Bony Butt & Ride a Racing Bike?
Bikes: Cervelo Prodigy
Quoted: 478 Post(s)
Liked 87 Times
Several things:
The fore and aft position of the saddle are important. That is also connected with the measurement of the pedal stroke. They're both related.
If you shove the saddle back or forwards it will affect your position and also will affect that "comfort". You need to try that. Or go to a professional fitter. But you might as well try that yourself.
Another thing, the shorts or the bibs. Both shorts and bibs have padding. Most padding comes from designers in Italy. I think there are very few pad makers out there, maybe except from the Far East. This means companies like Aerotech buy their pads from the Italian makers. The kind that you want is the padding that has a density amount "denser" than other areas of the pad, namely the sit bones. The more expensive shorts will have that kind of multi-density pad.
The other thing is "bibs". When you ride for longer periods of time, the shorts will tend to "ride" and the pads don't really "stay in place". Next time you ride and when it gets a bit uncomfortable, maybe at the 30 mile mark, and not wait till the 40 mile mark, get off the bike and "reposition" the shorts so that the padding moves more towards the back where the sit bones are. This is a two hand thing. One hand at the front and the other hand at the back. You actually "pull back" the entire padding.
Bibs, on the other hand (no pun intended), keep the padding "in place" better. That means the padding does not "ride" forwards or backwards.
Another thing - sometimes shorts don't fit right to begin with. They really need to be tight fitting. Bibs too, but maybe not to that great extent.
Likes For Garfield Cat:
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2634 Post(s)
Liked 5,778 Times
I did have two bike fits - the last one was far more professional than the first where the PT was basically going by text book. I have bibs as well as bike shorts. Being tall the bibs tend to REALLY stay in place. Have a collection of about a dozen bike shorts from hyper expensive (Swiss) to cheap and have found some mid-priced ones better than the expensive. Have been riding a Terry mens seat for the last week and no discomfort so far on shorter rides (20-25) but will see on the long hauls. Only issue with the Terry is that it weighs a ton, butt if that is the trade-off, I’ll take it.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Quoted: 478 Post(s)
Liked 87 Times
Some riders go for a long pedal stroke where, during the downstroke, the knees are not bent (enough). As you age, that pedal stroke needs to "shorten up".
As the pedal stroke "shortens up" the rocking motion of your hips will lessen and that will translate to less movement on that saddle.
While you're at it, that rider behind you, see if he can detect your foot and pedal relationship. Some riders have a "bad habit". One or both feet tend to be "Pidgeon toed" They turn inwards instead of straight. That motion translates into the hip as well. It's common for the Pidgeon toe riders to ride as if they're on their "tippy-toes"...also not a good habit.
Bad habits are hard to break and invites injuries, sooner or later.
Quoted: 478 Post(s)
Liked 87 Times
rsbob
Of all the things, the first thing I would look at is the "fore/aft" position of the saddle. Just by some movement front or backwards may make a difference. I mean sit bone pains. This assumes the saddle has a "wide-enough" area where the bones meet the saddle. Even though there are ways to measure the distance between left and right sit bones, it doesn't somehow "match-up" with that width on what the saddle makers put out there.
Besides, that's the least expensive trial. I know, you might have spent lots of $$$ on a bike fit. Me too and the best fitters are the most experienced fitters.
Grupetto Bob
Liked 5,778 Times
rsbob
Quoted: 245 Post(s)
Liked 469 Times
Go to a bike shop that knows how to fit a persons butt for the saddle they need.
It is possible you are on a saddle that is too narrow and your sit bones are not being supported evenly.
This made all of the difference for me. I was going through saddles quickly - luckily selling as I went so I wasn't taking a huge loss. But once measured and fit at a bike shop - I was steered towards a couple saddles I would have never considered for myself. It was a neat process - I sat some memory foam/gel pads at different angles and they would measure the imprints of sit bones. I ended up with a fizik alliante and it was great. I now ride all brooks - but they fit me perfectly (I don't consider them a fits all saddle as many do - but they at least fit me).
Likes For kstephens:
No almost, you did. One of my main markers for being in riding shape - never super fit any more and my butt got bony too - is I am above my saddles. From there it can’t hurt.
It is all about pedal action. Try to find the pedal action you once had. Undoubtedly you are going slower. So use lower gears. Dance on the pedals. Someone above said lower the saddle. Yes. From a high saddle with a big gear you can’t avoid leaning against the saddle and pushing back on it.
You sound like you are basically fit. Just keep at it. Early season it is not at all surprising to have a little saddle discomfort. It is only April. Expect it to get better from here.
Likes For 63rickert:
Sounds like you need a bike fit. A good bike fit will fix this issue. Finding the saddle that will your sit bones is the answer to your problem.
Quoted: 790 Post(s)
Liked 348 Times
Do something to build up your butt muscles. I find that if I am out of shape and have lost my butt then riding is not comfortable for me except on some bigger gel seats. Once I started doing a lot of hard uphill work, spinning up steep hills and grunting up steep hills in higher gears while pedaling standing up, I got some muscle down there, and a lot of places period, and then seat choice quit being an issue. I am 60 years old and have always been tall and never got to being obese, I just lose muscle when I don't workout, and gain it back when I do workout. I have also been trying to do some squats and toe-raises, and some running on grass, things I did a lot of when I was younger but now have to fit a lot of those activities in between aches and pains. Good luck....
Grupetto Bob
Liked 5,778 Times
Finally found a really good solution. Bought a pair of Endura FS260-Pro shorts with gel inserts. Took them out yesterday for a 50 miler and it was the first time after trying multiple shorts that I wasn’t hurting and had bruised sit bones (actually the skin where my sit bones hit the saddle) after the fact. I believe it had to be the gel inserts that did the trick. I tried all the recommendations but these worked. The only real issue is price. The bargain priced shorts may work for the majority but my truly bony butt liked these.
Quoted: 994 Post(s)
Liked 1,661 Times
I once saw a Touring Cyclist over at the state park camping. There was Wheel Chair Gel Pad siting on top of his seat. I asked him about it and he said after about 50 miles he puts it on top of his seat and it helps him make it to the end of the day.
He was about 60 years old and was going from Tucson Az to Florida and averaged 50 to 70 miles a day camping each night. I am always impressed by people who can do this at any age and if he wants a goofy looking pad to do so be it...
Quoted: 3255 Post(s)
Liked 2,545 Times
Go to the Touring/Randonneuring threads and see what they use.
