Is my brain getting addled with old age or is DT awesome for hills?
My 1995 Trek 520 came with STI shifters, which was blasphemy in the touring world - not field fixable, etc. Trek quickly went back to bar end shifters on the 520, still has them today.
But, I loved STI and in 20+ years had one problem with the front (left side in the US) shifter not moving. A good soak in WD40 cured that, never had a problem on the rear shifter. I'd never go back to having to remove my hands from the bars to shift
Voice of the Industry
Quoted: 1188 Post(s)
Liked 8 Times
I've been running STI since 9 speed systems were the big thing. I'm a huge fan and have used various Shimano and SRAM levels on my bikes over the years.
However, I've found the occasional failures (usually every 20-25K miles at some inopportune time) to be a pain because all the field fixes wind you limping home with a lot less gear selection that you'd like and an expensive purchase to look forward to.
The last time my Rival lever broke (3rd failure for that type) a few years ago on my workhorse commuter, I decided I was tired of buying levers and switched that bike back to DT. I live in a city and work on a steep hill and found that 1 tooth clicks really weren't optimum for commuting at uneven speeds or for hills as I found a huge percentage of my shifts required skipping cogs.
I'm finding that for at least that sort of riding, I prefer DT to integrated shifting. Taking a hand off the bar is a minus but the actual shift is faster than STI, I've never thrown a chain or missed a shift, and the reliability is bombproof. I still run Ultegra on my race bike which I still prefer for environments where my effort and speed are more consistent.
I'm wondering if I'm the only one who actually thinks DT is a superior way to shift for certain types of riding, or if I'm sliding toward retrogrouchiness?
Quoted: 18883 Post(s)
Liked 10,646 Times
I'm using Di2 and loving it.
Sunshine
Quoted: 10972 Post(s)
Liked 7,499 Times
All seriousness- Microshift 7, 8, and 9 speed shifters are designed to have 2 dedicated shift paddles and the brake lever. I love em. No braking with the shift lever.
Liked 10,646 Times
just another gosling
Quoted: 3895 Post(s)
Liked 1,945 Times
When I was first doing long rides, I was out on my steel DT bike and got dropped by a guy with brifters. I was holding his wheel fine as long as the slope stayed steady, but he easily dropped me in rollers when he just outshifted me. Besides the weight, that was a big reason I bought a modern bike. I still have a bike with bar-ends, which is better than DT as long as one's fit is for the drops, like used to be standard.
I've worn out a couple STI right shifters. I think ~25K of all-weather riding is about it for them. But then I've never ridden more than 5k a year, so no big deal. Maybe Campy is more durable? Don't know. Now there's Di2.
Results matter
Results matter
Quoted: 1067 Post(s)
Liked 259 Times
My main observation with DT shifters is that when I ride them I shift gear less often due to it being less convenient.
Their only performance advantage is that they are simpler.
So if I was depending on my bike to keep going as I cycle around the world through 3rd world countries I may consider them. But I am not.
NYC
Quoted: 1169 Post(s)
Liked 107 Times
Especially when racing cross, I absolutely despised the 105 (10sp) shifting with heavy, wet, muddy gloves and numb fingers.
Liked 10,646 Times
I don't feel bad about myself. I don't have much reason to. But thanks for the affirmation anyway, @nycphotography.
I remember using DT when climbing way back when. You're out of the saddle grinding away in your 39x21 and you want to shift to your granny gear (39x23!) so you have to sit down, shift, then stand back up and try to pick up speed again. Yeah, I don't miss DT at all.
Bikes: Garmin/Tacx Bike Smart
Quoted: 646 Post(s)
Liked 289 Times
Give Di2 a shot and you'd never even think about downtube. I think the appeal is nostalgia, at best. I'll pass.
I get where bannerjek is coming from. Commutes are short with lots of stuff happening during the rides. I recently got a cross bike (for the disc brakes), and built up a new wheelset. Didn't know that 11sp mountain hubs were different than 11sp road hubs (for shimano; the 11sp mountain hub is identical to the 10sp road hub) until I had built up the wheel. The only road cassette that fit was an Ultegra 11-34 11sp cassette; I've never used a cassette that had 2 tooth gear skips all the way up.
Turns out I don't miss the 1 tooth skips on commutes. The 2 tooth skip cog works really well, for the same reason downtube is attractive. From a stop to cruising speed, I only need 2 or 3 gear changes, as opposed to a true road cassette where you need 4 or 5.
Cat 2 Track, Cat 3 Road.
