I hate flat tires...
#501
Quoted: 7352 Post(s)
Liked 2,479 Times
Yes. I once brought my fixie to my mother in law's to stay the night, planning to ride to work from there. I realized I didn't have a wrench, and that evening, I went to the supermarket and bought an adjustable wrench. OK, that's neurotic, because it was only one 15-mile ride, but I really don't want to be caught unable to remove a wheel. And what's so hard about carrying a wrench? The weight isn't great.
#502
What??? Only 2 wheels?
Quoted: 1222 Post(s)
Liked 645 Times
I strive mightily to keep the bike light against my sweetie's tendency to put more and more small things into the bags. A 19mm is pretty heavy. Plus I'd need a 10mm, preferably a socket and ratchet, to unhook the drum cable, and a 9mm (or is it 8?) to free the anti-rotation arm. Yeah, we could carry that stuff, already do carry a spoke wrench, a small adjustable, and a small screwdriver. But this is a fairly civilized part of the world. Fools like myself sometimes rely on the kindness of strangers, or at least the kindness of a cell phone call. Failing that I rely on the fact that almost all flats can be patched without needing a completely new tube.
Real cyclists use toe clips.
jimmuller
jimmuller
#503
Quoted: 2338 Post(s)
Liked 2,827 Times
get all ready for the commute home....leaving on time to avoid a little dark and rain....off I go and....damn flat.
quick fix, but have to rejigger the race blades afterward....
am going to add set of tweezers to the kit.....took a bit to get the little wire/thorn out
am averaging 1 flat per 200 miles, but it is not really evenly distributed. Michelin Lithion 2 tires. May think about different tires
on the good side it was totally dark when i finally started but my new 1100 lumen light really lit it up well
#504
Liked 2,479 Times
You're going to hate me for saying this, but I do not hate flat tires. I don't love them, for sure, but they don't ruin my day.
#505
Quoted: 5224 Post(s)
Liked 3,585 Times
the colder it gets, the less happy I am about them. 2 nites ago was outside snacking mid-ride at a bike friendly cafe w 2 floor pumps out front. temps were in the mid 30s but I was dressed for it. young man pulls up (just a sweater & no gloves) & I assume he's locking his bike to go inside. he's there a long time & that's all I noticed. as I was walking past him with my bike to start homeward I ask if he needed help w anything. he says: "yeah actually" turns out his rear tire was low but not flat (unknown reason) & he was having trouble filling it with the pump. simple schrader valve, chose the correct pump (nice cafe has 2 pumps 1 w schrader head 1 w presta head) showed him how to insert valve & lock the pump head by lifting the lever & made him pump it. he did 2 pumps & I'm like "dude you're low on air keeping going!" anyway, problem solved ... maybe
#506
Liked 2,479 Times
True, fixing a flat in the cold sucks. Cold rain is even worse.
#507
Bikes: 2001 LeMond Nevada City, ‘92 Merlin Titanium, '84 Torpado Super Strada, ‘84 Schwinn Tempo, '81 Bianchi Limites, '73 Raleigh Supercourse
Quoted: 161 Post(s)
Liked 69 Times
Yep...on my way home from my ride this morning...picked up a goat head in my front tire.
#508
Quoted: 897 Post(s)
Liked 9 Times
Or as Mickey Roarke's character in the movie Barfly would put it, "I don't hate flat tires. I just seem to feel better when they're not around."
#509
Get off my lawn!
Bikes: 1917 Loomis, 1923 Rudge, 1930 Hercules Renown, 1947 Mclean, 1948 JA Holland, 1955 Hetchins, 1957 Carlton Flyer, 1962 Raleigh Sport, 1978&81 Raleigh Gomp GS', 2010 Raliegh Clubman
Quoted: 93 Post(s)
Liked 98 Times
The mysterious "went flat overnight" syndrome simply means it's time to use another bike for the day. If it were not for flats, a think most of my bikes would never see the light of day.
#510
Bicyclerider4life
I am unfond of flats.
I run 8 ounces of Slime in all my tires*. The rear tires on my trike also have liners.
*The curbside tire on my trailer has an airless foam tube.
"Whenever I see an adult riding a bicycle, I know there is hope for mankind." (H. G. Wells)
#511
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
Yep, the patch I put on two weeks ago, and expressed reservations about here (https://www.bikeforums.net/showpost.php?p=19983500&postcount=495) failed today on a ride through the Pine Barrens. It was strange. I hit a bump hard and it felt like I had pinch flatted. Sure enough the tire went flat. But it wasn't a pinch flat; a patch was leaking.
I replaced the patch, using glue on both the tube and the patch this time, and taking extra care to be sure the glue dried. I think it was a success.
#512
Liked 2,479 Times
#513
multimodal commuter
Liked 574 Times
Rear tire went flat a mile from the station this morning. Patched it by a street light. I didn't find the cause, and I suppose it looked like it might have been a pinch flat, but I'm pretty sure I was riding with enough pressure.
Whatever. I missed the 5:13 express, caught the 5:30 local instead.
#514
Liked 645 Times
Which prompts me to think: Good grief, you must get up at 3AM. And your morning commute must be in the dark; is your evening commute in the dark too? So what kind of lights are you running? (Yeah, I know, you may have posted that in the recent lighting thread but I don't recall specifics.)
jimmuller
jimmuller
#515
multimodal commuter
Liked 574 Times
Maybe. Could have been a sliver of glass or wire which went through the tire but didn't stay. Or maybe all the air spontaneously bored through the potential well of the tube in a quantum-mechanical manner and escaped. Or maybe you should slow down. Heisenberg tells us that if you are going too fast you never really know where the air is.
