Go Back  Bike Forums > The Racer's Forum > Track Cycling: Velodrome Racing and Training Area
Show Off your Track Training and Racing Bikes (2014+)
Track Cycling: Velodrome Racing and Training Area Looking to enter into the realm of track racing? Want to share your experiences and tactics for riding on a velodrome? The Track Cycling forums is for you! Come in and discuss training/racing, equipment, and current track cycling events.
Old 11-17-17, 05:47 PM
  #751
Quoted: 194 Post(s)
Liked 2 Times in 1 Post
Mah baby.
File Type: jpg
southernfox is offline
Old 11-17-17, 06:58 PM
  #752
Lapped 3x
taras0000's Avatar
Quoted: 325 Post(s)
Liked 23 Times in 20 Posts
Someone's ready to go fast!
taras0000 is offline
Old 11-18-17, 09:53 AM
  #753
Elitist
carleton's Avatar
Quoted: 1386 Post(s)
Liked 92 Times in 77 Posts
Very nice!
carleton is offline
Old 11-18-17, 10:42 AM
  #754
aka mattio
queerpunk's Avatar
Bikes: yes
Quoted: 344 Post(s)
Liked 58 Times in 35 Posts
Those TC1s seem like great, affordable bikes. Like if it were racing season and I damaged my bike today, I'd order one of those tomorrow.
queerpunk is offline
Old 11-18-17, 10:47 AM
  #755
Quoted: 194 Post(s)
Yeah, it's a great entry level that doesn't feel like an entry level bike. My next will probably be a fuji elite
Old 11-18-17, 11:22 AM
  #756
Elitist
carleton's Avatar
It's a solid bike.
Unsolicited advice: Spend money to solve problems and meet desires. Take note of what you like and don't like about this one and make sure that it's addressed in the new frame.
I'd imagine that you'd want something with a slightly shorter head tube maybe to give you the option of going lower without using an erogstem.
The Fuji is nice and has a great geometry.
carleton is offline
Old 11-24-17, 08:02 PM
  #757
Bikes: Felt TK FRD
Quoted: 59 Post(s)
New bike to replace the too small DF3 I had.
File Type: jpg
Godsight is offline
Old 11-27-17, 06:37 PM
  #758
Elitist
carleton's Avatar
Nice ride! How do you like the cranks? What BB did you use?
carleton is offline
Old 11-27-17, 11:25 PM
  #759
Bikes: Felt TK FRD
Quoted: 59 Post(s)
In general I like them. It seems like Vision only forge one length of crank arms and just drill the pedal holes at different spot for either 165 or 170 so the 165 arms look strange compared to 165 Dura-Ace. The chainring bolts are the spinning type that are annoying to deal with. Haven't received yet the Dura-Ace knurled chainring bolts but I see no reason why they wouldn't work.
I used the FSA steel BSA bottom bracket but any BSA bottom bracket made for 30mm axle will work. Plenty of options available if I want to upgrade later to a ceramic bottom bracket.
Installation was super easy but then again square axle is also easy to install. For maintenance, you can keep the FSA BSA bottom bracket cup in place and just extract the cartridge bearing and replace them compared to replacing the whole bottom bracket for a square axle or octalink crankset. The Vision crank comes with a auto-extractor bolt so removal is also very easy.
The Vision crank arms are bigger in all dimensions compared to Dura-Ace but have the back-side hollowed out. Just need to wait for summer or a chance to go to Milton to try out their stiffness.
Regarding the TK FRD frameset, I was pretty happy to see that it came within the box 2x bayonet top crown and 2x splined knuckle so the only thing I was missing to have two complete setup (1 for TT and 1 for drop bars) is another 31.8 stem faceplate. Had to go with the shortest extension to be within the 75cm rule for TT bars and I can run the longest extension and still be inside the 5cm limit with a compact 36cm road bar. Just need to see if my back muscles can handle to go that long and low with the drop bars. Daily stretching could be useful.
File Type: jpg
Godsight is offline
Old 11-28-17, 11:33 PM
  #760
Elitist
carleton's Avatar
Thanks!
That's interesting about the cranks being the same length but drilled to make different sizes. I guess that's how they keep the cost down.
carleton is offline
Old 11-29-17, 03:35 PM
  #761
Quoted: 70 Post(s)
Liked 5 Times in 5 Posts
Molds for cold forging ain't cheap
I'm planning to get a set of those cranks in 172.5 and use a Rotor BSA30 I have lying around.
rustymongrel is offline
Old 11-29-17, 03:51 PM
  #762
Elitist
carleton's Avatar
Good point.
Maybe it's cheaper to make the mold in the largest size then band saw the excess off and sand before painting? Or they can do the thing where there's an insert that gives you 3 different length options depending on how you turn it.
Also, Sugino knurled chainring bolts are probably less expensive than Dura Ace. I've used them as replacements for Dura Ace when I happen to break them.
$20 here: https://www.retro-gression.com/produ...hainring-bolts
I've ordered from there before. Nice people.
carleton is offline
Old 11-29-17, 04:18 PM
  #763
Quoted: 18 Post(s)
Originally Posted by carleton
i've ordered from there before. Nice people.
+1
kings run east is offline
Old 11-29-17, 09:20 PM
  #764
Quoted: 70 Post(s)
Good point.
The lobed inserts are clever, I guess maybe they're patented by Look? That would explain why you don't see them anywhere else.
I've heard there's good reason not to machine a forged part from a structural standpoint, maybe that's why they don't bother shortening them.
