Do you trust brazed on eyelets?
Quoted: 213 Post(s)
Liked 6 Times
if your unsure about wether it's a good idea that tells me I should be too haha
maybe Pclamps or another workaround then...
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,802 Times
Thanks for the detailed explanation. That does make sense. Your solution sounds like a very good idea.
It occurs to me that in older days, if a bike fell over, the Pletscher rack or maybe Blackburn rack would have bent or broken long before the braze on -- assuming the eyelet is brazed on. With a modern tubular steel rack, the eyelet is much more likely to be the failure point. Also, I suspect people now tend to load bikes more heavily than in the past when bike touring.
Likes For gugie:
Quoted: 1608 Post(s)
Liked 2,216 Times
The strength is not in the silver material but in the bond of the joint, hence the flux to ensure good bond between dissimilar materials.. Silver can be used to fill.
If you want some interesting information about frame building, go over to the frame building forum. Lots of really good info there.
Likes For SJX426:
Liked 5,802 Times
This is one of those areas that would be worthly of a university project. You could have an experienced frame builder do several sets each of simulated dropout braze-ons, and do destructive testing with equipment to measure forces. Back this up with some FEA, determine the failure mechanisms for each method. My retirement plan includes upping my torchwork time. My wife and I plan on being in an area that has a University with a good engineering project, this is the type of project I'd love to be involved with. Published results would help guide framebuilders worldwide in best known methods.
Likes For gugie:
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
To clarify, to common filler we call "silver" is usually 56% silver which does not build up well but has great capillary action (filling lugs and what not). There are other silver fillers like 50n or 46% silver that can build up like brass (bronze). These are what stainless fillet brazed bikes are generally built with. Search for Kirk frames for some amazing examples.
I'm not one for fawning over bicycles, but I do believe that our bikes communicate with us, and what this bike is saying is, "You're an idiot." BikeSnobNYC
My experience is the opposite. I think people load bikes less heavily when touring vs BITD. Part of it is lighter equipment - lighter tents, sleeping bags, cooking gear, etc. I have a Rip Van Winkle life with bikes, rode and toured a lot in my youth, stopped when wife, house, and kids sucked up my time, and now I'm back restarting my youth. Personally I know I carry signficantly less gear weight, and only use steel racks where in my youth aluminum was the choice, and I've broken aluminum ones in the past, always near the eyelet.
I definitely rode a lot from junior high through high school, but didn't try bike touring until summers while in college. I never broke anything, but I didn't do *that* much of it. The most epic one for me was about 24 days, IIRC.
For sure much of my own camping gear is lighter than the vintage stuff, but even BITD you could find light gear, if sufficiently motivated. Down bags were always light. Hoop tents were light, if you even bothered with a tent. Water purifier? What's that? Actually I think tents have been going backwards the last couple decades, but that's pretty OT. In general though, yeah, gear was heavier. I did have one buddy who rode across the country on his Trek 720, and he had and used one of those Optimus suitcase stoves. It was hilarious. Must have weighed like 8 lbs.*
EDIT * Ha, I looked it up and they only weighed 28oz full. They looked like they weighed 8 lbs.
Quoted: 964 Post(s)
Liked 1,451 Times
I'd imagine it always varied by individual, then as now. Now that you point it out, the ultra light crowd seems to have had a lot of influence in bike camping as well as backpacking. Still, there are those that pack everything: a laptop, a phone, a GPS, a camp seat, etc.
Anyway, with my jumble of hand-me-downs (usually heavy stuff because heavy stuff lasts long enough to hand down) and cheap new stuff (usually heavy because it's cheap), I struggle keeping the load down these days, even on a short trip. Luckily I have nice Nitto racks and 48 spoke wheels on my Ron Cooper to support it all, purchased and built out of post-traumatic stress from all the touring breakdowns I suffered in my teens.
Señor Member
Quoted: 1492 Post(s)
Liked 1,095 Times
My reflexive response is "yes". That said, I have an offering to the discourse.
I do not understand there to be a difference in strength between "factory" mounts and "after-market" mounts. If, for example, I were to have after-the-fact attachment points added by someone competent, I would trust them as much as I would an attachment that was there as the result of building the frame. Is there a difference?
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
Two people I really respect with years of experience, so you can see there can be a difference of opinion. I am a mere Padawan here. Doug's solution perhaps "goes the extra mile"
That's kind of how I see this problem. There's a saying among programmers -- "has" proves "can". So while an engineer may be interested to find out why the eyelet sometimes breaks off, I'm satisfied just to know that it can.
My Bikes
My Bikes
1/2 as far in 2x the time
Bikes: Yes, Please.
