The 41 refugee thread
#1776
Quoted: 8368 Post(s)
Liked 9,219 Times
I just spray Pledge on it and wipe with a rag. I never use a hose unless it's a muddy mtb.
#1777
OMC
Bikes: Specialized Allez Sprint, Look 585, Specialized Allez Comp Race
Quoted: 461 Post(s)
Liked 116 Times
If there's no caked-on dried mud, something like Pledge works well, or you can get a can of stronger but similar stuff in motorcycle shops - one of our customers runs the local Honda shop and brought us a case of it. Just spray it on and wipe it off. If there's chain grunge on the chainstay, use the solvent you've been using on the drive train, dampen a paper towel with it and clean the chainstay off, followed by the Pledge.
If you've been muddin' ...get a drop cloth from the paint section of a hardware store, spread it out on a section of uncarpeted floor, spread a bunch of rags/paper towels underneath the bike, and carefully do the bucket/soap/water thing. Or take it to a DIY car wash and use the sprayer there to blast off the mud and bring the bike home to finish it off.
Regards,
Chuck
Demain, on roule!
Regards,
Chuck
Demain, on roule!
#1778
No matches
Bikes: two wheeled ones
Quoted: 1398 Post(s)
Liked 444 Times
Be careful with pledge around the tires. I'm not sure but I would assume it would make them very slippery (pledge makes everything slippery).
#1779
Quoted: 4258 Post(s)
Liked 2,974 Times
Haven't had to do it myself, but I've heard of people taking their bike into the shower.
#1781
Mine has never been dirty enough to use a hose, so I just use some kind of spray cleaner...lately i've been using White Lightning Matte Finish cleaner. Works great and I havent had to actually buy any since the guys at the LBS let me use their stuff from time to time
#1782
Not actually Tmonk
Bikes: road, track, mtb
Quoted: 2712 Post(s)
Liked 3,276 Times
Good suggestions. Thanks!
"Your beauty is an aeroplane;
#1783
baby wipes, I've managed to do a lot of cleaning with them
#1784
¯\_(ツ)_/¯
Bikes: aggressive agreement is what I ride.
Quoted: 967 Post(s)
just damp microfiber cloth with maybe a little dish soap. I have hose access, but there's no reason to inject water into every crevice like that.
#1785
Cat 2
Bucket full of warm, soapy water with a brush or sponge. Works well then you just pour plain water out of the bucket to get off the soap. Pull the chain off if you can before doing this.
#1786
Not actually Tmonk
Liked 3,276 Times
Ah! A bucket works .
I like using soapy water and those big hydrophilic auto sponges because they cover a lot of surface and you can just squeeze them into any nook and cranny and the sponges just cover everything.
#1787
Bikes: 1979 Raleigh Team 753
Quoted: 3377 Post(s)
Liked 371 Times
I never used a power washer until this week at a cx race. Those things are fun. Think DIY car wash pressure X 3? Maybe they just had the good pumps. Hard part was keeping the bike from being sprayed away. I was truly worried about peeling the tread off the tire, and paint off the frame, so was careful with my angles. I avoided the hubs and BB, but that thing cleans a chain by getting everything off.
See video: https://www.homedepot.com/tool-truck...DEC/index.html
#1788
Cat 2
censors the website for some reason.. It's red(dit)
#1789
Not actually Tmonk
Liked 3,276 Times
I'm trying latex tubes on my race bike and have suffered my second blowout in 6 or 7 rides. The tubes are Michelin AirComps spec'd for 22-23c tires, but riding a 25 mm tire on a 24 mm width rim. I'm thinking they're just too narrow and fold up in there.
Anything else I could be missing? All together the tire+tube combo (Corsa G+ and latex) is notably fast and soft and I'm enjoying the ride. Maybe I just need to try the Vittoria 25/28c tubes instead?
Also I'm using a Topeak valve extender, don't think it matter but thought I'd mentioned.
Thanks,
Tmonk
Thanks,
Tmonk
#1790
Quoted: 842 Post(s)
Liked 469 Times
Latex is very elastic and you'll get pinch flat much easier than with butyl. I first check to make sure the tube is sitting in the tire properly, pump it up to 80 or so, inspect, then deflate and repump.
#1792
¯\_(ツ)_/¯
Quoted: 967 Post(s)
latex tubes also age incredibly poorly, so if they are old or sat on a shelf for a long time they might just be dead.
When I tried to break into my stash of latex tubes to put in my TT disc I went through like 4 of those ****ers before I found one that held. Nothing wrong with the tire or wheel.
#1793
Quoted: 2953 Post(s)
Liked 3,106 Times
I've never had any luck with latex.
#1794
Quoted: 693 Post(s)
Also, it is good advice about installation. Many people that I know who report trouble with latex have problems that stem from installation. I like the pink latex tubes because it is very easy to see when the tube is caught between sidewall and rim.
For an initial installation I like to inflate to 20, 30psi, then use my thumb to push on the sidewall, first on one side, then the other. I check to make sure the tube is not pinched. I then inflate to higher psi (70, 80) and deflate if I'm truly being careful.
After that you should be good to go until the tube is removed.
People who are used to butyl are often SHOCKED at just how easy it is to pinch that sidewall during installation, even when being somewhat careful. It's particularly common if someone is using any kind of tool/lever to assist with getting the tire on.
#1795
Quoted: 693 Post(s)
Liked 3,106 Times
This is the opposite of my experience: I get fewer flats with latex vs butyl.
#1797
Liked 371 Times
I got to change some tires for the cadets last weekend. It is pretty amazing the different tire fit between models and brands. I took a Gatorskin off and put on a Michelin. That was tough. Great tire. A cadet showed me his trick of pinching the whole beads from both sides to the center where there is more room to make things a bit easier.
I never really knew that/did that having my life spent with tubulars and tires that I can get on the rim with my hands, although quite obvious why it works better.
But latex tubes only for me.
#1798
Quoted: 693 Post(s)
That's my issue. I tried using latex tubes on my race wheels (Williams 58) and tires (Vittioria Corsa G+), which are pretty tight as it is. I think part of the problem was that these were brand new tires when I installed them, so they hadn't been inflated and rounded out.
100% it was just an installation issue. anyone who has been successful has had a problem with latex tubes before figuring out the necessary modifications to our technique. some people move on before figuring it out, though.
it's worth it.*
* - except maybe when you are traveling an only have access to a mini-pump... then it is super annoying to have to try to get the tire back up to the right pressure before every ride, when a butyl tube needs just a couple pumps.
#1799
Liked 371 Times
@tetonrider - I agree on the latex tubes - for racer junior, for old guy me.
But recently having experiences with near 10 different tire combos - those matter easily as much. Those going to latex tubes should also be going to supple tires.
#1800
Quoted: 693 Post(s)
latex tubes, though, will improve any setup, regardless of one's chosen tire.
