Show us your Peugeot PX10 !
#576
rmfrance
Bikes: 1968 Peugeot PX10, 1974 Peugeot PX10, 1964 Peugeot PX10, 1977 Peugeot PSN10, 1975 Gitane Super Olympic, 1978 Gitane Vuelta, c1958 Gitane Competition(?), 1983 Mercier?, 1981 Peugeot PF10, 1985 Peugeot PH501 Ventoux, 1965 Moulton M4 Speed
Quoted: 34 Post(s)
Liked 36 Times
It has a few hallmarks of a PY10, in fact; a bit later than my own area of expertise (?) but the braze-ons, rear dropout adjusters and tubing are all very similar to my '79 PY10LC. I would select a colour from what Peugeot offered for the Izoard back then - it will look right and not devalue a premium classic bike.
Likes For rmfrance:
#577
rmfrance
Quoted: 34 Post(s)
Liked 36 Times
PX - or PY?
I just realized that the Peugeot I got from a seller in England for a decent price is a PX-10. Also known as an Isoard for the British market. Also known as a Competition? Also in pre-restoration, pre-stripping, pre-derustifying, pre-repainting and outfitting stage.
For those of you who will mentally strangle me, I have a few crazy ideas for the pain....just haven't quite figured it out. This will be a summer project after the Trek, Faggin, AD SLE, MBK...
#578
Quoted: 838 Post(s)
Liked 1,082 Times
#579
Edumacator
Quoted: 2487 Post(s)
Liked 3,220 Times
Nope. Rattle can over rust spots. I think it was probably originally pearl white.
1987 Crest Cannondale, 1987 Basso Gap, 1992 Rossin Performance EL, 1990ish Van Tuyl, 1985 Trek 670, 2003 Pinarello Surprise, 1990ish MBK Atlantique, 1987 Peugeot Competition, 1987 Nishiki Tri-A, 1981 Faggin, 1996 Cannondale M500, 1984 Mercian, 1982 AD SuperLeicht, 1985 Massi (model unknown), 1988 Daccordi Griffe , 1989 Fauxsin MTB, 1981 Ciocc Mockba, 1992 Bianchi Giro, 1977 Colnago Super, 1971 Raleigh International, 1998 Corratec Ap & Dun, 1991 Peugeot Slimestone
#580
WingsToWheels
Bikes: Italian, French, British
Quoted: 85 Post(s)
Liked 66 Times
Just finished restoring a 1976 PX10 recently bought for a friend, only FD and headset weren’t original. Did it with some changes/upgrades to accommodate the owners’ specific needs for uphill climbing and esthetics:
- Simplex Slj retrofriction shifters
- Stronglight triple crank
- Simplex SJ triple FD
- Simplex SX410 long cage RD (completely serviced and repaired)
- Maillard Course 6s freewheel (also serviced and now turning smoothly)
- Stronglight Competition headset
The C&V forum is a huge help to solve those issues that obviously appear in these kind of works!
Likes For JackJohn:
#581
Bikes: '38 Schwinn New World, ’69 Peugeot PX-10, '72 Peugeot PX-10, ‘7? Valgan, '78 Raleigh Comp GS, ’79 Holdsworth Pro, ’80 Peugeot TH-8 tandem, '87 Trek 400T, ‘7? Raleigh Sports, ‘7? Raleigh Superbe, ‘6? Hercules
Quoted: 765 Post(s)
Liked 1,604 Times
What did you need to do to the SX410? I've got a pretty rough one I'd like to rehab for a build, but haven't found an info source on how to rebuild..... (possibly not possible.... I think at one time someone didn't know Simplex RD's are unscrewed from the inside and tried to unscrew it by the pivot, so that's the first thing that needs attention....)
#582
WingsToWheels
Quoted: 85 Post(s)
Liked 66 Times
Very nice! I just put Retrofrictions on my '72 PX and LOVE them!
In your case what happened to the hanger bolt is quite typical, it’s likely the spring inside is damaged. That was my case and I had to replace both spring and bolt, lucky I could find them on another cheaper Simplex rd that was compatible.
In servicing the SX410 the tricky part is the spring inside the parallelogram body: when putting it back, there’s a hidden hole inside allowing for the only position possible, I had to play with it a bit before finding the right one.
Also tricky was loading the springs to have a proper tension.
Hope this helps.
#583
Quoted: 765 Post(s)
Liked 1,604 Times
thanks, I learned a lot from this video, it’s in French but you can have English subtitles:
https://youtu.be/Yo0I9lmcd94
Then I also followed the technical scheme on the official Simplex catalogue.
Hope this helps.
Hope this helps.
#584
Chipper
Will edit this comment when I _finally_ find a PX-10 locally. 1 year and counting so far.
#585
Thanks for this info.
O RLY?
https://i419.photobucket.com/albums/p.../1982nl_16.jpg
https://mysite.verizon.net/imagelib/s...e&title=PXN10E
https://mysite.verizon.net/imagelib/s...3g&title=PXN10
A CFX-10 frame is identical in every way to a PXN-10 frame. PXN if supplied as a complete bike, CFX if frameset only. Reynolds 531 "Extra Leger" was french for Reynolds 531SL It is thinner, lighter 531, reserved for PY-10, the only bike higher in the line-up than PX-10 in these years.
EDIT: "Niet afgebeeld" is "not pictured" in dutch. It means the picture you posted is of a PY-10 (chrome, extra leger and all). The PXN-10 is "niet afgebeeld".
My current project:
Likes For JesseABN:
#586
Quoted: 5891 Post(s)
Liked 3,475 Times
AFAIK, the frame is the same (CFX 10 and PXN 10 with the difference being that the former was sold as a frame)
#587
Bikes: Still have a few left!
