... I wouldn't say they are worse than dual pivot brakes I used to date (Tektro, Shimano, Miche).
I got the head badge attached and the first layer of bar tape wrapped. I have to order some shellac flakes so I'm ready to finish the wrap when I return from out of state for the holidays with some contraband denatured alcohol.
#7121
Quoted: 215 Post(s)
Liked 623 Times
Hi SJX426,
The bars are Nitto B125AA NJS Approved Track Handlebar - 40cm, 25.4mm clamp. The bend is identical to the Cinelli 65, verified by direct comparison.
20200718_132054 by nemosengineer, on Flickr
20200718_132153 by nemosengineer, on Flickr
20200718_132222 by nemosengineer, on Flickr
: Mike
#7122
Quoted: 847 Post(s)
Liked 2,219 Times
: Mike
: Mike
-Randy
'72 Cilo Pacer • '72 Peugeot PX10 • '73 Speedwell Ti • '74 Nishiki Competition • '74 Peugeot UE-8 • '86 Look Equipe 753 • '86 Look KG86 • '89 Parkpre Team Road • '90 Parkpre Team MTB • '90 Merlin Ti
Avatar photo courtesy of jeffveloart.com, contact: contact: jeffnil8 (at) gmail.com.
-Randy
Likes For gaucho777:
#7123
Quoted: 4567 Post(s)
Liked 6,548 Times
https://silca.cc/collections/accesso...n-water-bottle
Likes For merziac:
#7124
Quoted: 847 Post(s)
Liked 2,219 Times
Thanks @merziac
#7125
Quoted: 2349 Post(s)
Liked 5,291 Times
Had a little medical setback that also interfered a bit with recovering from the knee replacement. But, I think I'm ready to move on from the Azor so I went ahead and got the Holdsworth set up for whatever use I can get out of it this winter. So far serious snow has held off. Anyway, this morning I took the tubular setup back off the bike and put on the clincher setup. Easier to quickly deal with flats that may happen with the cold weather rides. Messed with the headset adjustment some too as it was notching at one point.
I may have to try a few different saddles to see what's going to work best in a more upright position.
Steel is real...and comfy.
Likes For jamesdak:
