another cheapie tubular thread
What??? Only 2 wheels?
Quoted: 1223 Post(s)
Liked 645 Times
Bob, that black P-mount is one serious-looking bike! We'll have to go for a ride one time when you ride that and I ride the black Bianchi, and I won't be able to keep up with you.
Real cyclists use toe clips.
jimmuller
jimmuller
Vittoria Corsa Elite ride nice, but I've flatted twice in 300 miles. I also use YJs
Quoted: 2357 Post(s)
Liked 2,877 Times
An update rim is GP-4 so pretty heavy duty which is good and it is in really good shape
Based on the input I just placed and order with ribble and am going the way of tufo. S33 pro in 24, mounting tape and sealant
so with luck it will soon be let the tubular roll
Quoted: 660 Post(s)
Liked 601 Times
I opted for 3for50 Servizio Corsa tires. They went on the rims for overnight prestretch rather easily considering the worst case scenarios I've read here. Also, they run straight and true. Next comes glue. The bike would deserve better according to some I suppose, but for the budget and short miles it will have I'm sure these are a good starter tire.
OMC
Bikes: Specialized Allez Sprint, Look 585, Specialized Allez Comp Race
Quoted: 461 Post(s)
Liked 116 Times
Yup, cost is ~$8 or so.
I've ordered a pair of Specialized Espoir tubulars in 25mm, MSRP is $40 each. They'll go on my c. 2002 Zipp 303s, replacing 25mm Gatorskins. They've got to be better than Gatorskins. I think steel shod wagon wheels probably ride and stick better than Gatorskins.
Regards,
Chuck
Demain, on roule!
Regards,
Chuck
Demain, on roule!
Liked 2,877 Times
this is my first order, but when I had one tire in the order shipping was $8.00 by total order was over $100 and was free so at some dollar amount it kicked in free shipping.
the tufo's were at ~30 a little less than probike kit and about $20 less than what I could find in us based sites, and ribble had everything (tires, tape, sealant, and event got a spare valve just becuase) and it was all a lot less than what i could find here.
this helpd in decision to go higher grade tires. The total cost (tires, glue or tape, sealant) was about $40 to $50 more compared to cheaper options. And I am going to commute on this also. as cheap as i try to be I had to look at TCO (total cost of ownership) and figured I was ahead
Quoted: 1964 Post(s)
Liked 2,055 Times
I just cleaned off some old gl 330s with dried up red glue. First I chipped off a bunch with a small screwdriver and the used Citristrip adhesive remover. I have used the Citristrip on Continental glue too. It works better than acetone, toluene, or any of the nasty stuff I used in the past. I started using tubulars recently with Gatorskins because I didn't want to flat right away and when I did flat, I wanted to patch them. 25 mm Gatorskins at 90 psi ride nicer than 22s at 100 psi and +\- the same as Competitions at 100 in my opinion. Next up is regular Sprinters.
Quoted: 378 Post(s)
Liked 1,412 Times
Quoted: 660 Post(s)
Liked 601 Times
+10. Glue is not a problem when mounting the tires. Someday I will add to my sew-up experiences when I change a flat. Full Monty, indeed.
Bikes: '92 22" Cannondale M2000, '92 Cannondale R1000 Tandem, another modern Canndondale tandem, Two Holy Grail '86 Cannondale ST800s 27" (68.5cm) Touring bike w/Superbe Pro components and Phil Wood hubs. A bunch of other 27" ST frames & bikes.
Quoted: 110 Post(s)
For those of us that are totally ignorant to the tubular world…how often do you get a flat with tubular tires? What do you do when you are on a ride and you hold up an arm and the Service Course Mavic Neutral Support car doesn't up. What actually do you do with a flat out on the road? Is there a weight limit for tubulars?
I love the Mavic Classics tubular wheel set. Bearings like butter, straight pull design. This was the pro's pro wheel set and the choice for many teams on the cobbles for years. However, I can't ride 'em if I'm intimidated by repairing a flat.
