The 41 refugee thread
#1826
i've really been eyeballing the specialized allez to replace my old road bike, but the geometry appears to be more relaxed this year, so I'm trying to decide if the 54cm would be right for me, versus the 56. The reach of the 54 is 380mm, similar to my 56cm cross bike (which I really like) and 570mm stack (583 on the CX, although it has some spacers).
The 56cm version of the allez has a reach of 385mm and stack of 596mm and apparently 175mm cranks (I use 170 on my road bike). My current road bike has a stack of 55cm and a reach of (I believe) 385mm and I have a +17 120 stem on and saddle height of around 75cm from BB.
Anyway, I realize it's a lot of numbers, part of the problem at the moment is that no local shop has both sizes for back to back comparison, so trying to do my homework beforehand, I'm leaning a little toward the 54 as it seems to be a good balance between racing and endurance whereas the 56 seems straight up endurance geo.
#1828
I don't understand why cyclists wear gloves when its warm. Hand protection? Really? Speeding around corners at 30mph wearing next to nothing but you're worried about fingers, the last thing to ever touch the ground? If you are reaching for the ground with your hands in a crash you're doing it wrong and gloves aren't gonna save them.
#1829
OMC
Bikes: Specialized Allez Sprint, Look 585, Specialized Allez Comp Race
Quoted: 461 Post(s)
Liked 116 Times
Reaching for the ground is instinctive regardless of whether it's right, and gloves do help a lot by getting torn up instead of your palms.
Regards,
Chuck
Demain, on roule!
Regards,
Chuck
Demain, on roule!
#1830
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times
Depends on the crash. Sometimes you reach out, sometimes you don't. In any case, gloves absolutely help keep your hands from being so bloodied. I can cover most of my road rash at work, but I prefer not looking like I just got out of a cage match.
#1831
Quoted: 1853 Post(s)
Liked 680 Times
#1832
When it's really hot and humid, having gloves also gives you better grip. The sweat sometimes won't dry from your hoods and bar tape.
#1833
Someone on another subforum here made a neat bike geometry web app, and the 54cm allez and my current bike as it's currently set up are not too far apart fit wise (hopefully the link works), which is why I was kind of vacillating.
https://www.bikegeocalc.com/#7Unname...9F172.5G30H30Z
#1834
Quoted: 4276 Post(s)
Liked 3,000 Times
Plus, when your ride takes an unplanned veer onto a dirt road (just because you want to see where it goes) and you end up with enough dirt/sand stuck to your tires that they rub on the bottom of your break, a leather protection on your finger is nice to quickly rub off the dirt and stop that annoying rubbing noise.
#1835
Liked 680 Times
Oh, I'm trying to get an overall less aggressive geometry, just don't want too relaxed.
I prefer bikegeo.net
#1836
No matches
Bikes: two wheeled ones
Quoted: 1398 Post(s)
Liked 444 Times
#1837
Liked 680 Times
I separated my shoulder and smacked my head, which most likely contributed to my hearing loss in my left ear. Also, my wife is convinced I concussed myself. I'm not sure how things would have gone had I put my hand out.
#1842
Quoted: 2953 Post(s)
Liked 3,106 Times
I once crashed with my hands on the bars and it tore up the back of one of the gloves. I still have the scar on my knuckles.
#1843
Cat 2
Hands on bar crash was the only time I've ever broken a bone. Slammed hand into ground between bars + concrete = spiral fractured bones in my hand. Didn't hurt that bad, but the repairing of it was... uncomfortable.
#1844
smelling the roses
Quoted: 7081 Post(s)
Liked 901 Times
#1846
Not actually Tmonk
Bikes: road, track, mtb
Quoted: 2798 Post(s)
Liked 3,398 Times
Road rash on your hands is a thing and gloves can protect. Yeah if you slide for meters with your hands pressed into the ground your gloves will get worn through but they help with scrapes.
I generally prefer to not wear gloves, I like to feel the bars more. I wear gloves in the following circumstances:
Road and crit racing
Track racing
MTB
when it's cold out.
-Tmonk
Track racing
MTB
when it's cold out.
-Tmonk
"Your beauty is an aeroplane;
#1847
Not actually Tmonk
Liked 3,398 Times
My PM (Powertap G3) has been reading high while coasting lately, taking a while to drop down to zero. Like I might coast for 10s and it will still bounce around between 1-10 watts before finally dropping down. Any ideas?
I saw something on Quarq's website (now Ptap owners) about some latent charge buildup or something that can be discharged by connecting one of the terminal battery leads to another piece of metal with some pliers or something to ground. Maybe that will work? I already tried replacing the watch battery.
#1848
Quoted: 140 Post(s)
Liked 327 Times
#1849
Not actually Tmonk
Liked 3,398 Times
Yeah, I've done that before (a few years back) and was hoping that it wasn't that... I'm also not to keen on how that will work post Quarq acquisition, like I'm not seeing anything readily available for that on the website. I can call in.
#1850
Not actually Tmonk
Liked 3,398 Times
Hey guys,
I'm considering getting a new road bike (frame) before I start base training just to make things more exciting. I have a low tier venge with aero bits, so this bike will be used as a training/daily driver/high QOL bike and not to race, except maybe once or twice per year in particularly hilly events. I'm currently on a 2013 TCR Advanced ISP and it's the finest bike I've owned.
I want something that is similarly low-tech, quick release, rim brake. Might get some Di2 for it, so it would need to be compatible w that. Doesn't need big clearance, might prefer it without that.
Any suggestions? Testimonials? I would not shy away from another TCR, but would also consider a tarmac, emonda, supersix, or something entirely different out of of those bike three, if I found the paintjob exciting.
Many Thanks,
Tmonk (David)
Many Thanks,
Tmonk (David)
