Mid-'40s René Herse tandem
#176
Quoted: 964 Post(s)
Liked 1,451 Times
Wow, that is so impressive. Machining is just such a fascinating thing. Looking forward to seeing this all together and finished. I think you could give This Old Tony a run for his money if you were to start your own youtube channel. How's your snarky humor?
I actually think I've been watching too much youtube machining. I was required to make an instructional video for some science equipment I machined as a tool for my research, so others could use it, and surprised myself with the jokes I made, almost involuntarily.
By contrast, Abom79 is a way more prolific machinist but seemingly has no sense of humor. Maybe you lose that when it's your actual job. I have turned things on an American Pacemaker lathe like he uses, and it is indeed serious business. I'm super lucky to have access to the shop here at work, so I don't know how much videoing I could get away with! Maybe I'll give the youtube thing a shot in 30 years if retirement is still a thing at that point.
#177
Quoted: 3361 Post(s)
Liked 3,638 Times
The size of some of the stuff he swings in those lathes is a bit scary
I've got a feeling that our YouTube history has quite a bit of overlap
Also it's been fun following this, I'm always excited when I see this thread bumped!
Likes For abshipp:
#178
Quoted: 964 Post(s)
Liked 1,451 Times
Just got parts back from chrome, at Franklin Frame.
Getting nuts and bolts chromed is expensive! $4 each, because they had to be individually racked to plate. The plater could've done something called "barrel plating" where they all go into a barrel that turns slowly and acts as the electrode, making it unnecessary to rack the parts, but I guess nobody does that anymore. It may have been slightly cheaper in some instances to go with the reproductions that Jan Heine sells, but then it wouldn't be a real one anymore. A lot of the original screws are 5x0.75, a thread pitch that barely exists anymore and certainly isn't available from any retailer. I was able to get a Chinese-made tap and die to clear excess chrome from the threads, so that's good at least.
Because the racks and bolts have a lot of file marks and pits that still show through, I think any worries about the shiny chrome "letting down" the rest of the build or it being "overrestored" are unfounded! You gotta believe me, without a rechrome, I would have been letting down the paint. There were entire swaths of tubing completely devoid of chrome.
Now, before I start hanging parts on the bike, how should I preserve the original paint? It is beautiful original paint, but has rust spiderwebbing under it and is scraped off in places. I am thinking either linseed oil or car wax. Or both? The linseed oil mixed with coleman fuel dried nice and hard on my Trek, and looks to be holding up pretty well, for what it's worth. I am looking at patina preservation techniques that the car guys use for the Rolls Royces at Pebble Beach concours. Preservation, not restoration. Any ideas?
#179
Quoted: 4513 Post(s)
Liked 6,389 Times
Now, before I start hanging parts on the bike, how should I preserve the original paint? It is beautiful original paint, but has rust spiderwebbing under it and is scraped off in places. I am thinking either linseed oil or car wax. Or both? The linseed oil mixed with coleman fuel dried nice and hard on my Trek, and looks to be holding up pretty well, for what it's worth. I am looking at patina restoration techniques that the car guys use for the Rolls Royces at Pebble Beach concours. Any ideas?
Likes For merziac:
#180
Quoted: 472 Post(s)
Liked 1,039 Times
The, maybe, bad news: I think it takes a lot of coats. On the two bikes f/f, I stripped the bikes and applied 15 or 20 thin coats of cut BLO. Both times it was winter so I had plenty of time. Smear a coat on, wait a few minutes, wipe it off. One a day for as long as I felt like it. Easy but a long process. No worries. I like the smell of linseed oil. Natural. I like the idea that it’s so thin it seeps into tiny cracks, wee holes in chrome, paint dings, etc. So far, a good sealant. More durable than wax and easy to re-coat. YMMV
Likes For Prowler:
#181
Bikes: 50s, 60s, 70s Nottingham/Worksop bikes, becanes, Gitane, Bertin, Lion of Sochaux
Quoted: 145 Post(s)
Liked 120 Times
Regarding preserving the paint: I think this calls for treating what is worthy of a museum like one!
https://www.thehenryford.org/collect...for-artifacts/
see motorized vehicle pdf.
recommend cleaning the frame with Orvus then perhaps some light polishing for any oxidation as they recommend followed by Renaissance wax.
Likes For Slowride79:
#182
Quoted: 964 Post(s)
Liked 1,451 Times
Good suggestions. I have some nonionic detergent I can use for starters anyway. There's a fair bit of dirt in the lug details.
Here's a little effort I've made so far with restoration and reassembly of the brakes:
Before - n - after
Before - n - after
Likes For scarlson:
#183
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,803 Times
I think I have some air in a WWII jerry can I can send you to pump up the tires. I'm not sure if the date matches the bike, but I would think it's close enough to be called period correct.
#184
Quoted: 964 Post(s)
Liked 1,451 Times
Although if it's wartime WWII air, while the lead content would be correct, it won't have the appropriate radioisotope content to reflect the detonation of the atomic bombs which happened the year prior to this bike's construction. That immediate postwar era was a special time for the atmosphere...
#185
Quoted: 964 Post(s)
Liked 1,451 Times
Yeah, I was pleased mainly because he did not lose a single screw. That's impressive. Unboxing produced rich whiffs of either pipe tobacco or woodstove, which was also a nice touch.
Likes For scarlson:
#186
Quoted: 2364 Post(s)
Liked 1,751 Times
I can put it on the basement shelves next to the Lucas replacement wiring harness smoke kit I got off ebay for my car.
Likes For madpogue:
#187
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
