What are you doing today(C&V bicycle related)?
#1351
Quoted: 741 Post(s)
Liked 819 Times
Jury duty. Browsing BF in the jury room. Rather be on my bike, but the wheels of justice turn
s-l-o-w-l-y. Used to be a bike shop across the street from Van Nuys, CA court, but now I'm in San Fernando. Waiting.🏛
#1352
Quoted: 964 Post(s)
Liked 1,453 Times
Found a nice, perfectly true wheel with a 3-speed SRAM i-Motion hub laced to an A319 rim. Hub is predictably broken, as - why did they think they could re-invent the 3-speed? And has no shifter or cable-connector anyway, and none are available. Best put the hub out of its misery. Rim is pretty nice though.
AND the specs for flange spacing and size are close enough between the i-Motion 3 and a Shimano DH-3n20 that I can probably reuse the spokes and have them be the right length. Basically "insert labor here and receive a free dynamo wheel," seeing as I received the dynamo hub in error when I ordered something else. This should be fun. Results tonight.
#1353
WV is not flat..
Going through the finishing touches and cable work on this 93 Specialized Allez Comp.
#1354
Quoted: 964 Post(s)
Liked 1,453 Times
Also, I did a bit of a hail-mary rebuild on a friend's suspension fork (friend and fork pictured). I had to use the arbor press to disassemble it, so badly corroded it was, from sitting outside with water in it for the better part of a year. He just wanted to ride, he wasn't picky, so we cleaned it up, replaced the seals, and it appears to work fine. The air piston even holds air!
#1356
Quoted: 741 Post(s)
Liked 819 Times
Getting back on the Legnano after a busy week. We had concrete guys in all week demolishing our patio and driveway, then poured new concrete yesterday. I had to go to a day of Jury Duty in the middle of it all. Finally got the bike out today, and couldn't resist a couple of beauty shots on the new patio. Before the ride, I fixed one of the brake levers that had slipped, and re-wraped that side of the bars. After an 8 mile ride, I spent the afternoon organizing the garage. Too many bikes, they seem to fall from the sky somedays. I hung two wall mounts to free up the overloaded and inconvenient "J" hooks. With the newly poured driveway, we can't drive the cars into the garage, so I took time to spread out and reorganize. I put the bikes in the guest room for safe keeping while the workers were here. I didnt take any garage pictures still too messy, but better.😉
Tigger on guard duty.
#1357
Quoted: 293 Post(s)
Liked 218 Times
Cleaned my 5 in rotation while my two year old cleaned her C&V trike. 👍🏻🧒🏽
Likes For greg3rd48:
#1358
Quoted: 5937 Post(s)
Liked 3,643 Times
I just finished getting my mid 70s Sekine SHS 271 operational. I had to replace a spoke in the rear wheel. The bike is fairly original other than the pedals (and the consumables obviously plus the saddle). Nothing wrong with the original pedals but it's tough to beat a modern platform pedal for kicking around town in terms of comfort.
Likes For bikemig:
#1359
Quoted: 741 Post(s)
Liked 819 Times
Fixing flats on my Peugeot. I rode the bike a few days ago with no problem. I hung the bike on the rack. 4 days, later two flat tires. I saw a thorn in the front and repaired it. Nothing visible on the rear, so I pumped it up and went for a ride. Last night, the rear was flat again, so I spent today fixing that, as well as giving the chain a good clean and lube, and the gold paint, a polish with cleaner wax. All good now ... I hope. I wasn't looking forward to arm wrestling two Pasela PTs on and off, but they must have stretched a little since last time. No big deal dismounting or mounting them this time. 😎 I also fixed a non C &V problem with the power switch cover on my Garmin 810. I put a post about that on the Electronics thread on BF. Easy peasy.
Last ride before two flats.
#1360
Quoted: 1644 Post(s)
Liked 2,748 Times
Pulled this out of the acid bath...
Likes For curbtender:
#1361
Well, since riding (at least commuting) season is just about over here in Ohio, I did pick up a new set of rollers. My 25-yr-old ones finally gave up the ghost. The PVC drums had gotten warped after being stored in the attic, and the bearings were going bad... On the plus side, the new ones have machined aluminum drums and sealed bearings! I'm ready for a typical Ohio winter now!
#1362
Quoted: 1213 Post(s)
Liked 1,385 Times
Picked up my first Campagnolo Record Hi flange Mavic wheelset.... Also Record/Ambrosio wheelset.
Got to work right away breaking down the Mavic wheelset.
Ambrosio
Mavic
Before breakdown of front wheel the front hub looked like this.