Quoted: 556 Post(s)
Liked 133 Times
Just pull off the road, remove the wheel, remove the tire and install the spare which is under your saddle, and has been pre-prepped with a light coat of glue on the base tape. Pump it up and go on your way. Easy. If you have a second flat however, that's when you look for a comfortable spot in a grassy glade beneath the trees, and whip out your repair kit.
Quoted: 7371 Post(s)
Liked 2,520 Times
@mtnbke, tubulars require more maintenance overall, but the on-the-road flat is one place where it's easier. You remove the wheel, remove the tire, and slap your spare on. Maybe your spare tire will have residual glue on it. Your rim certainly will. Rolling tires off the rim is actually rare, so just be a little careful. I rode tubulars without fresh glue many times, and I never rolled a tire.
Most tubulars are lightweight tires, so they get punctures about as often as clincher tires of similar weight, which is to say pretty often. Still, getting two flats on a single ride is a very rare event. When I rode tubulars on the road, I only carried one spare.
Liked 2,055 Times
My first on the road flat was a bear to change because I followed the Continental intructions and used 2 tubes per new tire with new rims. I use less and less and changing gets easier and easier. Fewer pinch flats with tubies but the same frequency of punctures. I got a new saddle bag that will hold two spares easy for long rides.
Liked 2,877 Times
The box from ribble arrived.....less than a week. Now to finish getting the old red glue off and clean and grease the bearings. Then I can catch up with oldsCool and get the tufos on and report back
just out of curiosity does anyone know what the brand the red glue was/is?
Liked 2,520 Times
Clement.
Liked 2,877 Times
Between work craziness and some vacation, I got the old glue off, wheels greased and trued and the tufos on.
I used the Tufo tape and the install went pretty well once I figured you need to be in a position to stretch the tire, and hold it stretched bit before the next section.
the tire centered perfectly with no fussing needed.
I have done some short rides and my best description of the ride is "smooth"
I put the tufo sealant in and am hoping for the best. I also have a bottle of extreme sealant which will by my first try if I get a flat
but for you guys who run Tufo's (Robbie tunes) how big a deal is it if I have to pull a punctured tire off and replace with the spare I got?
I thought I read that the tufo tape is great, but makes tire changes harder?
Experience, Hints ???
thanks
thanks
Bikes: yes
Quoted: 1281 Post(s)
Liked 644 Times
How are you liking the Gatorskin Tubies after a few weeks now?
I've used Gatorskin clinchers for thousands of miles and while I find the flat protection to be pretty good (only flat I've had was a pinch flat), the ride quality is pretty harsh and they seem slick/not grippy. Just wondering if the tubies are better.
I've been running conti sprinter tubies on my C&V and the ride quality is pretty great; although I tore up my rear tire the other day after I installed some new brake pads and did a couple practice stops. You would think it would last longer than about 1500 miles or so.
Freewheel Medic
Quoted: 1463 Post(s)
Liked 2,220 Times
Pretty bike.
I also ride the Gatorskin clinchers, and the ride is not comparable to the Gator Tubulars. These are the first tubulars I've ridden, so I can't compare to other tubulars. But compared to clinchers, these are wonderful. Hope this is helpful.
Bob
Bob
Liked 2,520 Times
I can't tell from here if you over glue. How much glue do you use on a tire? Don't think of prying the tire off. Think of rolling it off. Or pushing it off to the side.
I think we're I've gone wrong is that I apply a thin coat to the rim. Mount the tire. The last few times I'm unhappy with the "lump" near the stem so I pull the tire off while the glue is still wet to try again. I notice that parts of the rim no longer have glue there. So I apply another thin count and repeat.
Pretty bike.
As for tubies, used to ride Clement Criterium cottons, used Tubasti cement, and changing flats was a piece of cake. Using the Tubasti, I guess I wasn't riding in the mountains, but never had a roll off.
Quoted: 1361 Post(s)
Liked 425 Times
another cheapie tubular thread~
Only 300+/- miles on a pair of Clement Super Condor. Rear blew out the sidewall. The front is looking 'tired'. Labeled made in Taiwan.
Have a pair of Clement Futur CX awaiting. No markings on them but appear better looking.
