DYI gravel bikes
The primary differences with gravel bikes are the tires with 700x38 on most, the drop bar profile, and the possible addition of a dropper seat post. A brand new Specialzed Diverge E5 gravel bike retails for $1,300 which is not cheap if one is thinking Wal-Mart bike prices, but it is by no means expensive. The Salsa Journeyer Sora 700c is sold by bike shops and sells for less than $1,100.
Hardtail mountain bikes work well on gravel and the tire sizes they use are common to a great many tires from Maxxis and others that are less aggressive and suitable for use on gravel. The highly regarded Specialized Rockhopper bikes start at $600.
Take the time to do a little research before you start whinging on which is always counterproductive.
Likes For Calsun:
Quoted: 3824 Post(s)
Liked 6,782 Times
I did a 330-mile tour last week, 90% of which was on unpaved surfaces: packed gravel, loose gravel, dirt, mud, grass. I was on 650b x 48mm tires, which overall were a good choice though not great mud tires. I don’t think I would have been a happy camper on much narrower tires.
Likes For nlerner:
Live not by lies.
Bikes: BigBox bikes.
Quoted: 860 Post(s)
Liked 784 Times
I dunno about some of this stuff. A lot of the things that have been posted here seem to be more matters of personal opinion. Wide bars, slack angles, disc brakes, I dunno if they are any better for gravel roads. I prefer the opposite, even down to these class IV roads in northern new england with rocks and ruts and mud. But I don't want to start a debate. That's why I said, any bike you ride on gravel is a gravelbike. Once I did 15 or 20 miles of ATV trails on my Vitus 979 as part of an 80-miles-to-cape-cod adventure. Twas indeed an adventure, but bike and rider made it out alive! The hybrid bikes and MTBs are equally good as my touring angle on things. Dirtdrops, rando bars, compact, narrow, wide, bullmoose, mustache bars, porteurs, risers, flat, anything goes! Maybe that's why gravel is "in" these days.
New defined as modern high performance bike (road bike tech) that was more useful than a road bike.
Cue the pitchforks and stoke the fires… I think Grant Petersen and modern gravel bike fans are probably desiring the same (or similar) type of riding experience. Maybe a couple pounds difference in their approach. Usually when I see spandex hamsters riding by, I can spot right away where a couple pounds should be shed…
I heard a saying before. The narcissism of small differences.
ETA it’s great to have options.
Likes For SkinGriz:
Sunshine
Quoted: 11044 Post(s)
Liked 7,595 Times
But despite it being personal opinion(preference), that doesn't mean that on the whole there aren't benefits to the things that have become commonplace.
- Wide bars- having flared drops help to slow down and stabilize steering on loose surfaces and descents. You may not find that beneficial, but it is largely accepted because so many have found a benefit in slowing and stabilizing steering on loose surfaces and fast descents.
- Slack angles- this is hardly universal. Some modern gravel bikes have slack angles and some modern gravel bikes have fairly traditional angles. Similarly, some classic gravel bikes(mtb, touring, hybrid) have slack angles and some classic gravel bikes have fairly traditional angles. What's really wild is that some modern gravel bikes have slack head tube andlges and steep seat tube angles. What?! Crazy, huh?
Point is, there is no single geometry that is 'right' and a quick look at 10 different modern gravel bikes would easily show that there is no single right frame angle.
- Disc brakes- I have 1 disc frame and 8 rim frames right now, and the hydraulic disc frame brakes easier/better in dry and wet conditions. I don't actually need the disc brakes since I have managed to live just fine with rim brakes up to the point when I got disc brakes, but hydraulic disc brakes are a clear improvement for me. Like above, preferences vary and others will disagree. Cool. Having ridden geavel for years on both though, hydraulic required less pressure to operate and has better feel both initially and thru the full pull of the lever. Disc brakes also allow for wider rims and an increased use of carbon rims. Again, you may not care about either of those things, but that doesn't make the comment incorrect.
The 'any bike is a geavel bike' comment is quite frankly worthless. Its like saying any bike in a mountain bike if you ride it on singletrack down Aspen. Or any bike is a touring bike if you kludge a rack on and carry the rest in a backpack. Any bike is a track bike if you bring it to the velodrome.
Yada Yada.
