Science behind the steele frame
Bikes: '68 Masi Special road, Grail bike
Quoted: 108 Post(s)
Liked 70 Times
BITD I think it was Tom Ritchey who said: a really good road bike is supposed to react like a spring
you don't make springs out of aluminum" that springy, resiliant, alive feel only comes from steel or titane
bikes alu-alloy and carbon fibre will feel dead. but the rider who only wants lightness combined with
stiffness will sadly never have the time or inclination to feel it
Likes For steve sumner:
Quoted: 1841 Post(s)
Liked 1,713 Times
The stiffest, least comfortable bike I own is made of steel. It is pretty much unrideable with tires less than 30 mm width. The most comfortable lively bike I own is carbon fibre, nothing dead feeling about it
Perhaps one reason steel bikes are preffered by some people is because when aluminum frames where introduced the low end ones used larger, thick diameter tubes to compensate for the reduced strength of aluminum vs steel by volume. This design regardless of material makes for a stiffer frame.
Also, Steel is springy, Aluminum much less so, but absorbs more vibration. A well designed carbon frame might offer an almost perfect ballance of absorbing vibration, feel/springyness and low weight, and why it is the gold standard for performance road/gravel bikes.
Likes For xroadcharlie:
Bikes: 2013 Cannondale Caad 8, 2010 Opus Fidelio, 1985 Peugeot UO14, 1999 Peugeot Dune, Sakai Select, L'Avantage, 1971 Gitane Apache Standard, 1999 Specialized Hard Rock
Quoted: 548 Post(s)
Liked 473 Times
Korina Interesting videos, thanks for sharing.
I will agree my OP was a loaded comment/question considering the audience but I wanted to get some facts behind my statement that steele is a good frame material (note I didn't say better) acknowledging that there are many other factors. I guess I have forgotten what a real crappy bike rides. like the ones I had as a kid. I guess I could head over to a big box store and take one of those bikes out for a spin. I did also change my wheels recently on my vintage steele bike and that's made a big difference in the ride.
Quoted: 2558 Post(s)
Liked 3,056 Times
Curious how people are now obsessed with fitting the widest tires possible in their vintage steel bikes. Apparently not quite comfortable enough.
As I've mentioned on this site several times before, I rode pro-level steel bikes for racing and training from 1965 to 2005, when I bought my first aluminum bike. I may have ridden a couple of my steel bikes (Reynolds 531 or 853; all the Columbus SL or SP bikes are gone) a few times since then, but they're all collecting dust in the basement these days.
As Sheldon Brown wisely said, in response to a question on the topic of frame material and comfort,
"A bicycle frame is made up of triangles, and there is no compressibility in the frame members whatever they're made of. You've fallen for folklore. . . . Ride comfort is much more affected by geometry, saddle type, and, even more important, tire choice/pressure."
I still like looking at beautifully painted steel bikes, but I choose aluminum for every ride (4 hours yesterday and 4 hours today; no fillings lost).
Likes For Trakhak:
Bikes: Performer X-Low, Catrike Trail, Windcheetah Club Sport, HPV Grasshopper, FAW+ Velomobile (under construction)
Quoted: 12 Post(s)
Liked 40 Times
Aluminum (and titanium) do not and can fatigue over time which can also play into the tubing size and design margins.
Likes For skier:
Just to add the the great reply here, it’s also worth nothing the steels have a knee in the S-N curve where you can essentially achieve “infinite life” if you stay below a certain stress level. Composites can also be designed to not be impacted by fatigue.
Quoted: 548 Post(s)
Liked 473 Times
Sorry you didn’t get the joke in post #13 .
Used to be Conspiratemus
Quoted: 297 Post(s)
Liked 245 Times
[heh, heh, good zinger. Steel is real when it suits us, but rubber rocks when the going gets tough.]
"A bicycle frame is made up of triangles, and there is no compressibility in the frame members whatever they're made of. You've fallen for folklore. . . . Ride comfort is much more affected by geometry, saddle type, and, even more important, tire choice/pressure.” . . .
OK, this is reductio ad absurdum but my point is the role of material in a bike frame (or a bridge or an orthopedic implant) cannot be dismissed just by saying triangles can’t deform, because they do. As the owner (but never racer beyond sprinting for road signs) of several high quality steel bikes I am prepared to admit the only reason to prefer them over newer materials is that they are much cheaper and fit at a sweeter spot on my personal marginal utility curve. And I have actually ridden one or two CF frames short distances. Impressed but not blown away, for the price.
And the risk of asplosion.
Likes For conspiratemus1:
With a mighty wind
Quoted: 1112 Post(s)
Liked 910 Times
So I've mentioned this in other threads. I'll mention it here too.
In my racing days, I got relatively cheap aluminum frames, slapped Ultegra or Dura Ace on them, and away we went. They were fast, responsive, and light. Maybe they rode rough on 23's @ 120psi but I was like 24, who cares. They weren't sought after or special.
Lately, being done with racing I've been riding high end steel or custom made steel. There is no question that they ride better and are more comfortable. It's probably not frame material but frame quality. We also know more about tires now, so the standard 25-28 certainly help. It really isn't a fair comparison.
I did end my racing on a Litespeed Vortex. Around 2005-6. I hated that bike. It was squirrelly and slow.
Mike Burrows take on frame materials:
I think the classic steel bike looks the best! And especially I have a soft spot for lo pros. The biggest advantage of carbon fiber, beside the strength-weight ratio, is the form freedom it gives the designer. The UCI rules have kept designers from using this advantage, and thereby keeping the difference between the materials smaller.
