fearing the slow good bye to rim brake bikes
#204
Quoted: 3957 Post(s)
Liked 7,310 Times
#205
Liked 7,310 Times
#206
Quoted: 3515 Post(s)
Liked 2,929 Times
Likes For smd4:
#207
Liked 7,310 Times
Originally Posted by mtbikerjohn
Fortunately,the engine didn't explode or it would have leveled pretty much half of Durango.
#208
Quoted: 1084 Post(s)
Liked 687 Times
I'm not sure that's actually true. A lot of people talk about disk brakes as though they're a completely different type of brakes, and are somehow "better". In their mind they are comparing disk brakes to drum brakes (like on a car). In fact, rim brakes are disk brakes that simply use the rim as the rotor.
Likes For Jeff Neese:
#209
Liked 2,929 Times
I misunderstood what you wrote, which seemed to suggest a boiler explosion would be bigger than the Hiroshima blast. You are correct. A boiler explosion would not be nearly as large.
#210
Quoted: 4420 Post(s)
Liked 4,873 Times
#211
Liked 7,310 Times
#212
Liked 4,873 Times
You learn something new every day. Today I learnt that a boiler explosion would not be nearly as large as a nuclear bomb blast. Amazing!
#213
Liked 2,929 Times
From now on I’m calling my rim a “rotor!”
#214
Liked 2,929 Times
In fact, it’s been said that the energy stored as steam is second only to nuclear energy.
#215
Liked 4,873 Times
#216
Liked 7,310 Times
Likes For tomato coupe:
#217
Liked 4,873 Times
#218
Sr Member on Sr bikes
This isn’t meant to be derogatory, but when you (and/or other disc brake users) state that “disc brakes are superior”…how exactly do you mean they’re superior? What makes them better? My rim brakes are perfectly capable of stopping my bike. I can lock up my wheels, at which point my bike’s ability to come to a complete stop resides in the amount of tire that is in contact with the ground. That ground contact would be the same with disc brakes. A locked up wheel with disc brakes isn’t going to come to a stop any quicker than one with rim brakes. I mean I’ve thought about it a lot, and the only conditions I can think of where disc brakes would be better are: regular long mountainous descents where that brakes have to be applied for long periods; extreme wet conditions; any sort of off-road cycling (mountain bike, cyclocross) where conditions are wet and muddy, or snow and ice.
Dan
Dan
#219
Liked 4,873 Times
Dan
Dan
Likes For PeteHski:
#220
Liked 2,929 Times
#221
Quoted: 1401 Post(s)
Liked 1,886 Times
I like rim brakes - more than capable / sufficient for many if not majority of bikes / applications
rim brakes are simple - less hassle - and can weigh less
however - a top quality disc brake system is superior to a rim brake system
#222
Liked 687 Times
I don't know why this pointless statement gets repeated so often. People understand that "rim brakes" refer to one type of brake, and "disc brakes" referent to another type of brake. No one ever points to rim brakes and says "those are disc brakes." What purpose does it serve to call them both disc brakes, when everyone uses and understands the present terminology?
#223
Mad bike riding scientist
Quoted: 6222 Post(s)
Liked 4,222 Times
People throw the term “modulation” around with regard to bicycle all the time and don’t define it. From the dictionary definition
Another definition
How, exactly, does a hub mounted disc brake give better “modulation” than a rim brake (i.e. a spoke mounted disc brake)? In my experience, I can pull on either a little or a lot and get the bike to slow a little or lock the rear wheel or, in extreme situations, spin me around the center of gravity. The only brake that I’ve ever used that didn’t have “modulation” was a hydraulic hub mounted disc. That one was full on or full off with no intermediate control…i.e. the opposite of well modulated.
I’ve seen people on line who claim that linear brakes are either on or off. I’ve never experienced anything like that in 30 year of using linear brakes.
a regulating according to measure or proportion
the exertion of a modifying or controlling influence on something.
Stuart Black
Stuart Black
#224
Liked 4,222 Times
Dan
Dan
As for hub mounted discs being superior in rain, the limitation isn’t the braking system. It is the contact patch. The lack of road adhesion is the limiting factor, not the kind of brake.
As long as the bike isn’t using coaster brakes or drum brakes, the kind of brake is seldom a problem in stopping the bike.
Stuart Black
Stuart Black
#225
Quoted: 1248 Post(s)
Liked 1,323 Times
It’s always interesting watching the debates devolve as a new technology becomes accepted. For acceptance to succeed it is because the product or technology is superior overall than what is being replaced. The luddites crawl out of the woodwork hanging on by whatever tenuous threads of logic to defend the obviously dated and inferior equipment. Clipless pedals, Index shifting, Brifters, 700C Clinchers, Carbon, Low spoke count wheels, Tubeless, Electronic Shifting, GPS Bike computers, 2X drive systems and now disc brakes. Anyone who has spent any extended time on an quality disc brake bike especially in the mountains or in adverse conditions knows they function better and are nicer to use than rim brakes. This is the reason a vast majority of passionate cyclists prefer and enjoy disc brake bicycles. To each their own however defending a rim brake bike as just a larger disc but not taking into account the inherently flexible calipers and cable system is laughable. The advantages of hydraulic actuation and a rock solid caliper design is overwhelming.