No, actually not every bike is a mountain bike, even if you take it on singletrack down a mountain. And no, not every bike is a touring bike, even if you tour on it.
There are some key differences between bikes styles that exist because it has been shown that those differences help make a bike better for a specific use. It's why you don't see a downhill competition using road bikes and you don't see a 29er with knobs on the track.
If someone is starting at the beginning, I don't know why anyone would steer them away from common and we'll accepted general features and push them towards something niche/quirky.
Its funny- your questioning the benefit of flared bars and disc brakes is the same feeling I had when I read comments about how 27x1 1/4 is plenty of width for gravel. I read that and similar comments and questioned what the benefit of that is. There is 0 downside to a quality wider tire since it will be more comfortable due to lower pressure and will likely roll faster even at a lower pressure since it will deflect less. But apparently faster rolling and more comfort isn't what some prioritize.
Likes For mstateglfr:
Sunshine
Liked 7,595 Times
I think “anything goes” is part of why it’s popular. It seems in a world of increasing specialization a “new” bike was needed.
Sunshine
Liked 7,595 Times
And I am hesitant to say 38 is the mean or median tire size for gravel riding.
Bikes: 1964(?) Frejus Tour de France, 1967(?) Dawes Double Blue, 1979 Trek 710, 1982 Claud Butler Dalesman, 1983 Schwinn Paramount Elite, 2014 Brompton, maybe a couple more
Quoted: 310 Post(s)
Liked 680 Times
I have been working on a 1981-ish Peugeot Competition (PKN-10). Thread here.
It came with 27" wheels for the American market, but I could not really fit 1 1/4 tires at the chain stays (plenty of clearance everywhere else). I put a set of temporary 700x35s on it, and they barely fit.
The weird thing is, the stays have huge dimples centered right about where a fat tire on a 650b wheel would go. Definitely not where the original spec tires would go. I'm gonna try it and see if I can make 650bs work, but here is the part that is more relevant to this thread.
After I noticed this, I looked at 80s road bikes in two different co-ops, and the ones that have dimpled chain stays have the dimples in very different places. Some of them are perfect for the wheels the bike came with. But some of them are like the Peugeot, with huge dimples that are nowhere near where they would need to be if you wanted to put fatter tires on the original wheels.
At some point maybe I will post a thread asking frame builders if there is some other reason to put big dimples in a chain stay besides allowing wider tires. For purposes of this thread, the question is this: has anybody else noticed these big dimples on some 80s chain stays that seem to beg for a 650b conversion?
DYI? Do yourself it?
To the OP, others have already said, but I'll echo my approach. I took a late 80s Rockhopper and put on wide drop bars with bar end shifters. Kept the gearing and brake calipers. It's a blast to ride. You may have to play around with the cockpit setup when doing something different from the original setup. So, it can be worthwhile to consider geometry. The advantage of a new packaged gravel bike is the geometry has been setup already. But, that doesn't mean you can't DIY. Or DYI.
Likes For mattk42:
Quoted: 13 Post(s)
Liked 43 Times
I put 700 x 35c on my '85 Nishiki Continental and only have a couple mil space front and back, no room for fenders - if you look close at this pic, you can just make out how little space there is between tire and brake bridge. I haven't tried larger tires but doubt they'd fit.
It rides nicely on road/ruff road/packed gravel (I haven't taken it on anything looser), there is no rubbing at all but I can't install the rear wheel inflated and I was disappointed that I couldn't go with fenders. The bike is really a touch small for me so it may move on before too long anyway. With pannier racks, it'd make a very nice long-distance mostly road tourer (which is what it was, after all).
There are compromises for sure starting with a C&V.
Bikes: 1957 Motobecane camping bike, 1974 Manufrance Super Course STC, 1977 Peugeot camping bike, 1978 Liberia C15
Quoted: 37 Post(s)
Liked 127 Times
Anything goes, but one thing you don't want is low trail. I have two bikes with low trail, but on bouncy roads it's a lot of work to keep them going in a straight line forward, and taking corners is unpleasant.
