Lace a Brooks On-The-Cheap?
Freewheel Medic
Quoted: 1463 Post(s)
Liked 2,220 Times
Bob
Bob
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1301 Post(s)
Liked 942 Times
Nor did they punch-out the hole rows after they had put the cover on the saddle frame. Pulling and twisting to gain access to the under-neath is not optimal, especially for dried leather from (Sturmey era) 1980's.
"In every job that must be done, there is an element of fun. You find the fun, and - SNAP - the job's a game!"
Quoted: 1867 Post(s)
Liked 666 Times
On that bridge-plate saddle, did you add a layer of leather to the top? I'm guessing so, and that would explain your line of bolts along the bottom edge between the cantle and the plate, and use of longer bolts rather than rivets to securethe top to the cantle. Given all that theorizing, how does it feel? And what modern model of Brooks would have the same cantle width as yours?
Quoted: 787 Post(s)
Liked 524 Times
I have laced old Brooks saddles to prevent the skirts from flaring out. Two holes per side is plenty for that, not too close to the sides. I've also had luck soaking the whole thing in room-temperature water for a few hours, then reshaping the saddle, with straps and stuffing it with newspaper as it dries. That can work surprisingly well.
Likes For jeirvine:
Regarding those saddles above, I really like the idea of using coins instead of washers but the workmanship is not good and the protruding Allen heads are just not okay by me (potentially hurtful/injurious to the rider). Even a shallow pan head or a true rivet would be better (smooth surface).
I work in an arena where critique is a necessary and welcome thing. We do not fool around and we don't take it personally. Critique is a learning opportunity. It is neither uncivil, unkind nor insulting. It may not be diplomatic but diplomacy is way down on the list of priorities if it gets in the way of clear, concise critique.
Different people have different contexts.
Bikes: old ones
Quoted: 26464 Post(s)
Liked 10,423 Times
Likes For 3alarmer:
Quoted: 331 Post(s)
Liked 332 Times
Brooks intransigence
Brooks refuse to sell leather skins. They sell everything else as spares except the important bit.
The metal bridge is a feature on the Swallow model. In the photo I used a piece of aluminium and simple bolts ,nuts and washers. It works just fine.
Riveting the nose cone is difficult as two of the rivets are horizontal and a very solid one-of-a-kind jig is needed.
Soaking leather in water and stretching works well if you tighten a little at a time and water doesn't seem to weaken the leather.
Use the dubbing sparingly, a teaspoon every 12 months is plenty.
Likes For Johno59:
Phyllo-buster
Quoted: 2299 Post(s)
Liked 2,059 Times
I have an inexpensive leather punch and would use that. It is fast and cuts clean holes and is easy to use for the side of a saddle. Placement is not as precise as I might like, so I would work out how to do that.
If I were drilling holes in leather, I would use a "brad point bit" (I have a set for woodworking). These have a central point for locating the hole but cut very clean holes because they cut starting at the perimeter (not the center).
Likes For clubman:
