Decoding of Eddy Merckx frames
#803
My guess is a 1985 Professional, SL tubing.
#804
Quoted: 4558 Post(s)
Liked 6,519 Times
#805
Merziac, I am looking at a Merckx frame with a Y 5 on left --- A6382 on the right. I can't find any real clues as yet to any other info...Any ideas?
#806
Liked 6,519 Times
Check my avatar, Merz is my main deal and I do have a couple of Merckx's.
Merz's
10th Anniversary tribute
#807
Quoted: 235 Post(s)
Liked 402 Times
Very interesting frame !
Built in December 1993 for the 1994 season, probably for a profi team ( not sure which one ).
U.Scanini is a Belgian brand (frames imported from Italy), Eric Vanderaerden (prominent cyclist) used their frames and as a result his name was next to the name of the "manufacturer".
Since U.Scanini "rebranded" the frames, EMC's Mx Leaders may also have gone to him.
In 1998 Team Collstrop used E.Vanderaerden there (in 1996,1999 and 2000 he used EMC frames).
To check is who used U.Scanini/E.Vanderaerden frames between 1994 and 2000 and a piece of paper (if it survived) on the fork steering tube.
#808
Quoted: 235 Post(s)
Liked 402 Times
Z7300 - is most likely Professional (late) Columbus SL. Lack of X and Gipiemme brake bridge do not give optimism. Only a photo of the inside of the tubes visible through the BB cover would explain it fully.
#809
Quoted: 235 Post(s)
Liked 402 Times
A6382 Y5 - 1987, but without photos it is impossible to write more.
Around the marking of Y5 maybe missing X, CX, C, M , also check a piece of paper placed on the fork steering tube - maybe something can be read.
#810
Bikes: Colnago Super (panto) - Gios Professional (1st Generation C-Record) - Eddy Merckx Corsa Extra (Team USA) - Barellia Reynolds 531 - Fully chromed Columbus steel bike (Patelli?) Super Record Titanium
Quoted: 60 Post(s)
Liked 33 Times
#811
Quoted: 60 Post(s)
Liked 33 Times
#812
Quoted: 2347 Post(s)
Liked 5,274 Times
Guess I can add mine to the mix.
Best I can tell there's a 55 and a C on the left side,
On the right side it looks like a G and a serial # 453889
Then there's this...
Steel is real...and comfy.
Likes For jamesdak:
#813
Quoted: 235 Post(s)
Liked 402 Times
G3886 - serial number, frame built in late 1996.
45 - different font size, non-standard marking.
55C - frame size 55 cm, C - marking used at the time only on the Corsa 01 model.
Paint pattern introduced in 2000 for the 2001 season used on Team Domo Farm Frites, frame painted in EMC.
Information posted on a piece of paper attached to the fork steering tube would be very helpful.
#814
Liked 5,274 Times
The bike was supposedly ridden by Wendy De Vos on the Domo Farm Frites women's team. I've found one reference to there actually being a women's team with only one rider associated with it. I have found Wendy via Strava but have no way to reach out and ask her.
There was no paper on the fork steerer nor did I even notice any stampings or such.
Thanks for the info!
Back to googling....
Likes For jamesdak:
#815
Bikes: Yes, probably too many but still have a roving eye...
Quoted: 322 Post(s)
Liked 2,846 Times
Ah...So a Corsa 01 model not just a Corsa. Now I have more research to do. Seller said it was EL-OS but I really don't know what tubing it is. It weighs 18 lbs 12 ozs in the picture without pedals so It's got to be a fairly light tubeset.
I was out on my MX Leader version today...a mind blowingly good ride
I know nothing about the pro race circuit and am not disputing that Wendy was/is a pro racer, but maybe it could be possible she's just a regular cyclist who had the frame repainted with her name on.
My frame above was dated by Jacek as from 1993, the Domo Farm Frites paint scheme was from much later in 2000/2001. The non drive side of mine also has a name on it that google does not give any inkling about a pro cyclist, so I just assumed it was a keen amateur Belgian cyclist who bought an older Merckx, and in or around or after 2000/2001 got repainted with his name on the top tube.
I'm not on Strava but can't you reach out to people on there to maybe ask her direct? Is she are you on Twitter or Facebook maybe an option too? Its not stalker-ey to try and track someone down to ask their bike history is it? If it was me I'd super pleased to see an old friend again and know that it was still on the road. Just some thoughts for my 2 pence/cents worth.
Likes For botty kayer:
#816
Quoted: 322 Post(s)
Liked 2,846 Times
And these are not mine, and are not in my size so I'm not in the market for them, but I'm sure our eagle eyed Jacek has seen them, and I was just curious and had some paint scheme questions. These are both currently on UK ebay now.
