Carbon touring?
#101
Quoted: 18596 Post(s)
Liked 16,096 Times
#102
Quoted: 2236 Post(s)
Liked 1,315 Times
Is it expensive? No. Is it quality? Well, that depends on what you think quality is. All I know is that at over 25 years of age it has performed flawlessly as a winter commuter and runs pretty fast metric centuries.. Wish I could say the same about its over 50 year old owner...
The best bike is the one you actually ride.
#103
Quoted: 188 Post(s)
It's just a matter of perception. A Hybrid is nothing more than a 29'r with smaller tires. One can make it as fast or slow as they want. Here's my 1991-91 Trek Multitrack (early Hybrid) with drops and Gatorskins on. I use it for commuting to work but wouldn't hesitate to take it on a light fast tour.
#104
Liked 1,315 Times
I'd say it's mostly the bars and suspension, which could be changed but if it works it works
It's funny, I just rode the BC ferries with about 50 other cyclists off on long weekend jaunts and the selection of bikes was wild. There was no rhyme or reason to anything. In reality people just ride what they ride and are happy regardless.
#105
Quoted: 188 Post(s)
#106
Let me end my time on this forum reading your drivel forever. You're a ****ing idiot.
#107
Liked 1,315 Times
Yep. Bars do not make a bike good or bad for an activity. People take flats and swap out trekking bars, some add drops. Some add moustache or jones bars and others add aero's - it's a personal thing.
As to the suspension. At least she is riding. Far better than owning an expensive bike that sits in a garage.
#108
Bikes: 2016 Novara Mazama
Quoted: 3640 Post(s)
Liked 81 Times
Here's one for you!! I can throw out Hybrids from the conversation because they are made/marketed for inexperienced cyclist for short distance only. They are non-functional for long distance cycling.
That throws out dept store and hybrid bicycles from the stats. So maybe that brings me to 50% of bicycles are under $2K. maybe less. The numbers need to be adjusted here.
We'll use your numbers. If 90% of the bicycles sold are under $2K that means 90% of the bicycles sold are entry level or low end. The 7% between $2K and $6k is the amount of mid-range bicycles. And that leaves us with the top 3%. So the 50% line is not about the number of bicycles it's about the quality of the bicycles, and subsequently the price.
Someone gave my ex a hybrid about 5 yrs ago. She's ridden it twice. My guess is the previous person about the same. So this bicycle might have 10 miles on it total. My guess is her bicycle is the "normal" hybrid. Praise to your friend. I'ld be willing to use it for around town, nothing more than that.
Don't you also think there may be more to your ex not riding the bike than the fact that it was a hybrid? I'd be willing to bet even if it were a fancy $10k carbon road dealie, it'd have been used just as little.
#109
Liked 1,315 Times
I would even argue that an expensive high end carbon bike would be ridden less than my cheap HiTen hybrid for the following personally observed reason.
Winter
The amount of fancy bikes on the road after sanding and salting begins drops dramatically. In Canada that's 6-7 months.
Winter
#110
Liked 81 Times
Odd. I'd much rather ride a carbon than a steel bike in the salty winter streets, seems like a place where the benefits are obvious!
#111
stupid made-for-inexperienced bigginers inferior hybrid. shoot...i thought
a full deore setup with suntour thumbshifters was good quality.
seems i wasted my time commuting through rain and sleet and dark
of night (midnight shift in northern germany) for 5 years, and all those
stupid wasted centuries. all that time i was doing it wrong!
There's an old saying in Tennessee — I know it's in Texas, probably in
Tennessee — that says, fool me once, shame on — shame on you.
Fool me — you can't get fooled again.
#112
Liked 1,315 Times
I understand your point about corrosion except no one wants to tempt ruining a $5000 bike that way and (not to be stereotypical) sometimes people who only ride "the best" also only ride in the the best conditions.
Bikes are funny things in that high end materials can sometimes limit use depending on conditions. Around town and winter bikes are usually beaters for that reason. It's not the material itself but the way people react to concerns about theft and damage.