Bikes: '38 Schwinn New World, ’69 Peugeot PX-10, '72 Peugeot PX-10, ‘7? Valgan, '78 Raleigh Comp GS, ’79 Holdsworth Pro, ’80 Peugeot TH-8 tandem, '87 Trek 400T, ‘7? Raleigh Sports, ‘7? Raleigh Superbe, ‘6? Hercules
Quoted: 765 Post(s)
Liked 1,616 Times
For me, the primary concern for gravel is fat & supple tires. Sure, there are masochists out there who will scoff and say "I ride gravel all the time on 25c tires!" A regular riding buddy used to be on an older, aluminum Trek road bike with 25c tires on rides we'd do together with a lot of gravel- I don't know how he did it, it looked miserable to me. Somehow he ended up with a not-so-old Fuji 'gravel' bike that can take fat tires and now he's saying 'I can't believe I was riding these roads on 25c tires- that was awful!'
Can you DIY a gravel bike? Of course! Not so much gravel-specific, but more 'all-road', I would (and do) take my '72 PX-10 650b conversion & '87 Trek 400t 650b conversion bikes pretty much anywhere.
I will note that the bar-end shifters on the Trek are a little nicer to have on really rough gravel/trails.
Likes For ehcoplex:
Quoted: 408 Post(s)
Liked 184 Times
Gravel bikes look like 1980's Rock Hoppers to me. One thing that appealed to me about the Kona Sutra was the versatility. Our family still rides two Rock Hoppers. We upgraded some of the components on one.
Not lost wanderer.
Quoted: 890 Post(s)
Liked 1,020 Times
My dedicated All-road/Gravel
a modified hybrid from Japan.
Cambodia bikes, Bridgestone SRAM 2 speed, 2012 Fuji Stratos...
Sunshine
Liked 7,595 Times
Volunteer wrench
Bikes: 1971 Schwinn Suburan, 1971 Peugoet UO8, 1984 Nishiki Cresta, 1984 Nishiki Olympic, 1987 Schwinn Super Sport, 1996 Waterford 1250, 2018 Cannondale Synaspe Carbon
Quoted: 19 Post(s)
Liked 55 Times
I had a Cannondale R500 that I bought new in the early '90s. A few years later I moved into a Waterford 1250. The R500 was then fitted with 700x30 knobby tires, The clearance was minimal, especially on the front. But I rode it for years for gravel, mainly rail trails and logging roads. It was a lot of fun even in muddy conditions. Last year, I restored it to it's factory specs and sold it. Now I'm contemplating a new build starting with a Nishiki Cresta or a Univega Super Ten that are sitting behind the house.
aged to perfection
Quoted: 852 Post(s)
Liked 1,281 Times
/markp
Sunshine
Liked 7,595 Times
I struggle to think of modern gravel bikes that have 460mm chainstays, bottom bracket drop that looks to be only like 40mm, a seat angle that is like 71 degrees, or a crazy slack head tube angle plus high fork rake that result in goofy low trail.
^ that is all fundamental geometry differences and doesnt even get into the brake style or drop bar that both heavily impact the look.
aged to perfection
Quoted: 852 Post(s)
Liked 1,281 Times
there is definitely a cycling industrial complex that is determined to sell us more stuff every year. More speeds, more gears, etc
however it's great when a bike is not so "purpose specific" that it cannot be adapted to serve multiple roles and ride / surface types
my Dinucci was built with clearance for 35mm tires (tyres) and fenders, with fender eyelets for just this reason !
if you're going to own a bike for years you need this flexibility. Pro racers and wanna bees toss their bikes after each season.
Also, gugie can add cantilevers and rack mounts to vintage Raleighs and bike so adapted make excellent mixed road tourers.
/markp
/markp
Likes For mpetry912:
Likes For LeftCoastJon:
1975 Peugeot PX50L gravel bike.
”Gravel specific” this and that is mostly marketing, and fashion items always command higher prices. Therefore, riding or adapting what you already have is sometimes the most sensible approach, especially when DIY is half of the hobby and if there happens to be boxes of stuff readily available.
Old bikes don’t become new even with bucket full of new components and a welding torch, but can’t really beat the feeling of riding your own creation. Pug above took me about a year and ~1k to build, it’s bit noodle when loaded but it sure is the most versatile bike I own.
For starting points to DIY, I’m repeating what others have already said: old sport tourers are often the best candidates.
