Explain fork rake to me.
There might be some one on the Framebuilder's forum who could explain front end geometry. Perhaps you and the customer should study up on the subject before investing any money on a new fork.
Liked 7 Times
If he wants a shorter wheelbase he'll need a new frame, and probably a fork with a different rake offset.
Ride, Wrench, Swap, Race
Quoted: 1566 Post(s)
Liked 1,300 Times
I'm guessing that the 28 printed on the fork steerer is perhaps the steerer diameter?
I've never heard of a 28mm rake figure, but if it's a track frame with a ~77-degree head angle that might well be the right figure.
I've got a 1952 E. Christophe road bike, all original, and the head angle is 77.5 degrees. The fork looks fairly normal, but the rake figue must be significantly lower than 38mm in order to balance out the trail figure with the steep head angle.
Reducing the fork's rake will put the rider's toe in the path of the front tire when the bars are turned during slow cornering, possibly toppling the rider.
Quoted: 1866 Post(s)
Liked 665 Times
It will make the bike longer, which is the opposite of what your customer wants.
モㄥ工匕モ 爪モ爪乃モ尺
Bikes: Custom frame
Ok thanks guys, He has actually did the math and his headtube is 72 degrees, and he ordered a 38mm rake straight fork from his 50mm oem fork.
aniki
General Cycling Discussion
9
03-26-19 12:25 PM