#113
Liked 81 Times
Now, if you told me the CF bike could only take 25mm tires and the ride was mostly ice, I'd understand the problem with functionality, just don't understand a frame material argument!
#114
Liked 16,096 Times
My guess is that the $5K CF bikes usually have higher-end components, and it's the fear of those getting damaged by salt that results in beaters being used in winter. I don't ride my custom ti frame when the roads are salty for that reason.
#115
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
Back to the original topic - doesn't a CF frame have the potential to be the absolute easiest field reparable material ever?
You could carry a lightweight repair kit of CF fabric, epoxy, sand paper, and plastic wrap - the village smithies will be out of work.
The frame would be engineered with field patching in mind, maybe reinforce all the joints to make the straight section of tubing the weak points (so things like a cracked bottom bracket would be very unlikely). It could be designed so any standard hardware store epoxy would work, so you'd only have to carry a small amount.
CF is generally valued for it's high strength/weight, but for touring its field repairability might be the bigger selling point.
#116
Quoted: 223 Post(s)
I never really got that. I've always viewed the entire drive train as being consumable/disposable so harsher conditions have never stopped me from running whatever bike I just feel like riding. I think the only thing I *might* be a little paranoid about is running carbon rims and grinding the crap out of them with whatever junk is on the road, but almost all my bikes are running discs now.
#117
Sunshine
Quoted: 11100 Post(s)
Liked 7,703 Times
#118
Quoted: 760 Post(s)
Gotta go walk the dog!
#119
Liked 16,096 Times
#120
Quoted: 18463 Post(s)
Liked 4,568 Times
A rather unique build that brings the entire bike to less that 1/10 that value above though.
I do wonder a bit about the expensive bikes. My Colnago has mostly Carbon, Titanium, Stainless, & aluminum. Almost nothing on it will rust. Those few carbon steel parts get lots of lube. The only shortfall is that some of the seals, such as on the bottom bracket may have sacrificed durability for rolling resistance. Hopefully I can clean the bearings, but one might consider cheaper bearings with better seals.
Anyway, with the used market, there are a lot of relatively cheap used Carbon and Titanium frames on the market that could make the basis for a commuter, and perhaps even a touring bike.
#121
Liked 1,315 Times
If someone said: "Here is a $200 beater and here is a $200 carbon bike.. choose between the two" - I'd probably go for the carbon one too; but that doesn't reflect what I see around here. Absolutely true that there are some hard core roadies that get out regardless of conditions but mainly there is a big surge in late spring and great ebb in late fall. Of those seasonal high end bike riders I often see very clean machines and I have no doubt they get thoroughly cleaned each time they go out.
I don't see people with $5K carbon bikes doing this all winter, even though the frames could probably withstand it.
#123
Liked 4,568 Times
#124
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
It won't help with a catastrophic failure but self healing composites are a reality today.
Someday your bike frame will fix itself before you even know there is damage.
-Tim-
#125
That's kinda what I was getting at.
...that there are some hard core roadies that get out regardless of conditions but mainly there is a big surge in late spring and great ebb in late fall. Of those seasonal high end bike riders I often see very clean machines and I have no doubt they get thoroughly cleaned each time they go out.....
inferior beater "japcrap" (as my daddy calls 'em) bikes are out there every day, rain or shine.
they gets their annual maintenance and an occasional spritz with the garden hose to wash off
the dirt and grime and salt and assorted road debris. they's just bikes (think '79 CB550).
harleys on the another hand live in air-con garages of the suburban mcmansions, only coming
out on friday nights for the dusting off of one week's dust and the 1-mile cruise to hooters,
driven (ridden? ha!) by dentists and accountants in shiny leather chaps and faux torn denim.
and of course on sunny sundays, they'll be out there lovingly washed and polished and then left
at the end of the driveway for a few hours for the neighbors to admire.
a beater bicycle is out in the rain and snow cause it's just a bike. the whole thing is consumable.
but lots of folks with $3000+ bikes are too heavily invested in the statusy-symbolyism of bright
and shiny expensive stuff to get water spots or road salt (egads! a scratch!) on their precious.