Quoted: 499 Post(s)
Liked 285 Times
Frame builders have a choice of brazing with silver or brass. Brass requires a higher temperature flame. Home builders like silver because the equipment requirements and the lower temperature. Lower temperature has less of an impact on the frame material. Both are acceptable. The issue is the cost of the silver rod. This is much like soldering but with much different temperatures and rod material. A bunch of metallurgy considerations.
Best, Eric
I seem to have lost what little mind I had left before this all started.
Bikes: Yes, Please.
Quoted: 499 Post(s)
Liked 285 Times
Quoted: 1079 Post(s)
Liked 1,899 Times
Glad this thread didn't come up before I carted my kids on a rear mounted seat connected to brazed on eyelets for about seven years.
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
If you have a choice, by all means mount the rack on the integral eyelets and the mudguards on the brazed-on eyelets. But if your choice is between a hardware store P-clamp and a brazed-on eyelet, I'd trust the brazed-on eyelet to handle load better.
Liked 5,802 Times
These are things I think of when putting torch to frame - what's the best way I can do this? I'd like to think I'm making small improvements every time.
Liked 5,802 Times
Liked 5,802 Times
BTW, a 24 day tour is a fantasy dream for me! It's long enough to forget that your other life doesn't exist, and you're new daily reality is riding a bike over hill and dale. Would love to sit down and share a beer and hear your stories of that tour.
framebuilder
The original question “do you trust a brazed on eyelet” suggests an all or nothing situation. It will last or it won’t. The answer really has to be under what circumstances? There is not a black and white answer. As you can see now it really depends on the chances of enough force being applied to the brazed-on eyelet that might exceed its yield strength. I provided an example of a loaded rack tipping over that did exceed what a properly brazed-on eyelet could withstand. Of course that is an unusual circumstance but it can happen. As a professional builder I have to assume that a customer does not understand the differences between the strength of a brazed-on eyelet and one forged as part of the dropout and they might blame me if a brazed one breaks and then expect me to fix it for free. That fix might include disassembling the bike, rebrazing the eyelet, repainting the area and then putting everything back together again. That can be a several hundred dollar repair that I want to avoid. And I can avoid the problem by attaching a rear rack with a different kind of braze-on. So this is why the answer is not black and white but rather it depends.
Quoted: 702 Post(s)
Liked 672 Times
The derailleur hanger of this abandoned bike was lopped off by some genius and I would like to have someone restore the dropout. Can it be done and can it be trusted?
Blackburn used to sell rear rack attachments for frames without eyelets. They fit thru the opening of the dropout, so "in" rather than "on" the dropout. They are removable, if you ever take off the rack.
P-clamps rotate. P-clamps scratch.
Quoted: 964 Post(s)
Liked 1,451 Times
Here's a thread on exactly this topic:
Should I trust this welded on derailleur hanger?
Likes For scarlson:
Quoted: 702 Post(s)
Liked 672 Times
Yes. That one's been done quite a bit, I believe. You can also probably save the paintjob, if you wrap the stays and upper "web" of the dropout with wet rags or clay.
Randomhead
Liked 3,699 Times
Señor Member
Liked 1,095 Times
Thanks, Doug. I hadn't been thinking of the dropouts, and what you've explained makes perfect sense.
If you were to attach a long rod to an eyelet that is originally part of a steel dropout, it would take a lot of bending force to break it off. In fact it probably won’t break but bend because it is all the same metal. If you were to do the same experiment with eyelets that were brazed onto a dropout, you would discover that it takes less force to break off an eyelet. If you could somehow measure the amount of force used before it would break, you would find out that eyelets brazed with bronze it would take more force than if it was brazed with 56% silver. There are other silver based brazing materials that would take more force to break than the 56% but not as much force as it would if brass is used.
Liked 5,802 Times
QUOTE=unterhausen;21590823]When I taught engineering design a couple of years ago, a project cost $3000. I can use a fatigue machine, but I'm not sure that's really the failure mode that builders worry about. I think that probably just hitting a brazed on mount with a hammer and looking for cracks in a microscope would be as good of a test as anything. Just to qualify that, I am totally against that kind of testing for most brazing. I have seen some incredibly inept brazing survive such a test. I have my suspicions about eyelets that fail. I suppose I should do some destructive testing of my work. Not sure where you would publish it,maybe in an open source journal.
Just to be clear, we are talking about eyelets like the ones that come on dropouts. Just about every other kind of rack attachment is beyond safe. I'm pretty sure the difference between built-in and brazed on is ductility. It's also not too hard to braze something like an eyelet and not get full penetration with complete bonding in the center. At least that's my working theory on why people have had brazed on eyelets fail.[/QUOTE]
I was thinking this would be an undergraduate project, mechanical engineering curricula usually has a lab class, often with an "open" experiment at the end for the student to design. Publishing might be limited to Bike Forums!
I agree that almost all brazed on bit failures are due to incomplete penetration, leaving a stress riser.
