Grail bike found!!
#126
aged to perfection
Quoted: 852 Post(s)
Liked 1,282 Times
you need to look closer. All metallic. The later nylon compression pieces matched to the chromed conical outer presser washer, slightly longer screws and one to two lock washers, Campagnolo packaged one per side to begin with and two later. Note the backing plates with the cable guides. The later simplified lever design paired with the aluminum base washer as you installed.
make sure you have all the parts in the correct orientation, and some lube is helpful
and don't forget your ref 661 spacers for brazed on bosses as your bike has
/markp
#127
Bikes: several Eddy Merz (ride like Eddy, braze like Jim!)
Quoted: 1127 Post(s)
Liked 2,005 Times
Ok
601 trick or treaters!
This is the house next-door. How do you compete with this?
I had 1000 pieces of candy. Homemade or really creative outfits get 2 or more pieces.
then I swapped out the shift lever parts.
the friction and feel was soooo much better with the nylon bits. And while I rarely question Repechage’s word, none of my other bikes have the cable eyelet on the lever stop. So I didn’t do that.
Heard a rumor of a set of DeRosa campy brake levers in a local shop’s glass case. However, said shop is known to either quote eBay for their prices (asking, not sold) or simply not sell because it’s a part of their “museum.”
I get it. It’s cool to be able to go and ogle the cool stuff. It’s rent time, so maybe a deal can be made.
lastly, I see in Andrea’s DeRosa guide the panto campy brake levers didn’t come out until 1975. But c’mon on. It would be pretty cool to have those on there. Right?
poll: Nisi or Martanos???
#128
Quoted: 3464 Post(s)
Liked 2,834 Times
Talbot’s in Palo Alto had full panto DeRosa’s for $850. in late 1974. Including levers. A club member bought two, the first one crashed in the first week. Car made a left hand turn in front of him.
#129
Liked 2,005 Times
Went to test the seat post. Didn’t fit.
not because someone used the wrong size and squeezed the flaps, well that happens too, but using the nitto tool, I spread them back to normal.
no, there was some metal inside that somehow wasn’t filed away back in the day, forcing the PO to use a smaller post.
round filed the excess and the post slides right in, pre lube!!
now to paint the flutes and panto.
I’m horrible at staying inside the lines. Luckily while still wet, it wipes right off with a lil paint thinner on a paper towel.
Not bad. Next the lettering.
"Leave the gun. Take the Colnagos."
#131
Liked 2,834 Times
#132
Liked 2,005 Times
Not my intention
both of these rims came off of 1971 or 72 bikes.
The seat post is the correct era
cranks, both FD and RD. I’m using cloth tape and an old Cinelli saddle.
the only part not 1974 or older is the XA stem from 1975.
Glasnos!!
Glasnos!!
#133
Liked 2,005 Times
So, the yellow needed some touch up where it was too thin.
out came some paper, paint and brush. Luckily I was joined by a friend. Madge.
I became worried about what to use for the detailed lettering (DeRosa) when I remembered that badger fur makes the best brushes.
Perhaps I shouldn’t have spoken out loud.
Come back. You too Greta. I said nothing about Weimaraner fur.
Anyway. A single whisker makes a fine “detail” brush.
Not a bad job. I feel a proper drink was in order. The Clover Club. Named after a Philly club, pre-prohibition.
2 oz gin
3/4 oz lemon juice
1/2 oz combiner fruit rouges
1/2 oz simple syrup
1 egg white.
2 oz gin
3/4 oz lemon juice
1/2 oz simple syrup
1 egg white.
Likes For Robvolz:
#134
Bikes: Trek 903, BMC Amp X 02, Criterion Pro Tour
Quoted: 43 Post(s)
Liked 41 Times
Wow you actually have a pet badger and a Weimaraner. Cool build but your pets are better😁
#135
Liked 2,834 Times
shifter compression parts and backing plates, caliper pad holders, you are showing post CPSC on those.
#136
Liked 2,005 Times
Wonderful thing about post CPSC pad holders, the safety plastic chips right off, revealing pre-CPSC pad holders.
#137
Liked 2,005 Times
Saddle time: I had this 1974 come in on a crashed crappy BMX bike. Surely borrowed off his dad’s bike without permission. (I know nothing about borrowing parts from Dad’s bike back in the day)
think it will do just fine.
All that’s needed now:
proper brake lever hoods (at this point, not picky) and some sew ups. I depleted this town prior to Cino.
Likes For Robvolz:
#138
Quoted: 4543 Post(s)
Liked 6,485 Times
https://www.biketiresdirect.com/prod...o-tubular-tire
https://www.biketiresdirect.com/prod...ular-road-tire
#139
Liked 2,834 Times
you will know after the plastic is removed. Do not expect all parts to be all blank or all stamped.
#140
Liked 6,485 Times
If you strip off the plastic and they don't match each other or are blank altogether, you will be chastised by some no matter what.
