#4651
Quoted: 2332 Post(s)
Liked 5,049 Times
Nothing major today but just had the Prologue TT in the stand sorting it out to make sure it's ready to go. My buddy had used it in a triathlon so I had to make sure everything was working fine. Also swapped on a saddle I can use, my Keo pedals and then setup my fit on it. Gonna see if I get a warm, calm day this week to take this out to Antelope Island for a run. 9 mile long causeway leading from the mainland to the island that perfect for getting in a fast ride on this weird beast. My normal route has too many turns, intersections, etc to really use this one.
Hopefully the shoulder holds together and lets me get a full ride in on this. First since the wreck on the Kona in 2018 that jacked me up for riding on this.
Steel is real...and comfy.
#4652
Quoted: 4523 Post(s)
Liked 6,417 Times
I did recently swap in a new rim on one of my main ride wheels after the wacky offset Shimano rim cracked at half a dozen of the spoke holes, it had plenty of miles but was a POS none the less.
Got it pretty true, centered and tensioned ok, took it to a guru for fine tune only to realize the NDS spokes are probably too short, damnit Jim.
#4654
Bikes: 2020 Lynskey GR300, 1987 Diamondback Ascent, 1991 Skykomish Marble Point, 1994 Specialized Stumpjumper FSR, 1996 Specialized Stumpjumper M2 FS, 1992 GT Karakoram
Quoted: 69 Post(s)
Liked 226 Times
This 92 GT Karakoram. First time using a clay bar to remove some sludgy frame buildup. Not quite the result I was hoping for but I’ll take it.
Likes For Wilbur76:
#4655
Tried to modernize the drivetrain on the super sport during last winters build and got frustrated with bottom bracket adapter. Fast forward to today and decided to polish up original crank and installed and whola, back in business. A real mess of mismatched parts to sort out this winter.
Likes For Kdogbikes:
#4656
Edumacator
Quoted: 2471 Post(s)
Liked 3,192 Times
Where the poop did you get those straps?
1987 Crest Cannondale, 1987 Basso Gap, 1992 Rossin Performance EL, 1990ish Van Tuyl, 1985 Trek 670, 2003 Pinarello Surprise, 1990ish MBK Atlantique, 1987 Peugeot Competition, 1987 Nishiki Tri-A, 1981 Faggin, 1996 Cannondale M500, 1984 Mercian, 1982 AD SuperLeicht, 1985 Massi (model unknown), 1988 Daccordi Griffe , 1989 Fauxsin MTB, 1981 Ciocc Mockba, 1992 Bianchi Giro, 1977 Colnago Super, 1971 Raleigh International, 1998 Corratec Ap & Dun, 1991 Peugeot Slimestone
#4657
Edumacator
Liked 3,192 Times
I LOVE the skeletons...
Likes For jdawginsc:
#4658
Total Scrounge
Bikes: 71 International 72 Super Course 83 Gap
Quoted: 327 Post(s)
Liked 924 Times
Received my Sapim 12/13g spokes and built a wheel around my Atom drum brake hub. It was a bit of an adventure because those spokes are large and in charge! noglider might have had a good point about building 2x around such a large flange, because it would reduce the angle that the nipples leave the rim. We’ll just see how it holds up!
If it fails, I’ll have to order custom spokes in the 240ish length, so I’m hoping it doesn’t come to that. Out of the box, these were bent a bit shy of 90 degrees, so I drilled a 3mm hole in a piece of steel, and corrected them a bit, so the hub flange didn’t take that stress.
It was a chore getting the tensionometer readings on these, but I got things where the drive side nipples felt like they didn’t want to get a whole lot tighter, then went around and got tension as even as possible. We’ll see!
#4659
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
#4661
Bikes: 1965 Dilecta Le Blanc, 1956 Royal Nord, 1972 Raleigh Sports, 1972 CCM Turismo,1976 SuperCycle Excalibur, 2014 Salsa Vaya, 2017 Felt DD70, 2019 Giant Lafree and others
Quoted: 351 Post(s)
Liked 606 Times
Does a grinder with a cut-off wheel pass as "wrenching"? This wretched Peugeot parts bike resisted all efforts to remove the cotters and I did want to save the frame. With goggles and grinder in hand, I proceeded to quickly remove the rusty, chrome paint sprayed crankset.( I have a better identical one in the parts bin). It must have been awful to ride with that cotter installation induced offset. I have mixed feelings about this bike. It and another Peugeot were donated by the owners daughter after he passed away while riding the bike. I had met him once, but its a very sad time for the family. I have another Peugeot project for a friend to give back to his brother so the parts are welcome.
