Soul Wheel Owners... Post your pics
#526
I am 165lbs and deciding whether the S2.0, S3.0, or the S3.0SL will be the perfect wheel set for my daily training. I am here in Toronto and roads are pretty flat here, maybe some false flats though.
Any comments?
Any comments?
#527
I've had the S3.0 Xpert and the S2.0 SL. The S2.0 SL is one of the lightest set of clinchers out there at 1330g. The rear has stayed true for me, but I've had to adjust the front a few times. Overall, it seems like there isn't enough spoke tension in the front because both times the front needed adjustment, it was due to a loose spoke.
The S3.0 Xperts were great for me. I kinda miss them! They rolled real smooth, climbed well, and took some serious abuse and never went out of true.
Bob
Bob
#528
Bikes: Felt AR1, Cervelo S2
Quoted: 17 Post(s)
After a few thousand miles:
S2.0s are great, stronger than they look. Stood up to Flatbush Avenue this Tuesday like it was nothing.
C5.0s are also great, but are a little more flexy. I notice it only out of the saddle on climbs. Might be my fault, rocking the bike too much.
I had a small problem with pawl springs but Sean, of course, handled it perfectly and quickly.
#529
Bob
Bob
I see you had the S3.0 Xpert, what happened to that wheelset? No good and sold it? Were those S3.0 Xpert 'aero' enough that you noticed the difference?
#530
As far as aero, I didn't really notice because I had them on a bike that I mostly use for climbing. Sorry...no help there.
Bob
#531
In that case, do you feel the S2.0 is a better wheelset for climbing?
#533
Quoted: 24 Post(s)
I noticed Soul uses the red nipples upon request. ALL the wheel builders that I've spoken to including two on this site, say that it's not a good idea, due to the material used on these nipples. Is SOUL using a special material? Psimet and Boyd wheels have both rejected my idea to use red ones, due to durability issues...Let me put it this way...they strongly suggested not to use the red ones!
#534
^^^ They must have their reasons, but I can't see why color would make a difference. All of the recent Shimano stuff (WH-7850, RS80, etc) have red nipples and I know people who have run those wheels for years with no problems. I'd be curious to hear about the reasoning behind. Anodizing process weakening the material?
ahson: Yes, I feel that the S2.0SL is a better climbing wheel than the S3.0 Expert. A nice compromise would be the S3.0 SL. You get the deeper rim and it's only 60g heavier than the S2.0.
Bob
Bob
#535
Bikes: A couple
Quoted: 38 Post(s)
#536
Bob
Bob
#537
Come on you Spurs!
Bikes: Trek 2.1, BMC Roadracer SL01
I put about 3000km on my set of 3.0SL this year and they hold up perfectly. I ride about 200km a week, mostly paved roads with some bumpy sections. I weigh 180lbs (82kg).
#538
Have you ridden the 3.0SL across rail tracks, speed bumps, pot holes? Are they still holding up perfectly after all those abuses? If so, I rather go with the SL than the Xperts because of their weight difference. I asked Sean about this, but somehow he recommended me the 2.0 Max or the S3.0Xperts which both of them are some heavy wheelsets. By the way, I am 165lbs.
#539
These 3.0SL claimed to be 1400g on Soul's website. Ummm..
#540
The 2.0 SLs came in at 1341g on my scale (which has always read a touch high) with no decals. Advertised weight is 1330g, so I consider 1341g to be ok.
The 3.0 Xperts came in at 1560g with stickers vs the advertised 1540g. Again, within 1%.
For reference, Mavic Ksyrium SLs are advertised at 1463g and weighed 1505g on my scale.
I did an organized century about a month ago on the 2.0 SLs. 7000+ ft of gain and they took some serious abuse. There was a 13 mile section of road with nasty potholes hidden in the shade, about a dozen cattle guards, and ruts. The rear stayed perfectly true. The front came out of true, but I noticed that one of the spokes had come loose. After tightening it, the wheel was dead straight again. I'd consider the 2.0 SLs tough enough for daily riding.
Bob
Bob
#542
Bob
Bob
#543
Bikes: are better than yours.
Telemachus has, indeed, sneezed.
#544
S2.0SL vs S3.0SL: Does rim height (25mm vs 31mm) make a noticeable aero difference on a bike? If not, I rather go for the S2.0SL for their light weight and durability.
#546
Come on you Spurs!
King Hoternot
Bikes: 2015 Cannondale Evo Hi mod
Quoted: 127 Post(s)
King Hoternot
Quoted: 127 Post(s)
King Hoternot
Quoted: 127 Post(s)