Likes For merziac:
#141
Bikes: 2013 Cannondale Caad 8, 2010 Opus Fidelio, 1985 Peugeot UO14, 1999 Peugeot Dune, Sakai Select, L'Avantage, 1971 Gitane Apache Standard, 1999 Specialized Hard Rock
Quoted: 548 Post(s)
Liked 473 Times
#142
Liked 2,005 Times
Rims: I was torn between some crusty Nisi + campy low flange, or Martano with Weyless hubs.
I have 2 sets of NOS large flange hubs I was thinking of swapping the Weyless out for.
But, that sounds like more work than cleaning up the Nisi.
So, I grabbed a paint stripper tool and the cordless drill. I didn’t want mastic dust anywhere in the house, and it has been a weird dreary day here in Portland, but in the mid-high 60s, so out on the front porch I went.
Lots of neighbors out for a stroll. Lots of “hey Rob, what the hell you doing?” Usually followed by “what’s in the keg-o-rader today”?
Luckily most are frightened of Madge and I get left alone enough to do my thing.
This is era correct. It came off my Dad’s 72 Colnago that I sold because I’ll never be a size 58.
How many layers of glue is this?
The stripper worked great. Dad was sloppy with the glue, and the Nisi has those lil’ divots, but I was able to get out what I wanted.
All clean
All clean
Likes For Robvolz:
#143
Liked 2,005 Times
Mail came.
I ordered this so long ago, I completely forgot about it. A panto’d silca frame pump in gold, with Derosa embossed on the side.
while it has more patina than my frame, I think it looks awesome.
Subtle. Nice, right?
Likes For Robvolz:
#144
Tinker-er
Bikes: 1956 Rudge Sports; 1983 Univega Alpina Uno; 1981 Miyata 610; 1973 Raleigh Twenty; 1994 Breezer Lightning XTR; V4 Yuba Mundo aka "The Schlepper"; 1987 Raleigh "The Edge" Mountain Trials; 1952 R.O. Harrison "Madison"
Quoted: 177 Post(s)
Liked 289 Times
I came to this thread for the bike, but subscribed for the badger.
Likes For PhilFo:
#145
Quoted: 43 Post(s)
Liked 41 Times
Yes! At first I thought, “That guy has a stuffed badger posed in his pics. Weird.” Then I thought, “Wow he has TWO stuffed badgers! Bizarre!” Now I just want to learn more about Madge and how she gets along with the dog!
Oh, and to watch the build finish.
Likes For ACHiPo:
#146
Liked 2,834 Times
Masi jumped onto the branded Silca pumps first, very soon all the name makers jumped in. Quite a bit of effort, many were painted to match, so size and color co-ordination required. Some used the raw plastic colors. This type of effort would just not happen today. The frame fit pumps later just made it more complicated.
Likes For repechage:
#147
Liked 2,005 Times
I do wish it said DeRosa vertically instead of horizontal. Like the seatpost.
#148
Liked 2,005 Times
A break was needed. Something about concerts, cleaning up the house and prepping for a dinner party.
Boil then ice bath before cleaning
Scallop crudo on shell this side
Crabs on the other
96 doms, rose and reg Krug and Cristal
Yes. Actual size.
then cleaning up the house post dinner party.
Shocked there was any left!!
finally the next day…
Me: ”hey sweetie, where are the keys, I need to run to a drug store”
Her:”What! It’s 11pm. None are open. Is it an emergency? What do you need?”
Me: “um, a toothbrush.”
Her: “what? Your dad was a dentist, aren’t there cases of toothbrushes in the basement?”
Me: I thought that too when I grabbed my toothbrush by the sink, Apparently I went through them all.”
“Up and down like the rain ‘Round n round like a choo-choo train.This is how we brush our hubs.”
After a good cleaning, starting with simple green, followed by crest plain toothpaste for a polish (use what ya got) I tried them on the bike.
Crabs on the other
Yes. Actual size.
#149
Liked 2,005 Times
I'm sure you eagle eyed vintage guys know what happened next.
Thought I'd see how they look on the frame. That's when I found out this was for a 126, not a 120. Boo.
Well, I've never gone to bed without brushing my teeth, a full tear down was called for.
These hubs had 78 stamped on them. That won't do. I grabbed my large flange set. 1974. That will do. Swapped axels and all parts which was a good thing because of the pitting I found.
Used the last of my campy grease. Wish the container was made of sturdier stuff so I could wash and re-use it to store duck-fat next to the cooktop.
Hey, just remembered I have a spare toothbrush in the glovebox. Crisis averted.
#150
small ring
Quoted: 439 Post(s)
Liked 937 Times
59 Allegro Special -- 72 Bob Jackson -- 74 Motobecane Grand Jubile -- 74 Sekine SHS 271 -- 80 Nishiki International