First up is a labelled Corsa Extra in the Team Panasonic paint scheme.
https://www.ebay.co.uk/itm/175505088643?hash=item28dceb2083:grcAAOSwC5FjgSyr&amdata=enc%3AAQAHAAAAoE%2F5lNHEFXNu8SqMBLb%2BsCV K1WvKAe0GqUBMh283cwkGdhoB%2B0BRkOaRUp8AYM4zAIgZdSUhRx%2FOI1O2b9csKjUU9XuS0JPXamlvdN2Md%2F%2FSQIPrXDq gAgsCFYg2nRkgjaLMHYZRJJG2zEUr4PTt6l8WIU5J%2Fwi9RYdnJyY4vQjqLwRuI%2FJiPIMUK4%2BZknOpYugTOyWBvIJdKQKa% 2BOQmgrc%3D%7Ctkp%3ABk9SR4jQr7ijYQ
Cube rear brake bridge and flat crowned fork. However the colors on the camo fade from dark blue to lighter blue does not look the same as the one on my 1985 Pro. The one above has two color apart from the dark blue and white, one of which looks more grey. Is this original or a repaint?
For reference here's the camo fade on mine.
My one also has the full chrome rear triangle, right up to the seat pin....
I've seen versions that have a painted rear triangle in the white and blue, and ones with chrome chainstay/s. I have never seen the paint and chrome variant on the chainstays and seatstays of the bike advertised, it just didn't look right to me, no camo fade on the seat stays in particular looked odd, but wondered if Jacek has seen it and what he thought?
And secondly is this MX Leader, it looks to be one of the earlier full Columbus Max versions, before the introduction of the MXL tubeset. But what wowed me about this one was the cool orange to yellow paint drip effect fade on the paint job, and also the starry rear triangle. I don't recall ever having seen that before. Jacek does that paint scheme have a name, was it associated with a team? I was just curious. Tell me more about this please
https://www.ebay.co.uk/itm/334667869...-0&toolid=1001
#817
Liked 5,274 Times
Welcome to team fries James, a fine team indeed . The paint on yours looks in fantastic condition, great score!
Yep, I have reached out a couple of ways. I was told she was married to Sven Vanthourenhout who was a Domo-Farm Frites rider and a coach of the Belgium cycling team. I found old google hits about them having some kids. Those same kids did a ride together with the Wendy I found on Strava back in 2021. No recent entries for her though. I did make a comment on that ride hoping she'd get an email alert or something but no response. Love to find out but without seeming too much like a crazed cycling stalker, LOL!
The bike is nice. Some pretty good chips at a few spots on the paint and some chain wear on the one stay. What's curious is the non-treaded fork. It didn't have any label attached nor did I see any stampings or other marks on it. It is a 1" steerer though.
I was able to source the Silva branded blue Merckx tape like I've seen in some of the men's team photo's and have a set heading my way. Last night I got in the 90mm stem I needed for my fit and put that on. I also swapped the white flite saddle for a black Avocet Ti Air I had. So this will at least look like the old men's team bikes. We are getting hammered with snow though so this won't get a test ride for months, augh!!
So right now I guess I'm actively "stalking" to riders for confirmation. Wendy on this one and Oscar Freire on the Olmo. It'd be cool to actually hear back from at least one of them.
Likes For jamesdak:
#818
Quoted: 322 Post(s)
Liked 2,846 Times
jamesdak I love a good detective story. Fingers crossed you get a reply with some more info, and post back here with any news. Good luck!
#819
Quoted: 235 Post(s)
Liked 402 Times
#820
I just picked this one up from Steel Vintage Bikes in Berlin during their Black Friday sale (20% off + free shipping to Texas ... arrived in 2 days!). My calculations are Strada Cromor 62cm c-c, probably 1988 based on the high A serial number and catalog photos with color scheme and logos. The fork, unfortunately, is not original. Has the straight seat stay brake bridge vs. the pointed arched one. Any other insights appreciated! And if anyone runs across an Eddy Merckx steel fork for this 62cm, lemme know!
Likes For zbillster:
#822
Didn't come with one. I don't have one on my 1994 Colnago SL either. My 1986 Colnago are steel brazed onto the bottom bracket at the factory. I noticed some people build up bikes with and without them.
#824
Liked 5,274 Times
Nice!
So right now I guess I'm actively "stalking" two riders for confirmation. Wendy on this one and Oscar Freire on the Olmo. It'd be cool to actually hear back from at least one of them.