Maybe my fascination of the lo pros is also the reason I find modern triathlon bikes far more interesting than modern road bikes (interesting is far from equal to beautiful...).
Steel does seem to be an excellent choice for bike frames, Perhaps better then alluminum if we use good steel tubing (like thinwall cromoly).
Is it possible that the bicycle industry's marketing team had worked overtime, and sucessesfly convinced average consumers that alluminum bikes are better then steel to boost sales.
Then theres manufacturing cost. I'm not an engineer, But it wouldn't surprise me if it was less expensive to build good quality, inexpensive alluminum bikes then steel ones with the tighter tolerances and careful welding needed for thin tubing.
And while we could, and someone probably does build high quality, performance steel frame bikes to this day that might rival some carbon frame ones, Carbon might be the best choice for mass production.
Liked 3,056 Times
Likes For Trakhak:
I thought it would have been racing that would influence the move to aluminum and CF.
would they not want to shave every last gram of weight for that bit of competitive edge?
I do agree, as a non competitive rider steel is my daily ride.
curmudgineer
Bikes: 2 many 2 fit here
Quoted: 263 Post(s)
Liked 112 Times
A premise has been made, that the tubes of a frame triangle provide compliance by bowing, i.e. pre-buckling, which I question. A mathematical analysis would show how much bowing would be needed to provide the equivalent of a compliant suspension, and I suspect it would also show that not only aluminum, but also steel and titanium frames would be in a fatigue regime if they were bowing to such an extent. So, I tend to agree with Sheldon about the compressibility of the frame triangle.
I will grant that a steel tubing frame will twist more than one of aluminum tubing, under the same torque loading and when designed for the same mission with the same skill and resources.
Likes For old's'cool:
Quoted: 297 Post(s)
Liked 245 Times
I think I agree that a triangular bike frame cannot bow from vertical loads with anywhere near the amplitude of a compliant suspension. (Steel forks, which are not triangulated, do move enough that it has to be considered in avoiding the tire interfering with fenders or handlebar bags on rough roads.). I was thinking more about the tiny movements set up in the frame members which each impact, which can’t be seen even if they can be felt. If you strike a hard-thrown baseball with the wrong part of the bat, the vibrations transmitted to your hands are painful. A hit in the sweet spot is painless (and will more likely result in a base hit.) My thought was that different materials might be expected to handle these low-amplitude, high-frequency vibrations from road roughness differently, with the differences perceived as “lively”, “dead”, or “harsh” with “notes of assertiveness without overpowering fruitiness” . And these vibrations must be propagated through the frame tubes by tiny compression-rarefaction deformations of the (triangulated) frame material.
An ideal triangle cannot shorten any side but this assumes the sides and joints cannot bend — if a line segment bends, the polygon is no longer a triangle as there are now four angles and sides or else one side becomes a curve. So this geometric precept involves some question-begging.
Likes For Dick Chainey:
Likes For Sluggo:
Quoted: 297 Post(s)
Liked 245 Times
N
Thanks. Not surprised by his results and expectation/perception bias (aka placebo effect when you’ve spent money on something) is undoubtedly decisive in the macro sense. But in the micro sense, does the difference between “twanggg” and “klok” matter more than as acoustic cues to the placebo expectation?
The article in this link shows measured data that supports Sheldon's (and Trakhak's) statements with some discussion and caveats: There is not a significant amount of vertical compliance in triangulated frame. Tires (and maybe fork) are the only suspension you have.
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,050 Times
I’ve only owned and ridden steel frame bikes, so I’m no authority on comparing frame materials. OTOH, I do appreciate the fact that perfectly rideable low-end steel frames from the 80s are nearly free these days.
That said, I suspect my ride comfort comes mostly from riding technique, bike fit and choice of tire width and pressure.
Otto
Otto
Quoted: 1954 Post(s)
Liked 2,199 Times
I’m sure everyone realizes that posting this question on a C&V subforum will yield the expected results.
John
John
Likes For 70sSanO:
Bikes: Turner 5-Spot Burner converted; IBIS Ripley, Specialized Crave, Tommasini Sintesi, Cinelli Superstar, Tommasini X-Fire Gravel
Quoted: 406 Post(s)
Liked 390 Times
My 531 TREK 760 from1985 may be my favorite bike from an overall ride perspective. Just the right amount of springiness for this 210 lb frame., But my favorite attribute may be the quiet ride I can achieve on steel that I can't match on my Ti, CF, or AL bikes. Its akin to just floating, and since I'm old and will never again be fast or go for long days in the saddle, the quality ride of ferrous still makes me happy. At the end of the day, or the end of a two hour ride, Im reminded, THIS is what a bicycle should look like. Your experience may vary.
Quoted: 1110 Post(s)
Liked 1,048 Times
Materials matter some and shape matters some. I've got a nice carbon frame that rides about as nice as any steel bike I've ever owned, on the other hand I recently threw a leg over a rock lobster and I think it rides better then any other bike I've ever ridden and that's even after owning two DeRosas that fully convinced me the mantra that nothing rides like Derosa was a truth. I was turned off of aluminum by a trek 2300 and a schwinn fastback pro that I demo'd the first year they came out. Both had me thinking I was going to die, especially the Schwinn constantly going airborne on a rough curvy mountain descent at 50+mph. Yet I've hopped on aluminum since that was a joy to ride. Steel is real; real nice, real comfortable and real heavy but it is a legacy material that still works in this modern world to make a top notch bike for whatever purpose you need it for. But I wouldn't shun any other material on the claim its inferior, I've ridden them all; I love my steel, the carbon is sweet and I miss my Ti Litespeed classic. Just get the bike that fits your form and purpose best.
