Browning find - Is this frame any Good?
Bikes: 1980 Marinoni Special, 1987 Ciocc Microf. C40, 1978 Raleigh Competition GS, 1982 Colnago Super, 1972 Gitane Pro TdF, 1976 Belgian Diamant by Martelly, 1989 Trek 520, 1972 Dawes Galaxy 2014 Cervelo R5, 2020 Salsa Warbird, 2013 Giant Trance X1
Quoted: 91 Post(s)
Liked 61 Times
Quoted: 3815 Post(s)
Liked 3,350 Times
you can hold a plate style gear hanger up to the Juy one to use it as a guide as to where to cut/grind the stop. most any brand other than Juy or Huret shall suffice. just mark where you need to cut with a crayon or felt marker.
"Robert wilst then be thine uncle."
Likes For juvela:
Liked 3,350 Times
thank you for the new information
it tends to support the idea of a low countries origin for the frame
[curtains close for a moment whilst juvela dons his deerstalker cap]
am going to make a guess that frame originates with Flandria
they were the first manufacturer in europe to adopt Shimano for pro bikes in 1973
member non-fixie has posted about this here -
Vintage bicycle rebuild... follow my progress till the end.
Flandria far and away Belgium's largest producer from a unit volume standpoint
they did a good deal of contract work
if shell width is 70mm yet is BSC threaded that would be another piece of supportive data...
Quoted: 91 Post(s)
Liked 61 Times
-----[/QUOTE]
Definitely BSC I will check width and report back.
-----[/QUOTE]
Quoted: 91 Post(s)
Liked 61 Times
Likes For Dannyboy21:
Liked 3,350 Times
thank you
a NERVOR steerer is what one would have expected (french tubing maker)
no relation to Etablissements Peyrard (NERVAR)
a sixty-eight mm shell does not rule out Flandria while a seventy would have tended to rule it in
Belgium seems to be a real homeland for contract builds
tubing note -
the 27.0mm pillar size tells you the three main tubes are db
when you get the fittings out of th shell you will be able to examine chain stay interiors
would expect them to exhibit seams
thank you
tubing note -
Quoted: 91 Post(s)
Liked 61 Times
So as mentioned I decided to move some of the good bits over to this Gitane Pro TdF Service Course. Just have to figure out how to get the Shimano Adamas rear brake to work better, add the new tubulars and Bob's your uncle. Took it for a test flight last evening and the old rear Vittoria started to fail after about 10 Km. Haha. Good thing my daughter can drive now!