After
Ambrosio
Mavic
After
Quoted: 964 Post(s)
Liked 1,453 Times
Stuck 3ttt stem in a friend's newly-acquired Vitus 979. Didn't want to ruin the fork twisting and pounding more than a certain amount, and too much alu around to use lye, so I was prudent. Had to cut it off and drill it out!
That's all that's left of it. Just happy it wasn't a Technomic, at least this was pretty short!
#1364
Bikes: Fuji Feather, KHS Urban Soul, GT Course, Specialized Sirrus, Miele Uno LS, Nishiki Bushwhacker, Wheeler Cross Line 4000, Specialized Rockhopper
Quoted: 20 Post(s)
Liked 13 Times
All I got around to was replacing a rear tire and swapping rear wheel for one with QR (to use an indoor trainer) on my Supercycle Excalibur I just picked up.
#1366
Quoted: 741 Post(s)
Liked 819 Times
Still tinkering with fit on the little 54cm Legnano Gran Premio I picked up following last year's Eroica. I usually ride a 56-60cm, and got such a good deal on this one that I thought it was worth a try. It was close enough to complete the $100 Clunker Challenge after I swapped in a longer Ambrosio stem. I found a longer seat post at the local bike swap, and now its getting close. I have a modern carbon frame that is 55cm, and with a long stem, it works fine, so I have hopes for this one. Its a fun little bike, and a little brother to my 56cm Roma Olympiade, that I've had since new in 1964.
Legnanos, little (as bought) and big. The old seat post was maxed out, but rideable, sort of.
#1367
Quoted: 378 Post(s)
Liked 1,414 Times
Swept, vacuumed and mopped a hardwood floor in 3 rooms in an attempt to find a brass washer from a Shimano 600 L DT shifter (friction). It was the same color as the floor.
The shifter is for a Shimano "A" braze-on post, and the post is compatible with few shifters, so, yes, it was crucial.
But for the shifters, the bike would be 100% polished Suntour Superbe Pro. Making it more of a concern, these shifters are polished, while many of the available, compatible shifters are painted silver.
Damn right I found it.
Likes For RobbieTunes:
#1368
Just finished putting together newly repainted Legnano mod 2.
Downtube logo is not a decal it's a "stencil".
Just took some test photos.
So HAPPY.
So HAPPY.
#1369
smelling the roses
Quoted: 7081 Post(s)
Liked 901 Times
I finally(after 5 years) got my shop arranged how I like it, and am going through my five regular riders, one at a time. With plenty of room to move! I am also repainting 'the worst paint job ever', my coupled '84 Letour Luxe.
#1370
Quoted: 4574 Post(s)
Liked 6,559 Times
Likes For merziac:
#1371
Quoted: 741 Post(s)
Liked 819 Times
Pretty bike. I have the two blue ones pictured above. Never seen a red one - stunning! I'm not a fender and chain guard guy, but those are beautiful pieces.
#1372
Quoted: 477 Post(s)
Liked 1,107 Times
This winter's project is an '84 Fuji Touring Series 3. It's near the high end of the frame sizes I ride but it will do nicely. First low trail bike I've had - about 35mm. Now I'll learn about low trail bikes. Decent shape and low miles. Mostly stock parts except for the RD. I'll swap that out for a Suntour Vx GT. Is ALL filthy with wee rust spots all over the frame. But the bearings are all pretty good so away we go.
So each day now I'm doing something on it. Taking it apart, cleaning something, sourcing replacements or upgrades (ex: removed the Fuji saddle and obtained a Vetta which is half the weight), figuring out processes (ex: OA bath for the frame). Of course I have to, daily, balance the urge to get it done against the need to stretch the project out through the March. Paint touch up will help there.
#1373
Quoted: 7410 Post(s)
Liked 2,610 Times
svoperokram that's amazing.
Likes For noglider:
#1374
Quoted: 767 Post(s)
Liked 1,898 Times
@svoperokram, beautiful! That is a stunner!
Likes For BFisher:
#1375
Bikes: 1970s Coppi/Fiorelli beater, 1973 Raleigh Competition, 1972 Bob Jackson, 1970 Cilo Sprint-X, 1985 Fuji Touring Series IV, 1969 Legnano Roma
Quoted: 222 Post(s)
Liked 199 Times
'Tis the season, it seems. So finally got around to hauling a 6' tree home (on my singlespeed beater, of course), wrapped tight in twine and slung over my back like an infantryman's rifle. And now letting it relax before any further work, but at least the tree topper is in place...
