Random Thought Thread, aka The RTT (**possible spoilers**)
Bikes: Trek 1.2
Quoted: 25 Post(s)
The chainrings are not worn - I only have 1500 miles on the bike. The chain is seriously wedged between the small chain ring and the bracket, it will not budge. Last week when I rolled it down to the LBS they said they would have to take off the chainrings but then the mechanic pulled on it with an allen key and it popped back on the small chain ring.
I may ask the LBS about a chain catcher. Or maybe I shouldn't suggest anything and see what they recommend. Then I could ask about a few of the things that are mentioned here. If changing the tension on the cables to adjust the FD is all it needs, that could be great and I could probably do that myself.
![Gramercy is offline](https://www.bikeforums.net/images/statusicon/user_offline.gif)
I read your post in the mechanics forum, and I'm not sure I followed. Is your chain dropping on the inside and getting stuck there?
"Chain suck" is typically used to refer to the chain hanging onto the underside of the inner chain ring, and getting pulled up and trapped against the chain stay. It happens on mountain bikes with mud. It's pretty rare to happen on a road bike, unless the chainrings are seriously worn.
If you're actually having chain suck on multiple occasions, you need to look at replacing the inner chainring.
If you're dropping the chain to the inside, there are 3 things to consider. First and foremost, is the FD adjustment, most notably the limit screw. Second is consider how you're shifting if you go all the way to the biggest cog in the back before shifting from the big ring to the little ring in the front, the resulting chain line makes it more likely to drop the chain, and Third would be to consider a chain catcher, such as a Deda Dog Fang.
For a chain watcher if you have a round seat tube I think the N-Gear Jumpstop is the best out there. The metal cage and separate horizontal/vertical/twist adjustment is key.
If you don't then I think K-Edge has a similar thing but not sure what it works with.
nvm, it's for round tubes also:
Road Clamp-on Chain Catcher - Road - K-EDGE Chain Catchers
I bought a regular k-edge and it's next to useless compared to the N-Gear. With the N-Gear I can adjust the derailleur to hurl the chain into the small ring and never have it fall off. With the k-edge you can't do that, it moves pretty easily.
"...during the Lance years, being fit became the No. 1 thing. Totally the only thing. It’s a big part of what we do, but fitness is not the only thing. There’s skills, there’s tactics … there’s all kinds of stuff..." Tim Johnson
![carpediemracing is offline](https://www.bikeforums.net/images/statusicon/user_offline.gif)
pan y agua
Quoted: 1483 Post(s)
Liked 768 Times
Doubt you need to change the tension on the cable. You likely need to adjust the limit screw, so that the FD can't move as far inward.
You could get lost and die.
You could hit a tree and die.
![merlinextraligh is offline](https://www.bikeforums.net/images/statusicon/user_offline.gif)
Quoted: 15 Post(s)
Liked 27 Times
if this works, it's not such a bad idea (for once) for commuters.
A Foldable Bike Helmet You'll Just Happen To Have In Your Bag : All Tech Considered : NPR
![botto is offline](https://www.bikeforums.net/images/statusicon/user_offline.gif)
Batüwü Creakcreak
Quoted: 230 Post(s)
Liked 289 Times
I don't have as much 'pre-pm' data, but seeing my power profile and training with the PM totally changed what I thought about my own abilities.
I'd like to think it made me train more efficiently as well.
![ridethecliche is offline](https://www.bikeforums.net/images/statusicon/user_offline.gif)
Powered by Borscht
Bikes: Russian Vodka
My PT had an opening for today and squeezed me in. Can't wait to start!
![ovoleg is offline](https://www.bikeforums.net/images/statusicon/user_offline.gif)
Making a kilometer blurry
zero to nonzero anyway (no wins for 14 years, then a dozen or so in a big hurry)
![waterrockets is offline](https://www.bikeforums.net/images/statusicon/user_offline.gif)
Quoted: 1853 Post(s)
Liked 680 Times
I followed Fudgy's lead and ordered some fancy, semi-custom shoes. And Paypal offered me the option of six months same as cash. So I am financing a pair of shoes.
On a separate note, I noticed yesterday that all the students have left for the summer. This is now the best time of the year.
