Gravel grinding
#51
Bikes: I have a few
Quoted: 340 Post(s)
Liked 210 Times
#52
Quoted: 18430 Post(s)
Liked 15,585 Times
Skalkaho Pass in Montana. 7,250'. I nearly froze on the way down because I didn't have proper rain gear.
#54
Quoted: 32 Post(s)
Here's my take as to why my first proper new road bike will be a 650b 'gravel'
For me, drops are the most comfy bar arrangement, giving multiple positions for different riding situations .
A slack, touring geometry is more conducive for long rides and commuting comfortably
Large, 650b wheels with the supple tires add suspension at its best point, at the riding surface.
A skinnier, 700c wheel and tire set can easily be swapped out if you want more road readiness, but frames only designed for skinnies don't give any real pros that make a significant impact.
Millennials need a do all bike, since they know that getting a solid bike costs a good chunk of change. But can't afford a multi bike stable that's all high end. So spend the most on the bike most suitable for multiple disciplines.
#55
WALSTIB
Traveling through Missouri and found a place to get the bike out. I am riding on the Katy Trail rails to trails and you can really roll well on this surface. Unless you hit one of these tire groove pits. Mercy too many along here.
#56
Quoted: 7653 Post(s)
Liked 3,485 Times
#57
There was a podcast Tom was on recently where he talked about his past riding fire roads on road bikes in the 70s in California. It was part of training for some of the elite riders of the time. They called them "Jobst" rides after Jobst Brandt, a guy he used to ride with all the time and now a somewhat legendary figure in certain circles. Ritchey and a bunch on US national team members would go all day on backwoods dirt roads on very slightly modified road bikes and that Jobst would kick everyone's ass. Sounds like good times.
#58
Quoted: 32 Post(s)
So I wouldn't consider myself an exception.
#59
Liked 15,585 Times
Last month in Vermont.
#60
Liked 15,585 Times
Sometimes unpaved roads are the best alternative. Heading to Glacier National Park from Columbia Falls you can take either Blankenship Rd. or U.S. 2. The latter has a lot of traffic (including truck and RV traffic) and a section with no shoulder just west of Hungry Horse. The former, not so much. And the scenery is much nicer.
#61
Liked 15,585 Times
And you won't get these views if you opt for U.S. 93 south of Hamilton, MT instead of Old Darby Rd.
#62
Bikes: Priority 600, Priority Continuum, Devinci Dexter
Quoted: 685 Post(s)
Liked 55 Times
I have two very similar frames, one with 700c x 38 mm tires and the other with 650b x 47 mm tires. Both work on our local fire roads, but I do favor the wider tires for rides that are predominantly on gravel. (When a lot of pavement is in the plan, I might grab the 38 mm bike instead). The wider tires provide just the right amount of comfort and stability on the fire roads that I ride without the weight and energy-sucking from a suspension fork.
#63
Quoted: 32 Post(s)
Pavement in my city is terribly rough, unless your like most cyclists here and live in the posh suburbs.
Which is why 7/10 bikes I pass in the city are Walmart MTB's.
#64
Liked 15,585 Times
Taking unpaved King's Pass in Idaho instead of sticking to paved roads shaved 5.3 miles off what was already a hard day while adding only 275' of climbing. 3 miles up and 3 miles down.
#65
Quoted: 685 Post(s)
Liked 55 Times
That looks amazing. The photos in this thread are almost better than the discussion
#66
Quoted: 1218 Post(s)
Liked 298 Times
suburb riding is crazy, the snooty people trying to run you over is bizarre!
I really do hate the city, and I also hate the suburbs.
So If I ever had a gripe about the gravel riding taking off, it is seeing a flux of city people flocking to what used to be nice and quiet.
#67
Quoted: 32 Post(s)
City pavement is worse than single track.
#68
Liked 298 Times
That's what is inspiring me to get 650b. I love riding but my back Doesn't like the bumps.
My city hasn't seen growth since the 60's, so the housing and low density reflects that. If i stay off the main arteries i like it, but usually those roads are in a rougher state since they have only been repaving main roads for the past 2 decades
gravel can just be graded smooth. The problem with city streets is they bury all the water sewer etc under the pavement. then they dig it up, do repairs, and then some 'no care worker' does a shoddy patch job. add no growth, and now you compound the problem.
regardless the return to larger tires on bicycles is a good thing. in my opinion.
#69
Quoted: 32 Post(s)
a 65x47 seems to be your calling then. 650b slicks + a 35 degree sweep handle bar = Plush!!!!
I'm thinking gravel kings by panaracer in 42c.
#71
Quoted: 1743 Post(s)
Liked 1,281 Times
I am pretty much a roadie. When I hit the rail/trails it's on this......
#72
Liked 15,585 Times
I have been incorporating more gravel into my tours. One usually gets less traffic and nicer scenery. Sometimes that happens accidentally, like last month heading south through Vermont.
But it's not always pretty. If you want to ride west from Butte, MT to Anaconda you have to ride dirt or spend some miles on I-90. Done it a couple of times. The last time I forgot about a spot that looks benign but is actually quite messy if there has been a lot of rain recently. Rolled through it instead of walking around the spot on on the grass and sunk into the mud abut 3". Had to power wash my bike and shoes when I reached town.
#73
Liked 15,585 Times
Three more from my first time riding Melrose Bench.
#74
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
All, there is a gravel ride pics thread in the CXGB forum.
Gravel Ride Pics
Your photo's would be very warmly welcomed in that thread.
-Tim-
Gravel Ride Pics
-Tim-
#75
All of a sudden gravel grinding seems to be all the rage. But not for me. From the 3rd grad to the 9th when I lived on the farm, riding my bike to school on gravel roads gave me all the gravel grinding I wanted for a life time. Give me a nice clean smooth black top any day.
Now in Mi, I just don't live in a place where there is all that much pavement to ride. At least not without taking your life in your hands. Or driving to a trail. After dabbling in mountain biking, I found gravel road biking and love it. I again have endless miles of roads with few to no cars on them. The scenery is far better as well. It's not as fast, but that just builds my legs. I do work near a state park that has some very nice blacktop for biking and will take my road bike down to get pavement, but the routes are limited and that gets old after a while. There's nothing else like heading out from your driveway on a bike and halfway through the ride, deciding to go right instead of left in search of a road you've not been down before.
To me, what gravel biking represents on the consumer side is all the places in this country where road biking has been pretty inaccessible finding the joys of road riding. It's road biking, just on the roads that we have.
