The Unofficial Univega Appreciation Thread!
#1326
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
that's a big'o frame! love the colors
what year is it?
what year is it?
#1327
Quoted: 195 Post(s)
Liked 207 Times
Good question. The serial number is M8C25546. The M indicates 84 but I think the Grand Touring name came later so I really don't know. I'm getting parts together. Some days I think of putting brifters on it but lately I see it with Suntour barcons and a 6 speed 14-32 freewheel. The only 7 speed freewheels I see with a big ring have a bunch of close ratio gears and a lone big 34t. I don't really see that as a good touring set up. Anyway, the parts should all be here in the next week. I'll be sure to post the pictures.
#1328
Sophomore Member
Quoted: 1628 Post(s)
Liked 1,059 Times
Got an '84 Gran Premio a few months back. These were I believe the third model from the top of the line, just below Univega's race bikes, these were marketed as "club bikes", and mine is certainly capable of that role. Takes 28 mm tires easily, as well as a triple. These frames are durable, comfortable and capable. The frame, that is. I have replaced all of the stock components other than the headset and seat post. I like old frames, but don't have the patience to deal with most old componentry, YMMV.
#1329
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
ah, the megarange freewheel. i have one of those i intend to get rid of as soon as i can. i don't have a tool for it, so i'll either need to get one or just go to a shop. you know, ird has some new wide range 7spd freewheels. they're not cheap, but they're also touted to be much improved over the first design. i've read about atleast two BF members already getting them. i don't think they're ramped, though, like hyperglide wheels
#1330
MERIDA (Taiwan): Insufficient data, but format appears to be MyMxxxx(x) based on limited sample size. Month indicator could turn out to be fortnight indicator. Also reported to use My??xxxx, where ?? is two letters. Somes uses a space or hyphen in front of xxxx number string. Easily confused with Miki , use country of origin decal, if present, to identify,
#1331
Quoted: 195 Post(s)
Liked 207 Times
For the Miyata-built Univegas, you'd be correct with M=1984, but after ~1986/7 production moved to Taiwan, so look at those builders -- especially since yours has the later uni-crown fork. - Giant began with a G, and yours starts with an M, so that looks to be, according to T-mar's Asian serial numbering guide ( Asian Serial Number Guide )- a Merida-built example.
I hope I'm right in this guess...
#1333
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
oh my! that is sharp specialissima?
#1335
Sophomore Member
Liked 1,059 Times
I've powdercoated two frames in "clear". Both of them suffered the same fate, namely, they look great for a couple of months. But small cracks in the powdercoating form in areas of flex, like the bottom bracket and head tube. Moisture enters the cracks, and rust forms. Once rust is formed under the powdercoating, it quickly (in a matter of weeks) spreads to the rest of the frame.
Apparently the problem is that, clear finishes lack the rust protection which is provided by sealers and primers, so their lifespan us very limited, maybe a year of normal use.
I have had OK luck with this stuff, on my steel Cannondale fork:
https://www.amazon.com/U-S-Chemical-.../dp/B0043B7UQY
I've been really careful about not getting the fork wet, and it's held up fine for a year or so with no sign of rust. The frames that rusted were often deliberately left outside in the rain as a form of "torture testing", so if that any rust that was gonna happen, I would see right away. And see it, I did.
This stuff is pretty good too, more economical that the 2k Glamour spray, since it's liquid instead or aerosol. I tried it before, but probably thinned it out too much, plan to try it again soon, and lay it down very thick so that metal is well-sealed.
https://www.kbs-coatings.com/DiamondFinish-Clear.html
What I have found is that clear coatings require a lot of babying, and while they will never be as durable as regular paint and primer, you can make them work if you're fastidious enough about protecting them from water and rain.
#1336
WV is not flat..
I’ve put many miles on this Specialissima. I wasn’t sure about the mustache bars, but have gotten pretty comfortable on them. This is from a trip down the C & O Canal to see the Cherry Blossoms in DC this year.