"If you’re new enough [to racing] that you would ask such question, then i would hazard a guess that if you just made up a workout that sounded hard to do, and did it, you’d probably get faster." --the tiniest sprinter
Quoted: 283 Post(s)
Liked 262 Times
I still like a friction shift on the front mech, whatever on the rear. Never had a prob with DT friction shift on both. If you explain about "lighten up the pedal pressure, shift a bit too far, then back a bit when the chain is on the cog" you get a look like you're from Mars.
well hello there
Quoted: 503 Post(s)
Liked 336 Times
best of both worlds
Quoted: 4423 Post(s)
Liked 1,569 Times
I like DT shifters. But I don't see why STI should shift "slowly" in comparison. My bikes don't.
Bikes: Surly Disc Trucker, Ribble Nero Corsa, Surly Karate Monkey, Surly Ice Cream Truck, Cannondale MT800, Evil Insurgent
Quoted: 186 Post(s)
Agreed totally. I would not even ride a drop bar bike without integrated shifters. Having the gears at my fingertips is integral to the enjoyment of any kind of geared bicycle, for me. I understand that others may have different preferences, but I do not share those preferences, at all.
Yes it is a paradox
Bikes: Trek, Orbea,Specilized
I can't hear well enough to operate a friction DT. When I was younger I remember having to use my hearing to ensure I had made a good quiet shift. Remember having to do a great deal of maintenance to the shifting system to keep it working properly. Glad to have left friction DT shifting.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
I've only known DT shifters so I can't speak to Brifters. But newer is usually better for good reason. The Ultegra DT shifters (and the rest of the Ultegra kit) have been 100% reliable over the 25+ years I've ridden them. But there are certainly disadvantages in climbing. When finances allow, I'll move up to a bike with modern geometry and shifters.
Quoted: 4560 Post(s)
Liked 2,802 Times
When I was first doing long rides, I was out on my steel DT bike and got dropped by a guy with brifters. I was holding his wheel fine as long as the slope stayed steady, but he easily dropped me in rollers when he just outshifted me. Besides the weight, that was a big reason I bought a modern bike...
My only road bikes have had downtube shifters. My first, in the 1970s. Well, that's all anyone had then. When you hit the rollers you did what everyone did -- sit and mash or stand up and dance. There was relatively little shifting. If you needed to shift you sat, shifted, then either stood again while trying to minimize the loss of momentum, or double shift down and sit awhile to mash.
Tricky business with 10 speeds -- meaning, two chain rings, five cog freewheel. Especially those corncob freewheels. That's when I discovered why all the grand tour racers did that painful looking rock-and-roll thing, bobbing up and down, side to side, grinding everything they had into a 21 tooth "big" gear. No wonder they looked constipated.
I remember Lance Armstrong switching back to downtube shifters for some mountain stages, supposedly to save a bit of weight. I watched him powering up those climbs, moving seemingly effortlessly between sitting and standing, rarely shifting, and never doing that painful looking 1960s style rock-and-roll thing with hands clutching the top bar (basically, how Chris Froome *always* looks on climbs, like he's trying to pass both gas and competitors simultaneously).
Ah, to be that naive again. Turns out all I needed was the confidence of youth, EPO and cooperative insider help to go with those downtube shifters.
Despite it all, when I got my only other road bike, ever, last summer -- an '89 Centurion Ironman with 14 glorious speeds and a bike weighing only in the low 20 lbs and with indexed shifting -- I figured I was ready to kill on the moderately fast-ish local B group rides, despite my grey hair and creaky knees.
Nope. Not even close.
Oh, I did okay on the flats and modest continuous 1%-3% grades. For about 10 miles.
But as soon as we hit the rollers at the 10-20 mile stretch I got dropped. Every time. By folks pretty close to my age (60), not just younger, stronger riders.
I was losing momentum with the downtube shifters. I watched the others and they could seamlessly, effortlessly shift up and down, climbing out of the saddle for a few strokes to maintain momentum, then shifting *while* standing or as they sat. I couldn't do that.
Yeah, okay, the carbon frames and clipless stuff probably helped, compared with my old school stuff.
So roller by roller, one 50 yard long 6% climb at a time, over the miles, I dropped farther and farther back, until I couldn't bridge the gap anymore on the downhills and flats. Usually I could hang on for about 20 miles of their scheduled 50-60 mile rides before I fell off the back and went my own way.
Gimme brifters. I may keep my Centurion Ironman stock, but my next road bike will have brifters, if only for those fast-ish group rides (hey, I'm old and asthmatic, and 17 mph over a 50 mile ride is fast for me).
