Why do some people refer to some bicycles as BSO?
#151
Quoted: 1069 Post(s)
Liked 800 Times
Nah, they are pretty sucky. It's just the bar for 'adequate' performance on a bike like that is pretty low. Fortunately the demands placed on your typical $100 BSO are also pretty low.
If all you've ridden are $100 department store specials, you just don't know how much better a quality bike works.
It's when manufacturers dress up cheap bikes in flashy graphics and badly-cost-engineered 'features' that produces truly bad bikes. Passing these off as 'performance' bikes is what causes buyers to expect more of them than they can deliver.
1981 the "ELITE" Paramount Custom Touring Frame built to personal specs by PDG Waterford, wife has 1 of 3 modified Mixtie frame the "ELITE" Paramount
the following is taken from ------ https://waterfordbikes.com/w/culture...ord-1980-1994/
.................When Ed Schwinn took over the company in 1979, one of the first things he did was to shut down Paramount production. If it couldn’t be a world-class bike then don’t make one until it could.
..........Marc was put in charge of re-building Paramount – almost from scratch. He started out by retooling the department including a new brazing fixture and alignment table. In June of ’80, the company decided it needed the Paramount back but that they would have to move out of the Chicago factory. Marc’s first bikes were built for Eric Heiden and the 7/11 team in 1980.
..........That year, Schwinn brought back the Paramount as a super-custom bike – “anything you want” for the then outrageous sum of $3,000. These became known as the “Elite” Paramounts. By 1981, enough demand had built up to justify bigger plans. Marc got the go-ahead to build a factory which, after a considerable search, landed in Waterford, Wisconsin. The new factory housed what became Paramount Design Group, or PDG. Not simply a framebuilder, PDG was to become a design laboratory for both the re-born Paramount as well as the rest of Schwinn’s product lines. Frame production grew dramatically, matching all but the boom years of the early 70’s. In addition, PDG built the Sting, Schwinn’s high-end BMX race bike.......
1983 Paramount RR custom built
custom built Bassett Racing 45 speed cruiser
2013 Giant Propel Advanced SL
2018 Spec. Roubaix Expert
STRAVA 2018 miles at 9,600+
STRAVA 2017 miles at 11,000+
2002 $100.00 Target Magna 7 speed Hybrid with 10,000+ miles of enjoyable, very minimal maintenance riding from store commutes to club riding on A rides of 40+ miles at 20+mph average to 60+ mile individual rides.
I really enjoy my POS that rides like crap.
#152
Quoted: 1074 Post(s)
Liked 295 Times
If I get them early enough, I can adjust and repack all bearings to get both tolerable performance and life out of them. (Although quite often I find bearing cups that have cracked)
And I'm quite content with all the other "characteristics".
The weight, the wobbling chainrings, the single-wall rims with all the structural integrity of a disposable pie plate. All fine, for a certain kind of riding.
But the brakes can be scary. I can always choose when to (try to) go fast. And how fast to go.
A hard stop is a decision that might be forced upon me by circumstances.
I'm much happier even a tiny step up the quality ladder, into the territory of the unbranded v-brakes.
A simpler thing done well is often better than a complicated thing done poorly.
It's a bit interesting to look at the development of disc brakes.
Early brakes were expensive and often not that great.
Then we went to expensive and generally good.
Then to moderately priced and good.
And now we're getting the full range again.
Everything from expensive and great to cheap and poor.
I don't often wish for a way to hold back "progress". But I really think we might have been happier w/o disc brakes produced and used as selling points through mere existence, w/o any discernible relationship with functionality. It's cargo cult thinking, "if we add the part, performance will follow"...
#153
Dirty Heathen
Quoted: 890 Post(s)
Liked 929 Times
Well, that must be an exceptional bike if that's your go-to for A-group rides, considering the rest of your fleet. Chapeau to you, sir.
#154
Mad bike riding scientist
Quoted: 6252 Post(s)
Liked 4,278 Times
As I said above, there is a big difference in nearly 20 years between Big Box Store bikes. HelMart and Target are selling bikes in 2019 for the same price as they did in 2002. Something has to give and that is quality. They hang eye catching stuff on the bike like disc brakes (which are brakes in name only) but save pennies by short changing the important bits like bearings, axles and spindles. The bottom bracket cups will often pull apart when you try to take them off which makes removal almost impossible. The axles bend like butter on a hot day. The bottom bracket spindles twist apart along the length. And the bearings and bearing cages in the bottom bracket often grind down to dust. Not shavings but actual dust.