Likes For Goofball:
#1338
Quoted: 56 Post(s)
Liked 56 Times
My last attempt at a clear finish was with lacquer, using an adhesion promoter first, did ok except where my flabby thighs wore it off on the top tube, first rainy ride and it showed rust the next day. Bare steel and Seattle is not a good idea
#1339
Sophomore Member
Liked 1,059 Times
But the natural look of a polished steel frame is so awesome! Too bad it's only temporary.
I'm about ready to throw in the towel after so many failed attempts. My next (untried) idea is to find a shade of silver-gray paint the looks like bare steel, and use that. Then get some gold paint to make fake brazing at the lug joints. Then finally a clear coat over that. I suspect that this probably is the way to go vs. fighting all the rust issues.
#1341
Quoted: 195 Post(s)
Liked 207 Times
Found a Grand Touring on CL. It's outfitted with a flat bar. I waited a few weeks and offered $160. I'm so excited to get started. Adding: drop bars, a seven speed freewheel, moving the 32t to replace the 28t, a leather seat and racks. I've got some brifters but also some friction barends. 🤔
Before
Before
#1343
1996 Univega Superstrada
I picked this 1996 Univega Superstrada a couple of weeks ago, I watched it in the classifieds for a couple of months, it started at $200 when it reached $100 I went to check it out. I'm a little confused about the component group it's mostly original but my research shows that the Superstrada is #2 in Univega's lineup but, the original shimano RSX group is near shimano's lower end, why didn't they go with something a bit better?
By the way the bike rides very well, apparently the brifters gave out at some point and were replaced with a garbage set of brake levers and separate shifters (also garbage) I'm trying to decide whether to go back with the original brifters or just upgrade to shimano tri-color levers and shifters.
Likes For Gashepherd:
#1344
My very first Univega! A Nuovo Sport with a chromo frame, ??? fork, Suntour V-GT Luxe derailleurs, and ??? brakes. By the serial number, this is a 1981 model, correct? Also, is the frame made by Miyata, and why does everyone always ask that?
It isn't in the most amazing shape, but I won't complain for $60 and it being a 51cm frame. I am short.
Likes For Seijun:
#1345
Univega frames were made in Japan by Miyata until about '88 or so, when production of lesser models shifted to Taiwan.
#1346
Quoted: 4722 Post(s)
Liked 3,048 Times
Miyata was arguably the best of the Japanese mass volume manufacturers during the 1980s. Some would argue they were the best in the world. Regardless, the consensus is that were one of the best. Consequently, owning a Miyata built Univega is somewhat of a status symbol in the cycling fraternity.
Edit: The brakeset is the the ubiquitous Dia-Compe centre-pull and appears to be the 610 version. There were numerous clones of these and the Dia-Compe themselves were clones of Weinmann that were built under license.
Given the level of bicycle, hi-tensile fork and stays are likely. You can increase your confidence in the fork material by removing the fork and checking the steering tube. Most CrMo forks are stamped as such.
#1347
#1349
Bikes: Fuji Sportif 1.7C, Shogun Metro AT, Jamis Durango SX, Miyata Alumicross, Fuji Special Road Racer, Mongoose ATB, Fuji SST 1.0 Team, Gitane (?), Specialized Rockhopper SS, Univega Gran Turismo, Univega Supra Sport Mixte, Nishiki Tri-A, Diamondback Coil
Quoted: 82 Post(s)
Liked 141 Times
Not really. There was a notched headset wrench for it, similar to a bottom bracket tool. But you can finagle it, using a Channel-lock or get it started with a light tap counter clockwise with a hole punch. Then the washer underneath comes off, and then the big one just unscrews, it shouldn't be on there tight at all. Not a fan of those headsets, but when you get it back together it should be a set-it-and-forget-it sort of thing.
Likes For PugRider:
#1350
Quoted: 796 Post(s)
Liked 523 Times
