Have you ever cached water for a ride?
When I took a photo of Lake Wenatchee on my recent Cascades mini-tour, I consciously realized at the time that it was similar to what you posted here earlier this year.
Apparently I was also duplicating a Colonial Creek Campground photo you'd taken.
Forgive the Fredly water bottles.
Bikes: 2020 Masi Giramondo 700c; 2013 Lynskey Peloton; 1992 Giant Rincon; 1989 Dawes needs parts; 1985 Trek 660; 1985 Fuji Club; 1984 Schwinn Voyager; 1984 Miyata 612; 1977 Raleigh Competition GS
Quoted: 1128 Post(s)
Liked 257 Times
In addition to the 2 in the rear, you can add another bottle to the frame by getting this thing: Minoura BH-100S Bottle Cage Mount 22.0 - 29.0mm Clamp | Bikewagon Assuming you have the space of course.
Also you can get handlebar bags with netted water bottle holders on each side.
You can get larger 24 ounce bottle to.
The Camelback is a good idea, but I would just get the smallest one which I think is the Rogue which holds 70 ounces so it's not as heavy on your back.
If you can get at least 3 24 ounce bottles on your bike plus 70 ounces on your back you would be all set, that's about 140 ounces just with those I mentioned, and you could add more with at least two more in a handlebar bag.
The frame pump you have is taking up valuable real estate on your bike, that is where another water bottle usually goes is on the seat tube, so move the pump to the top tube. Then you can mount a third bottle to the bottom of the down tube. So you have plenty of options without going and hiding water.
Bikes: '00 Koga Miyata Full Pro Oval Road bike.
Quoted: 475 Post(s)
Liked 8 Times
I'd just carry the water, a couple bottles in my jersey, and one on the bike. And a few energy bars and a pb&j. Seems like the easiest way to do it to me.
don't try this at home.
Quoted: 987 Post(s)
Liked 528 Times
Won't help you know but someone is making a water bottle that fills itself using moisture in the air.
Self-Filling Water Bottle Converts Humid Air into Drinkable H2O
Unfortunately, it can't possibly work at that size and that rate of water collection. It's just another kickstarter / indie gogo project that's bogus.
See:
Is the Fontus Self Filling Water Bottle a Scam? This Evidence Suggests So
To condense that much water via solar powered refrigeration would require way more power than would fit on a bike.
The video rant linked in the story is really great!
I saw a previous video rant that calculated the amount of air needed to draw through the device. Not only is the power way too low, the airflow is way too small.
Here's the video, linked from the comments of the original link above. 50,000 liters of air need to have 100% of it's humidity extracted to make 1 liter of liquid water.
And lower humidity air, cold air, or cloudy days make it even slower.
Bikes: ...a few.
Quoted: 2012 Post(s)
Liked 410 Times
Sounds like a lot of work. I'd echo the idea of carrying all the water on you. Two 800mL on the bike, and maybe another 2x500mL disposable bottles in jersey pocket. That's 2600mL, and maybe hydrate well before the ride. Should be enough for 90 miles.
As far as my own situation, though: yes, it is. I could move it to the top tube, but it won't seat well there because there's no peg. The pump did come with a velcro strap to "solve" that problem, but I think I lost it... oh well.
Bikes: ...a few.
Liked 410 Times
Still, caching is way too much work.
Quoted: 440 Post(s)
Liked 264 Times
If some of the streams are not dried up could you use a water bottle with a filter and get enough water that way? Little pricey but we use them on hiking and kayaking trip, Katadyn MyBottle Water.
https://www.rei.com/product/799021/k...water-purifier
I do like the idea of stashing water along the route, I'd never thought you of it.
Carry a SteriPen. At any stream you can refill and purify, only weighs like a half pound, and would easily fit in a jersey pocket.
Advocatus Diaboli
Quoted: 4760 Post(s)
Liked 1,542 Times
If stashing is no longer an option (though it sounds like it would work if you're willing to do the drive), I find a good accessory to have around the house to use in pinch, is one of these topeak beamracks. Of course with one these you could load up to 4-5 liters of water if you put a bag on it large enough.
EDIT: Sorry, originally linked wrong product on Nashbar that I don't think would work well with a road bike. You'd want one of these instead:
https://www.chainreactioncycles.com/u...e/rp-prod28820
Quoted: 839 Post(s)
Liked 2,199 Times
Never have, but it sounds like a good idea for the ride you have planned. Anything to avoid dehydration on a 90-mile desolate dirt road. I like the idea of using one of those box wine bladders assuming water can be funneled into it. Even better if you could freeze it the night before and stash it in a shady place. Might also mount an extra bottle (from bars, behind saddle, etc.) for the start.
Quoted: 41 Post(s)
Liked 8 Times
I'd say go ahead and cache some H2O on your route. A runner friend of mine routinely caches it on her routes. At 8.3454 pounds per gallon, a bunch of water on one's bike will be too heavy and detract from the ride.
5
04-17-15 09:44 AM