Stuart Black
Stuart Black
#156
Quoted: 57 Post(s)
Liked 41 Times
There are quality, well made clock radios with decent sound for the purpose they serve. A vintage good Zenith, or better make old clock radio is good for what it does, sounds OK, as does a Tivoli today. But the best always cost a little more, but in the long run is a happier purchase.
#157
Advanced Slacker
Quoted: 2764 Post(s)
Liked 2,540 Times
I don’t think all $200 bikes are BSOs.
i think there are examples of rigid bikes that are either single speed or have just a few gears in the back with rim brakes that are fine for their intended purpose: cruising around flatish neighborhoods.
Where the “BSO” honor comes into play is when for that same $200 they try to build a “mountain bike”, add suspension, disc brakes and deraileurs at both end.
These are truly MBSO (Mountain Bike Shaped Objects).
They are not mountain bikes, they are more like an idea of a mountain bike. An aspirational statement, perhaps.
They are roughly shaped like mtbs, but the suspension is so bad it is worse than none at all, the brakes suck and are no better than rim brakes (in some ways worse) and you can’t actually mountain bike with them..
Sort of like putting fake shutters on your house, except that these shutters make your house leak and then fall off.
#158
What happened?
Quoted: 1835 Post(s)
Liked 292 Times
1958 Furys are badass, argue and they'll run you down autonomously.
#159
Been Around Awhile
Bikes: Vaterland and Ragazzi
Quoted: 12 Post(s)
Liked 1,549 Times
#160
That bike served it's purpose quite well, and inadvertently served a 2nd purpose. Originally it was bought in 2005 when I was teaching my oldest how to ride a bike. I used it for 2 years riding a mile and a half out on a rail trail with her. After that it got tossed in the corner of the garage.
Many years later after outgrowing 2 kid bikes, she asked if she could ride my old bike since she was now nearly as tall as I am. So I pulled it out and dusted it off and she played around with it for a summer. The following year when the snow melted I found it out in the yard. Tossed it back in the garage.
Another year went by and I was trying to come up with some sustainable exercise. Thought of the bike, dug it out of the corner again and found the chain completely frozen with rust. I hit it with penetrating oil for 2 days and got the chain loose again. Jumped on it and rode it daily until winter hit. That was it's secondary purpose, to get me exercising on the bike. Bought my Giant the following spring and a few years of just wanting daily exercise, I found myself several hundred miles away from the car on a trial heading to my next overnight stop. 2 weeks after that and another week long trip.
Now I don't ride daily for exercise. I don't like rides less than 500 miles.
Well worth the $99 I paid.
#161
Bikes: K2 (Marzocchi/Fox), Trek 6000 (red) MARS Elite up front, Specialized Hardrock Sport -> eBike (R7 Elite up front), lastly TREK 820 loaner. Recently sold Peugeot du Monde Record and 1956 Schwinn (owned since new).
Quoted: 75 Post(s)
That was a bike, not a BSO. Inexpensive, sure - but it worked for various purposes.
BSO would have left you stranded miles from anywhere with bent or broken parts NLA ...
#164
Advanced Slacker
Liked 2,540 Times
#165
Quoted: 18504 Post(s)
Liked 15,817 Times
#166
Quoted: 44 Post(s)
Quoted: 1514 Post(s)
Liked 735 Times
A $99 bike from 2005 would be like a $79 bike from 2000. Still a BSO. Like any BSO, if it got put together correctly, it could hold up for years under easy use. Even used daily, a few miles on a mup at pedestrian speeds would be sufficiently easy to count.
#169
Quoted: 2558 Post(s)
Liked 3,056 Times
I bought and drove a 1960 Plymouth Golden Fury (top of the line) for several months working as a messenger in NYC around 1977. Translucent metal-flake rectangular steering wheel, speedo on stalks, stainless steel body (except bumpers), 395 cu. in. engine (supported by hinges in the front and a huge spring in the back, or maybe it was the other way around). The owner's manual (given to me, along with a trunkful of brand-new spare parts, when I bought the car from the original owner) noted that the "stabilizers" ("a term we prefer to 'fins' ") were designed to improve handling (above Mach 1, no doubt).
Any time I want to reminisce about how that engine sounded from the driver's seat, I need only watch "Christine" and crank up the bass.
This Car Shaped Objects can also be your best friend or your worst nightmare.
https://www.youtube.com/watch?v=oezKQEF0deY
Show Me!
https://www.youtube.com/watch?v=9aU5l2e9YlQ
Show Me!