Quoted: 467 Post(s)
Liked 540 Times
My 1969 PX10, a 2019 Cino veteran all spruced up now, a favorite ride as its 1st gen Phil hubs still retain their near frictionless roll, some kind of magic! Don
1969 PX10
Replacement Phil Decals
1969 PX10
#588
What size is your cassette. I am about to rebuild the same bike and with the cassette on it I would not want to hit any hills. I notice that you do not have a short cage derailleur. How does it shift?
#589
Quoted: 467 Post(s)
Liked 540 Times
It's a 14-32 and derailleur has no issues shifting thru all cogs. Crank is a just a 52-45, but if you want very low gearing (just a FYI) I successfully paired a mountain bike, Shimano Deore, triple crankset to a 14-28 free wheel. on a 1971 Stella. That triple has a 24 tooth granny. . Don
#590
Quoted: 765 Post(s)
Liked 1,604 Times
#591
Quoted: 467 Post(s)
Liked 540 Times
For sure, but the $$ add up quickly compared to cost of a used mtb crank from your local co-op. ($10-$20), one could even pickup a long cage derailleur for cheap-BF'rs like cheap parts...
#592
I would like to keep the biker as original as possible. It still has the original Normandy hubs, so I'm not sure what freewheel I can find for that. The bike is all original except that the original owner swapped out the 27 " rims for 700c to make it easier to find the tires he wanted.
#593
Quoted: 765 Post(s)
Liked 1,604 Times
Your choices for French-threaded freewheels (which is very likely what you need if you've got the original hubs) are going to be pretty limited, and even more so for something that will get you some lower gearing for hills. If you want to stay as original as possible, but have some more sane gearing, the Red Clover triplizer is the way to go. Yeah, it's $$, but you get to keep the beautiful Stronglight 93 crankset. Though you'll also need a new, longer spindle for the BB (IIRC it's a swap from 118 to 121, though I might have this wrong- the specifics are on the Red Clover site). However, if you go for a triple then the original RD probably won't have the chain wrap capacity, so you'll need to upgrade to an SLJ GT or similar.... The fact is that, as originally equipped, a PX-10 isn't really geared for hills (unless you're young and even then, extremely strong!)- if you want rideability, you're gonna have to make some compromises.
Likes For ehcoplex:
#594
That makes sense, thanks. He said he had new rims laced onto the hubs because he did not like the tire selection. I just assumed he meant to go from 27" to 700c, but it was likely tubulars then. He actually gave me the bike. The bike is in pretty good shape except the LH crank arm square taper was badly damaged and I just found a new one for about $85 Canadian including shipping, and the absolute cheapest I could find in decent shape. I will have to open the pedal threads to imperial units as the pedal treads where rough and the new one is that way anyway. So won't be using original pedals.
I am not sure I will keep the bike when it is done as I already have a mint 1977 PY-10 with gold anodized components, nice enough that I hang it on the wall in the house and only really ride it occasionally. I enjoy the rebuild and would like to keep the PX-10 original (except the rims of course). I live in a somewhat hilly area so gearing it down would make it more ridable for me or any future owner. I may see if the original owner wants it back when he sees it finished. He bought it new.
I see Red Clover also has a 37t small chain ring. I need to check if the front derailleur has the capacity for that without going triple.
#595
I.C.
I.C.
Likes For Insidious C.:
#596
Thanks for that information. I will need to ask the original owner what rims it had when new. I was pretty clear that it was a PX-10 so I assume he had the tubular wheels swapped out.
#597
Quoted: 765 Post(s)
Liked 1,604 Times
The guy I bought my '72 PX-10 from claimed to be the original owner and that it was 'all original', yet it had steel 27"Rigida rims and Normandy Sport hubs (and a GIANT dork-disk), and had 'safety levers' on the Mafac brake levers! Not to mention it appeared the front derailleur was completely mangled and appeared to have been sucked into the chainrings at some point! But the price was right and I had plans to mod it anyway (650B, etc).
bikeaddiction1 , does yours have the original Delrin front derailleur? Somewhat rare to find one of those that hasn't cracked- would be interesting to know if it could handle a triple. The all-metal SLJ models can handle a triple- even the ones that aren't specifically spec'd as being for a triple. Not original, but still French/Simplex, and I think was a pretty common 'upgrade', especially if/when the original Delrin FD cracked.
#598
I know the original owner and he gave me the bike so I am confident that he is the original owner and knows the history of the bike and has no reason to tell me anything else. He originally wanted me to modernize the bike but did not like the options for getting modern derailleurs on it.
I believe it does have the original Delrin front derailleur (the one that slides sideways?). It is not cracked although the plastic does look dried out. I don't think I would go the triplizer route due to cost and as my vintage bikes (down to about 8, all road bikes, all XL, my size) are more of a hobby and I ride mountain, gravel, touing more and I have modern bikes for that. I am going to try to find a wider range cassette though.
The vintage bikes are just cool, fun to work on. and fun to ride on occasion.
#599
Quoted: 765 Post(s)
Liked 1,604 Times
Agree 100% with all but the last two words! All my bikes are 'vintage' and I ride 'em all the time & just about anywhere! But, as always, to each their own, as long as one is having fun!
Likes For ehcoplex:
#600
My dad had a '72 PX-10 from new until '79. Growing up, I heard a lot about how light and quick it was, so naturally the PX-10 assumed a near mythical status in my mind. So when I got into cycling in 2004, getting a PX-10 became something of an obsession. I never managed to find one in my size and for the right price, so I had to content myself with an '80 PKN-10 and an '82 PSV-10. Although I would still like to have a PX-10, the desire has been largely satisfied by the '81 Motobecane Le Champion I recently bought. At this point, if there is another grail bike to be had, I think I would love an early to mid '80s lightweight Gitane.
Likes For JochenRindt:
