Camera recommendations
Quoted: 5233 Post(s)
Liked 3,601 Times
not to hijack the thread, but ...
for my helmet I use a flat base dash ball socket mount
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
wrap it around the top of the helmet w zip ties
since that's no longer available, this looks promising
https://www.amazon.com/iSaddle-Threa...m+mount+holder
add and "extra" thumb screw to the bottom of the sportcam (because it attaches better to the camera than the generic screw that came with the flat plate mount)
https://www.amazon.com/SmallRig-Came...00CBSL30K?th=1
not all generic threaded mounting screws are equal that's why I use a good quality long photo thumb screw when using these generic type mounts
screw both together & adjust tension & aiming
for mounting on the bars, I use the device that came w my camera, it's been very durable & I can use the OEM quick release slide mount. this is fun cuz I can slide it off while I'm riding do some hand held stuff then slide it back on
add the screw on QR plate to the camera. this screws on very nicely & holds tightly
join the camera to the mount by sliding it on
there are positives & negatives to all mounts. I almost prefer to hand hold the camera but that's not always practical
for use in the car I use the flat dash mount w a beanbag style dash mount (from Best Buy) left over from my TomTom GPS. I just add some velcro
Quoted: 4560 Post(s)
Liked 2,804 Times
I rigged up a helmet mount using one of the accessory shoes from the Ion Speed Pro kit. It's fastened to the helmet with zip ties and heavy duty Velcro tape. The Ion has an ultra-wide, near-fisheye lens, so aiming isn't critical.
There's a ball head accessory for helmets but it sits up higher than I want. The homebrewed mount sits closer to the helmet.
If anyone notices they usually ask whether it's a camera or light. Hard to tell at a glance because of the cylindrical shape. I also have lights on the helmet: a small, lightweight headlight on front; a Blackburn 2'Fer on the rear. Both are mostly to-be-seen lights, although they can serve in a pinch to read a map, check my wallet, or illuminate whatever the camera sees up close.
Liked 3,601 Times
that's tempting, if it's not a bother, would you be kind enough to throw up a pic if you have one. lately I only mount mine on the helmet if I'm riding where there are no ppl cuz it looks so dumb. usually is an unpaved rail trail which is rough terrain so bar mounted isn't ideal anyway. or at night. the bar mount is good on the smoother paved roads. wish mine was a dark color too. the white kinda stands out, which is ok as a deterrent when I have it pointed back toward overtaking traffic. but sometimes I prefer to be more stealthy
Bikes: ...a few.
Quoted: 2012 Post(s)
Liked 410 Times
Here's a shot of mine:
Liked 3,601 Times
Liked 3,601 Times
FWIW - I can confirm iON Camera mounts are 100% compatible with the Polaroid XS100. bought the iON Camera 5007 Mount Pack so I could get a lower quick release mount on my helmet
Quoted: 7359 Post(s)
Liked 2,497 Times
What do you typically have to do to turn these things on and off? Swinging my leg over the bike is already involved enough these days.
Liked 2,804 Times
Also the Ions vibrate to confirm any switch movement. This is usually palpable by hand even with thin gloves on, and sometimes through the helmet or even on the handlebar, depending on road vibration, etc.
There's an LED light, red for record, green for on but idle.
There are other miniature controls and ports under the rear weather-sealed cap, but don't often need to be switched in position. The cap needs to be removed every time to recharge the battery, and to either transfer/delete the recordings, or to remove/reinsert the media card.
Overall it's pretty simple for no-look helmet use. With a fully charged battery and enough room on the media card it'll run continuously until the battery is exhausted (usually 90-120 minutes), or the media card is filled. With an empty 16 GB media card the battery will run out first, unless an external battery pack is used. Probably not necessary for most commutes.
Bikes: ...a few.
Liked 410 Times
The only problem is the bolt hole at the bottom of the camera. It's plastic and I wouldn't trust it unless I had a secondary method of securing the camera onto whatever platform I'm using.
Liked 3,601 Times
yeah that that threaded hole is weird. it holds perfectly w the supplied quick release clip which screws on, that's why I was excited to get the iON Camera mount kit w another QR clip. like I stated above when I use the threaded hole on the camera for other stuff I use an aftermarket good quality long photo thumb screw. I tried a few & found some work better than others. but it's really weird that a regular tripod screw just spins. whatever is going on there may have been intentional. the only thing that comes with the original camera that is supposed to screw in is that QR
Bikes: ...a few.
Liked 410 Times
I never actually tried to use the QR. That QR clip requires another mounting bracket which I did not have. I already had the handlebar clamp. I thought these threads were pretty standard for cameras of all kinds.
Liked 3,601 Times
Yeah, I used an aftermarket handlebar clamp mount, and it was off of this that the camera became dislodged, twice.
re: QR clip requires another mounting bracket - you might be interested the iON Camera 5007 Mount Pack includes these items. I bought it for the circled items only
Bikes: ...a few.
Liked 410 Times
That looks a little bit more classy than my zip ties, but I'm still not convinced the bolt hole is going to hold up to use.
Having said that, I might be in the market for a second Ion for seat post for the rear. I'm trying to figure out how I might mount it there.
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4343 Post(s)
Liked 3,003 Times
Liked 3,601 Times
Liked 3,601 Times
got the iON brand Contour ROAM3 Waterproof HD on my wish list for a long time now
https://www.amazon.com/dp/B00METYIQ2...XFURGNTS&psc=1
Bikes: ...a few.
Liked 410 Times
Yeah, too late. I already stripped it from using the handlebar clamp. Maybe on my next one...if I opt to get another.
Bikes: ...a few.
Liked 410 Times
I'm curious how the sound quality is on your Polaroid. The sound is very poor on my Ion. Barely picks up anything over the wind noise, and even when standing still indoors it's not good.
Liked 3,601 Times
seems OK for what it is, party voices, picks up my voice better than other people's but I can hear them if they are withing range, fairly subtle road sounds from inside the car on the dash, but I will say that when I am on a bumpy road I get a buzz when mounted on the bars. wonder if that's cuz I've dropped it 1 too many times ...? most of my road bar clips sounds OK, but sometimes I hear some buzz working it's way in, handheld it doesn't have the buzz & can still pick up the sound of the crunchy snow, or the sound of the studs on dry roads, yes you can hear the wind too
Liked 3,601 Times
Bikes: ...a few.
Liked 410 Times
party voices
https://www.youtube.com/watch?v=4D4nesxLKWk
https://www.youtube.com/watch?v=7oocCsMqD_c
https://www.youtube.com/watch?v=u39MlxZdAP4
self explanatory sound
https://www.youtube.com/watch?v=oB3scpa5ud0
https://www.youtube.com/watch?v=5cnltSQDBN0
most of this clip sounds OK, but I hear some buzz working it's way in
https://www.youtube.com/watch?v=Ar3RDH7SVgo
https://www.youtube.com/watch?v=Hq6Io7_6ypg
https://www.youtube.com/watch?v=9HhL3m-HTIA
party voices
Liked 3,601 Times
Liked 3,601 Times
Señior Member
Bikes: Windsor Fens, Giant Seek 0 (2014, Alfine 8 + discs)
Quoted: 446 Post(s)
Liked 8 Times
Fly6 is good on the back. Up front, no perfect cameras currently as far as I know, but I haven't been looking for a while. The Contour Roam was good when they were available. Now it seems like none of the waterproof camera choices consider anything longer than an average downhill ski run to be worth putting batteries in for.
I'm kind of thinking about setting up a Mobius in a DIY waterproof case and USB power source.
Work: the 8 hours that separates bike rides.