The headlight is a B&M Lumotec IQ Cyo Premium (it's not pronounceable, don't even try), powered off a dynamo. It's an excellent light.
Would you believe: the same thing happened today, as yesterday! well, not quite the same thing: but the rear tire started getting low about halfway to the station. I pumped up three or four times, and the last time something went wrong with the valve (I assume the core had got unscrewed... but I couldn't check it out in the dark) and I ended up walking the last hundred yards or so. When I got to the station I realized I hadn't yet missed my train, which was a few minutes late, so I started to fix the flat. The bike is now in my bike locker with the wheel off, the tire halfway off the rim, waiting for this afternoon when I'll replace the tube.
As to the cause of these two flats, I must have got the tube pinched between the tire and the rim when I fixed it yesterday. It's a tight tire (Continental Grand Prix 4000 in 28 mm) . It's hard to get the tire onto the rim, and once it's on it is hard to tell whether the tube is pinched or not. The tire appeared to be perfectly seated, had no dips or bulges or other anomalies, so I thought it was good. But the fact is that it went flat again, so I'm thinking I didn't have it seated right after all.
Edit: I don't normally use talcum powder on my tubes. But I'm going to try it this afternoon when I put in the new tube. Anyone have a tip on the best way to apply the talc?
www.rhmsaddles.com.
www.rhmsaddles.com.
#516
Liked 3,585 Times
found the pic I was thinking of. Nitrile gloves - good for any hobbyist. just wish they came in a larger size & slightly thicker so they wouldn't be so prone to tearing. smaller hands would help but I can't change that
#517
Liked 3,585 Times
wonder if you can brush it on by putting a bunch in an empty jar & using a small paint brush or something?
#518
multimodal commuter
Liked 574 Times
It happened again yesterday riding to the station: rear tire went flat. Pumped up and rode a bit, but it was going flat so fast I stopped at the next street light and changed the tube. The puncture was on the rim side of the tube. The rim tape (velox rim tape) was not perfectly centered, and though I couldn't see any obvious spots where it was missing a spoke hole, I took it off and put it back on, this time taking care to get it perfectly centered.
This may explain both of the flats I had last week. If it happens one more time, I'm replacing the rim strip.
www.rhmsaddles.com.
www.rhmsaddles.com.
#519
Bikes: Too many, but sometimes not enough.
Quoted: 225 Post(s)
Liked 18 Times
There is quite a bit of variation in nitrile glove quality. I go through about a box every few weeks at work. I've had very good luck with Costco's nitrile gloves. They come in two box packs, in sizes from small to xl. My hands are kind of small, so the mediums fit great.
#520
multimodal commuter
Liked 574 Times
Happy New Year, guys! Let us hope we all keep this thread alive, as a way of appeasing the flat tire gremlins, so they don't bother us unnecessarily!
That said, I had my first flat of the year yesterday. Or maybe it was my last flat of 2017; hard to tell. When I got to my bike locker at the station, having left the bike there two weeks earlier, the rear tire was flat. Totally flat. I pumped it up and rode away, even in the cold, but had to stop a couple times to pump it some more.
It turned out to be a defective innertube; the tube had a thin spot at one of the molding ridges. I patched it.
www.rhmsaddles.com.
www.rhmsaddles.com.
#521
vintage Bianchiist
Bikes: Bianchis, 84 Superleggera, 86 Giro, 87 SportSx, 87 Campd'Italia, 87 Limited, 88 Proto, 95 TSXChorus, 94 TSX105/DAax, 94 Super Grizzley RC, 94 Genius Record, 06 Pinella Boron, 18 Volpe Avanti, 00 Megapro ST Veloce00 EM Strada OS
Quoted: 35 Post(s)
Liked 13 Times
I had a dream last night that I got a flat tire, then I woke up and realized my streak still stands! (knock on wood) I've been strictly biking (no car at all) for 2 years at an average of 400 miles a month, with zero flats. I just had to share because I think it is kind of amazing. Though it is not down to pure luck, that is shared over 3 different bikes and 4 different tires: 35% Conti gatorskins (28mm), 25% Rubino pro G+ (25mm), 35% Corsa G+ (23mm), 5% Rubino pro speed (25mm), all tires were new, (except the gators which where quite used already). I also always pay close attention to what I'm riding over, the roads to my house are in bad repair with mixed surfaces and riddled with potholes, with new ones appearing regularly. I've probably gone and jinxed myself now though...
Anybody else have a long streak without a flat?
.....Happy riding!
.....Happy riding!
#522
Liked 2,827 Times
.....Happy riding!
.....Happy riding!
#523
Liked 645 Times
We have had only three, all on the rear, on our tandem, having ridden it about 10,000 miles. The first didn't happen until well over 5000, and it was a slow leak. I rode my Gatorskin-shod Bianchi commuting about 25mile round trip three days a week for 9 months with no flat except a pinch flat from hitting a bump and then realizing I hadn't been checking the tire pressure.
jimmuller
jimmuller
#524
Liked 2,479 Times
I was going to say I can't remember the last flat I had, but it's more likely that I don't remember my flats any more soon after I have them. I think I had one in the summer.
#525
multimodal commuter
Liked 574 Times
I never forget ANYTHING. I mean it man, I literally cannot remember the last thing I forgot.