We are what we reflect. We are the changes that we bring to this world. Ride often. -Geo.-
#4663
Total Scrounge
Quoted: 327 Post(s)
Liked 924 Times
#4664
VO fender install
Almost done installing these. Need to address minor mounting bolt rub on the front tire but other than that is ready for a test run. VO fenders get some heat for being difficult to install but I have to say they provide plenty of hardware and explain how to use it. It does require patience and some know how otherwise can become frustrating. I enjoyed the process..
I thought the leather washers were cool but only needed to use 1.
Grinding the end of the bolt should do the trick
#4665
Picked up this 1974-ish Peugeot UO8. No wheels (I have a set on hand), but the crankset had been upgraded to a Stronglight 52-40, and the seatpost upgraded to a Campagnolo. The original Simplex derailleurs look solid but I haven't decided whether to keep them on, or swap at least the front out as a precaution (understand these are prone to failure). Paint and decals are all in excellent shape and the grime is cleaning off nicely. Think this will look really good once it is done!
Likes For KenNC:
#4667
Quoted: 90 Post(s)
Liked 137 Times
I have been trying to get my shop cleaned up a bit and have a bunch of bikes that have been striped and taking up room for way to long so I started putting them back together and getting them ready to move on to new homes. I just finished a Nishiki Prestige that had been sitting here apart for 2 or 3yrs, bike was a dirty mess & for whatever reason the PO painted every part that had chrome plating Gold. I cleaned everything & removed the Gold paint. The bike had Suntour Cyclone M series Drivetrain that I replaced the RD & Shifters ( already had a Accushift FW on it ) with Cyclone a6000 accushift models, new headset & BB were needed & I had a Suntour Cyclone BB that was right at home here, a new Tange headset was installed.I also upgraded the brakes to Dual Pivots with Koolstop pads. Bike rides great, shifts perfect & stops on a dime and gives you change lol.
Likes For Glennfordx4:
#4668
WV is not flat..
Likes For brandenjs:
#4672
Bikes: 1964 Huffy Sportsman, 1972 Fuji Newest, 1973 Schwinn Super Sport (3), 1982 Trek 412, 1983 Trek 700, 1989 Miyata 1000LT, 1991 Bianchi Boardwalk, plus others
Quoted: 584 Post(s)
Liked 702 Times
110 spider for stock crank
#4673
Edumacator
Liked 3,192 Times
Oh, crap. Did the freewheel body remain fused to the hub? How did you attempt to remove?
Plus a lost satellite dish.
#4674
buy my bikes
Bikes: my very own customized GUNNAR CrossHairs
Quoted: 520 Post(s)
Liked 433 Times
It's a 6spd Suntour freewheel on a 30~35 year old HardRock. I scavenged the complete bike from the curb side a couple years ago. Cleaned it a little, and then sold it to a friend for $50. I offered it for free, but he wanted to give me something. And since I'm greedy, $50.
Short story long, he got divorced and needed to get his garage cleaned out. So I got the bike back for free. And he gave me a bunch of other stuff. Now I'm thinking - I'll make this my "in-law" bike, it can live down in Louisville, and I'll have a coffeeneuring bike for holidays. The rear wheel felt really looooose. So I think - I'll re-pack the hub!
The Suntour freewheel only had three prongs where it should have 4. So it's looking worse. I put my freewheel tool (the 4 prong deal) and put wrench on it. But my wife and I are about to go to a party, I'm in a little bit of a hurry and just want to break it looooose.
So I put the freewheel tool in a vice, stat rotating the whole wheel like in the YouTube video, and the whole deal just kind of POP! s. I'm thinking - success! Then @#$% starts falling on the floor - the 3 prongs, ball bearings.
Dang - bummer. Anyway, considering the money invested (..... like I invested negative $50 ...?) I'm probably not going to invest any more time. I have much better 26 inch wheels I can put on this thing. I'm the local nexus of vintage bike-crap, so I've got better 26in wheels. Hopefully the Suntour shifter / derailleur will cooperate with a 7 or 8 spd wheel.
good times.
#4675
Edumacator
Liked 3,192 Times
yea.... pretty much.
good times.
good times.