Old 12-06-17, 09:34 AM
  #765
Idiot Emeritus
sarals's Avatar
Bikes: Yes.
Quoted: 331 Post(s)
Liked 13 Times in 4 Posts
I LIKE your baby! Congratulations! (My coach rides a Fuji Elite - nice!)
"Can you add a signature line please? The lack of words makes me think you are being held hostage and being told to be quiet"
sarals is offline
Old 12-06-17, 11:09 AM
  #766
Lapped 3x
taras0000's Avatar
Quoted: 325 Post(s)
It has to do with the way forging aligns the grain structure of the metal. Think of a part that is made in a closedmold and is foam injected. If you were to cut it in half, you would see that the foam is densest along the outer skin with bigger bubbles in the center. Forging does something similar to the grain structure in metal. Remove some material after forging and you will remove that strong outer "skin", creating weak areas.
Old 12-06-17, 12:13 PM
  #767
Elitist
carleton's Avatar
In this particular case with holes for pedals being drilled unusually further from the end, wouldn't those holes be in the weaker areas?
carleton is offline
Old 12-06-17, 12:16 PM
  #768
Elitist
carleton's Avatar
Getting closer to my final form.
LVL: 80/100
Felt TK FRD
3T Scatto
Zipp 808 Track
SRM Track Science
Ultegra Pedals (Making my own straps, stay tuned)
Izumi V chain
carleton is offline
  #769
aka mattio
queerpunk's Avatar
Bikes: yes
Quoted: 344 Post(s)
yes possibly but they'd still be exerting force on the strong areas.
Old 12-06-17, 05:19 PM
  #770
Lapped 3x
taras0000's Avatar
Quoted: 325 Post(s)
Having the holes in the weaker areas isn't the problem. The strength here would be the same as that of a billet machined crankset. But if you were to trim the ends off after forging the crank, you would be removing this tough, work hardened exoskeleton that forging imparts on the crank. That skin contains and transmits stresses and you would then have a piece where the end of the crankset has lost this ability. It would act similar to a stress riser because you have a gradient of strength across the cross sectional aspect of the exposed crank end. Most likely you would end up with localized distortion down the road, if it doesn't crop up right after machining.
Old 12-06-17, 07:16 PM
  #771
Elitist
carleton's Avatar
Wow. Thanks for the responses.
On a related note: Short Bicycle Cranks
carleton is offline
Old 12-12-17, 08:20 PM
  #772
DMC707's Avatar
Bikes: Too many to list
Quoted: 1765 Post(s)
Liked 1,125 Times in 746 Posts
Mah baby.
Your machine has a clean and well sorted appearance !
DMC707 is offline
Old 12-13-17, 06:42 PM
  #773
theblackbullet's Avatar
Bikes: I don't even
Quoted: 84 Post(s)
Liked 220 Times in 84 Posts
I knew this would come up
My complaints about the 2010 TK1:
A) Tilting Ritchey seat mast topper (deal breaker)
B) Largest size was 57cm TT
C) 40mm offset fork
I was talking with my bike fitter about the issues one day about how I didn't have the tilting seat or fork offset issues with my Tiemeyer. He was quiet then said, "Do you still have the Tiemeyer?" I did. He also said that both the Tiemeyer and TK1 were too small for me. But, moving back to the Tiemeyer would at least eliminate the deal-breaking seat issue that lost me races. I sold the TK1, rode the 57cm Tiemeyerand and ordered a new 58cm Tiemeyer that addressed all 3 of those issues (ableit only 1cm longer but with a 15cm head tube instead of the 11cm on the previous...I should have had it made at least 2cm longer at 59cm).
Nowadays, I want a 60-61cm TT. There are only a few high-end bikes that come that long. Many are labeled "60cm" but are not. The 60cm Fuji carbon actually has a 58cm TT. The "60cm" Koga has a 57cm TT. So, the TK1 and Cervelos have the longest top tubes (that I can recall off hand).
Since then, Felt went to the 3T seat mast stopper with the indexed DIFF-LOCK system, that addresses issue A.
They also increased the TT length 3cm which addresses issue B.
They still have the 40mm offset fork (issue C). This is my only concession.
The TK FRD (TK1) is the best bike for me right now that:
- Addresses all of the deal-breaking issues (seatposts slipping, toppers tilting, dropouts slipping, etc...)
- Has the reach I need.
- Is high quality.
- Is available.
- Is fancy
Random fact: The bike weighs 8.3kg/18.5lbs as pictured above. That's only 1lb lighter than the 61cm steel Snyder.
Just to note, the Fuji Track Elite is offered as a 61cm and has a 59.5cm TT.
theblackbullet is online now
Old 12-13-17, 07:05 PM
  #774
Elitist
carleton's Avatar
I see it now. Thanks! They call it the "XXL"
Fuji Bikes | Track Elite
I'm glad that manufacturers are now embracing longer frames. Also, as someone here pointed out, narrow bars necessitate a longer top tube than wider bars. Because bringing the hands closer together effectively extends them further out. Interesting basic geometry fact that I'd overlooked for a long time.
carleton is offline
Old 12-13-17, 07:37 PM
  #775
Bikes: I don't even
Quoted: 84 Post(s)
Yes thank goodness! 59.5 is kind of on the edge for me, but it was the tipping point fo finally getting one of these fancy plastic bikes. Now if only I could get fuji to offer the same bike with 130mm spacing in the rear and a derailler hanger... Most manufacturers are still stuck on short top tubes and slack seat tubes for large road frames unfortunately. At least for track bikes, steep angles have always been available.