Finally, Time Warner Cable decided it needed to install new cables, which means digging across my front yard and tearing up the grass. It's only taken me five years to get a nice, stable lawn mostly free of weeds. It's no big deal to dig it up.
Also, they have to tear up the driveway. Fortunately, my wife saw them start jackhammering and ran out to have them stop so she could pull her car out of the garage first. They were just going to tear up the driveway without telling us. It didn't matter that our cars might have been in the garage and stuck there until they fixed it.
![topflightpro is offline](https://www.bikeforums.net/images/statusicon/user_offline.gif)
Bikes: Yes
Quoted: 9 Post(s)
They have no right to tear up your driveway if it's on your property even with a right of way. They can use a power tunneling device which won't disturb the pavement. They won't use it unless you demand it because it costs more than a lunkhead and a jackhammer.
![shovelhd is offline](https://www.bikeforums.net/images/statusicon/user_offline.gif)
Quoted: 4281 Post(s)
Liked 3,007 Times
That'd be good to know.
Bikes: 1996 Eddy Merckx Titanium EX, 1989/90 Colnago Super(issimo?) Piu(?),1990 Concorde Aquila(hit by car while riding), others in build queue "when I get the time"
![himespau is offline](https://www.bikeforums.net/images/statusicon/user_offline.gif)
Liked 680 Times
In other news, I'm thirsty and need to go to the bathroom, but they shut off the water to our building this afternoon to do some road repair work.
![misterwaterfall is offline](https://www.bikeforums.net/images/statusicon/user_offline.gif)
Bikes: Yes
Quoted: 9 Post(s)
So if you repave your driveway, they will pay for the first 8 feet? I still say if you screamed loud enough they wood have tunneled it.
Bikes: It has two wheels
![Big Grin](https://www.bikeforums.net/images/smilies/biggrin.gif)
![JohnKScott is offline](https://www.bikeforums.net/images/statusicon/user_offline.gif)
Trying to cut out all caffeine and most processed sugars in my diet after I crashed and burned energy wise over the past week. Day 3 of no coffee/tea and I'm feeling better. Anyone else cut this stuff out periodically?
Quoted: 693 Post(s)
"you have no restrictions. let pain be your guide," sez my doc.
probably not the best thing to say to the guy who traveled 12+h on a broken femur.
![Smilie](https://www.bikeforums.net/images/smilies/smile.gif)
![tetonrider is offline](https://www.bikeforums.net/images/statusicon/user_offline.gif)
Bikes: Giant TCR, Giant Anthem, Felt CX
Quoted: 65 Post(s)
I hope it will help me. I'm going from zero information (no HR or anything) to All the Information lol. I'll have lots of free time to figure it out after school gets out in a few weeks!
![rideaz is offline](https://www.bikeforums.net/images/statusicon/user_offline.gif)
Super Moderator
Quoted: 1175 Post(s)
Liked 938 Times
We have a job opening for a PHP developer in case anyone's interested.
![Homebrew01 is offline](https://www.bikeforums.net/images/statusicon/user_offline.gif)
Quoted: 842 Post(s)
Liked 469 Times
I've been on a really bad sugar and caffeine kick of late. When I lost 40 pounds, I eliminated junk sugars, and all but my morning coffee. I say junk sugars because its close to impossible to eliminate it entirely. Now its back into full addiction swing where I am craving junk food.
![furiousferret is offline](https://www.bikeforums.net/images/statusicon/user_offline.gif)
These Guys Eat Oreos
Bikes: Yes
Quoted: 13 Post(s)
![Creatre is offline](https://www.bikeforums.net/images/statusicon/user_offline.gif)
out walking the earth
![gsteinb is offline](https://www.bikeforums.net/images/statusicon/user_offline.gif)
Quoted: 2953 Post(s)
Liked 3,106 Times
I have not, but I've heard from friends who have that they had really bad headaches for the first few days. Did this happen to you?
![caloso is offline](https://www.bikeforums.net/images/statusicon/user_offline.gif)
Super Moderator
Liked 938 Times
Drink decaf and pretend it has caffeine.
**** that
Quoted: 1099 Post(s)
Liked 104 Times
However, it seems like you should only eliminate one variable at a time (caffeine or sugar) to see which one is messing you up.
![mattm is offline](https://www.bikeforums.net/images/statusicon/user_offline.gif)