#170
VSOs & PSOs
Yes. AAMOF.
All those Amazon violins? 95% of them cannot be made to sound decent by professionals...forget about amateurs. The fingerboards aren't even glued on straight. They are literally "violin shaped" objects....that have all the best acoustic properties of a 2x4, a snow shovel, and a chalkboard. And no one on earth can make them pleasant to listen to.
The biggest problem with cheap musical instruments is their final regulation and adjustments. I can get a violin to hold tune and I can fix an untunable piano but it might not be worth the investment in my time. Similarly, getting a cheap bike to ride well might take more work than the bike is worth... someone has to make a profit somewhere along the manufacturing and sales line.
Another big difference is that violins and pianos are mostly wood and a bit of metal. Bikes are lots of metal and cheap metal is heavy. There is no way to get those bent steel cranks lighter and those stamped steel caliper brakes will never be Ultegras.
BUT, put a world class musician on a cheap violin and they can make it sing.
Put a Tour de France cyclist on a WallMart bike and they will beat us every time.
#171
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
I am qualified to comment on violins and pianos.
https://www.youtube.com/watch?v=1HotrHNXwpE
No, they really cannot. No amount of technique and artistry can compensate for awful carpentry common in cheap VSOs. A $100 Amazon special will never sound good. A professional would all but never win or hold playing job with one....some have on lower tier equipment but not the VSO level, but they tend to have bad habits due to needing to saw and force the instrument to get tone. It is insanely hard and frustrating to get anything beyond a basic forte chicken scratch. I've had parents come to me proud of their thrift of their Prime score of a badly painted lavendar violin that had the bridge glued on and the fingerboard not even in axis--nevermind the string action entirely wrong.
Youtube video comparisons are specious at best. Compressed audio, poor microphones, poor acoustics, etc. Nothing compares to being in the room.
#172
BSOs
I cannot speak for pianos...but, violins are my forte.
BUT: are you comparing that VSO with another violin with much better strings, set up, proper sound post, good bridge, correct nut clearance..... ?
Put the $50 violin through $300 worth of set up and I would bet it plays a whole lot better (but still not worth the price)!
I am in the process of reconditioning my old LeMond Reno (their bottom end road bike) and with new wheels, a better seat and a decent handle bar it rides a whole lot nicer (for another $300).
#173
Quoted: 7674 Post(s)
Liked 3,550 Times
There is a reason professional musicians with trained ears choose better instruments ... and it is not all ego. A $62 violin with $400 worth of rebuilding would be a $500 violin .... and still wouldn't meet the needs or really talented musicians.
I could buy a $99 Walmart bike such as a good friend owns, replace the wheels, the brakes, the headset, maybe the BB, break it down to bare metal and lube and adjust every part .... and I would have a $500 bicycle. Why?
If a person's needs are met by a $99 bike or a $62 violin, great. Pretending there is no difference between a $62 violin and a $285,000 violin is ridiculous. And I have ridden enough BSOs to destruction that I know for daily hard riding they are not a viable choice.
Sadly, the way I ride now, a BSO probably Would meet my needs. But I would never try to pretend it as anything but what it was. Some people here seem to be so deep into the debate they have lost sight of reality.
I used to be a musician, used to pay in a band .... I used to have listening skills which have decayed through disuse. A lot of people have never developed those skills. But I can guarantee you a person playing a much better instrument can feel and hear the difference.
For all of the people who think pointing out that really cheap bikes are really cheap is "snobbery" if any of you own anything except super-cheap BSOs ... that is called "hypocrisy."
Walk the talk.
Walk the talk.
#174
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,099 Times
Have you ever tried commuting on a Stradivarius? The brakes really suck, and it goes out of tune turning corners.
This is a really silly analogy. Bikes are utilitarian objects, violins are not.because of the very nature of its use, subtle differences will make huge differences to all users of a violin who want to go beyond just getting it to make a sound.
Bikes are used by people for a whole lot of reasons that really don't require high levels of super-efficient characteristics. The question is whether any department store bikes are reliable enough for commuting and non-serious recreational riding, not how fast a professional rider could make it go.
#175
Quoted: 3352 Post(s)
Liked 1,056 Times
The bottom line remains, the "real cyclist" that look down on any bike that doesnt cost at least $5000 apparently dont understand not everyone has unlimited money. People will buy what they can afford. To sneer at them and call them BSO or anything else is just plain snobbery.