Likes For gesta:
Quoted: 1965 Post(s)
Liked 2,058 Times
Why do people ride on gravel? If you ride on gravel roads or the gravel at the curb, are you trying to just stay upright or are you trying to go as fast as possible for PRs or maybe you are racing? I haven't gotten into the serious -- think Gravel Racing -- gravel bikes but when I did do such a thing wrt to CX, UCI had limits on tire widths but geometry was all over the place on pro level bikes. I'm pretty sure it is the same for gravel.
Mad bike riding scientist
Quoted: 6252 Post(s)
Liked 4,278 Times
Oh, sure, every bike I build is a DIY gravel bike.
Also any bike is a gravel bike, if you ride on gravel with it!
I like '80s touring frames (built for 27" wheels but the canti brakes reach 700c wheels and offer better tire clearance) with 700c wheels and 700x38 tires. Often they will fit fenders too! There are so many '80s tourers to choose from. You can almost always find one for sale on your local CL or fb marketplace.
Here's a list.
Bridgestone RB-T
Bridgestone T-500
Bridgestone T-700
Centurion Pro Tour
Fuji Touring Series IV
Fuji Touring Series V
Fuji Saratoga
Kuwahara Caravan
Lotus Odyssey
Miyata 610
Miyata 1000
Nishiki Continental
Nishiki Cresta GT
Nishiki Riviera GT
Nishiki Seral
Novara Randonee
Panasonic PT-3500
Panasonic PT-5000
Panasonic Pro Touring
Panasonic Touring Deluxe
Raleigh Alyeska
Raleigh Kodiak (careful this one is also the name for a mountain bike)
Raleigh Portage
Raleigh Super Tourer
Raleigh Touring 18
Schwinn Paramount P15-9 Tourer
Schwinn Passage
Schwinn Voyageur/Voyageur SP
Shogun 2000
Specialized Expedition
Takara Overland
Trek 520
Trek 720
Univega Gran Turismo
Univega Specialissima
Here's a list.
Bridgestone RB-T
Bridgestone T-500
Bridgestone T-700
Centurion Pro Tour
Fuji Saratoga
Kuwahara Caravan
Lotus Odyssey
Miyata 610
Miyata 1000
Nishiki Continental
Nishiki Cresta GT
Nishiki Riviera GT
Nishiki Seral
Novara Randonee
Panasonic PT-3500
Panasonic PT-5000
Raleigh Alyeska
Raleigh Portage
Raleigh Touring 18
Schwinn Passage
Shogun 2000
Takara Overland
Trek 520
Trek 720
This one is at the start of a 76 mile ride on the High Line Canal Trail in the metro Denver area. About half of the trail is unpaved. It had no problems with handling the ride.
This Cannondale did around 700 miles of dirt riding on the tow paths and rail trails along the route from Toledo, OH across Ontario to New York then down along the Pennsylvania/New Jersey border and back up the C&O/GAP to Pittsburgh. Here it is north of Harper’s Ferry.
Other ones to consider are any of the millions of mountain bikes…both steel or aluminum… from rigid to front suspension to dually that have been made since 1983. Here are some of my “gravel” bikes. From 1985, a Miyata Ridge Runner. It’s rigid which is right in keeping with modern goofy idea of riding rigid bikes in hair shirts with nail bed saddles.
Hardtail from 1999. Fully capable of gravel and more.
A soft tail from 1998. Ideal for taking the edge off of hits without full suspension.
And then there is the ultimate dually…a Specialized Epic FSR. Unlike most double squishies, this one has a rear shock that locks out when pushed down from above…like when pedaling…but opens when hit from below. The rear suspension is active when you need it…in the rough…and inactive when you don’t. Where people on their rigid bikes with their hair shirts and nail saddles are crawling through rock gardens and washboards, this bike blasts right past them with barely a thought.
I did the rigid thing for many years. I earned my strips when it comes to gravel. Suspension…front suspension at the very least…makes riding gravel much more enjoyable.
Stuart Black
Stuart Black
Sunshine
Liked 7,595 Times
I look at it from the opposite side of you- why wouldn't I ride gravel?
In general, there is no tire width limitation for gravel races. Not sure if you were suggesting there is, but just wanted to clarify.
Liked 4,278 Times
Personally, I think of the dedicated gravel bike idea as a bit silly. I like to ride gravel roads but I do it on a more appropriate bike or touring bike that I already have. There’s nothing wrong with using the right tool for the job.
Stuart Black
Stuart Black
Likes For cyccommute:
