Fixed Gear/Single Speed - Start Here!
#101
Veteran Racer
Bikes: 32 frames + 80 wheels
Quoted: 1337 Post(s)
Liked 765 Times
im super new to the fixed gear scene. I'm 6'5" 195lbs 32" inseam and i have an old raleigh frame and fork nor sure of the size. i took off the old 27" tires and a friend of mine gave me some 700x23c rims with a 16t fixed gear on the back. i've got bars, seat, cranks, 48t chainring, pretty much all the parts. the frame has vert dropouts and i'm looking into a frame n fork. from the charts it looks like ill be leaning towards a 60cm frame.
would something like this be ok?
Murphy Himself 60cm frame & fork
#102
Cult Classic Cycling Club
Bikes: Ridley Helium, Norco Search
i know, but will my parts work on this and is it a correct size for me?
#103
Veteran Racer
Liked 765 Times
If your parts match the dimensions of the frame, then yes, just like any frame. As to size, it's probably in the ballpark, if that's what you ride comfortably on the road.
#106
Zen Student
Bikes: Colnago Crystal road, Lotus road, Dawes SST-AL fixed gear
Interesting, below the pics in the Murphy ad, it states
FREE USA SHIPPING
FREE USA SHIPPING
1989 Lotus Unique, 1999 Colnago Crystal with full Campy, 2009 Dawes SST-AL fixed gear
#108
Zen Student
Do you guys recommend any specific cog brand? I'm looking to pick up a new 16t or 17t cog for my Motobecane Track because the stock 15t cog is pretty cheap and sounds pretty terrible.
Also, is it safe to assume the noise is from the cheap cog? Or can it be due to chain tension that is too tight/slack?
#110
Veteran Racer
Liked 765 Times
For 16T or smaller I'd recommend Dura Ace, which will cost between $20 and $25 depending on where you buy it. For 17T and larger I'd recommend Soma, which in black will cost less than $20. And yes, the stock cogs are pretty bad, not very round or well machined. Even the one that came on my more expensive Kilo WT was pretty bad, and it sounded like it was full of gravel. Chain tension was pretty uneven on it as well. As soon as I changed it, the drivetrain became silky smooth and quiet and chain tension was very uniform.
#111
Would switching the cog help with the chain tension? (I assume it'd be similar to switching a chainring, right?)
Thanks for the help!
#113
Thanks!
Would the cheap cog also explain a "bumpy" ride? I've been riding my Motobecane Track as a singlespeed since I got it and made flipped the wheel today to try fixed for the first time. The ride is definitely not as smooth as my freewheel. Or would that be more likely caused by a chain that is too tight?
#114
Veteran Racer
Liked 765 Times
IDK what you mean by a "bumpy" ride, but you can adjust the chain looser to see if it makes any difference. In any event, the chain should have about 1/2" total up and down slack at its tightest point. You need to rotate the wheel several turns before you will be able to find the tightest point.
#117
Bikes: Surly Steamroller 2010
I'm pretty new to single speeds... I took a dive and bought a complete surly steamroller, and switched it to a freewheel (I hadn't ridden fixed, and was trepaditous to go too far too fast). Right now, it's still completely stock, but I'd like to upgrade. Also I like the feel of the frame so far, but I don't ride particularly long distances at the moment, mostly campus and town transport. So a few questions:
1. Did I buy a good frame, and what are the most telling factors?
2. Parts and components, which, how much, etc.
#118
Oh, you know...
Bikes: '74 Schwinn Sports Tourer (Polo), S-Works E5 Team Festina (Chorus 11), Trek 2200 Bonded Carbon (Fixed), Trek 920 (7 speed IGH), Chesini Olimpiade SL (1x7)
The Steamroller is well thought-of.
#119
on Baby Charlie Concept~
#120
hey guys! I've been riding my fixie for a while now and I ****ing love it! My girlfriend wants a bike pretty bad, but I know she's not much into cycling. Her birthday is comming up and I want to know if I could snag a bike for around 150-200 for her bday, could you guys make any recommendations? it would just be a bike to ride from class to class with. Thanks dudes help a brotha out!!
#121
Veteran Racer
Liked 765 Times
Hey man, is your gf petite? If so, this might be just the ticket, about $170 with shipping >>> https://cgi.ebay.com/ws/eBayISAPI.dll...STRK:MEWAX:VRI
#122
yeah she's 5'5ish so that might work! I've found another at a LBS thats about 180 walk out the door so I'm trying to decide. I'm sure she'll be happy with anything and even happier if the colors look nice. girls
#124
Can anyone recommend me a good set of tires? I'm wearing down my stock tires pretty quick and I think my front has a leak. I'm looking for something that wont puncture so fast but also wont slow me down too much. Thanks dudes!!
