More gasoline on the fire - Electronic Shifting
#201
Quoted: 1530 Post(s)
Liked 718 Times
That feels great.
#202
Aside from the obvious puritanical beauty of an "analogue" classical bike... what bull... shifting with mechanical STI levers is substantially more strenuous on your fingers than Di2... and it's not mere milliseconds... especially with multiple consecutive shifts. When I built a Di2 flatbar for city use - I eventually had to ditch my old mechanical Trek Madone for a Di2 roadbike... it was simply too big a QOL improvement to pass up.
I totally agree! I have that on both my Di2 bikes... even my Dura-Ace spec S-Works. I'm not always sure where the front-derailleur currently is otherwise x) ...and the battery indicator entirely removes any charging concerns/issues.
#203
Quoted: 2333 Post(s)
Liked 2,097 Times
i‘ve only used the latest di2, but the battery lasts months. thousands of miles. it would have to be a seriously long tour without access to power!
when it “dies” it also dies for the FD first, into the small ring, so you still have access to a wide range and can climb, you just can’t go fast.
on the other hand, the failure mode of a broken cable is walking home / calling a lyft.
I'm an electronic shifting fanboy but a broken cable is trivial. Just carry a spare along with a spare cleat, mounting hardware, etc. I've never broken a cable, because I replaced them on a PM schedule. I have broken cleats and the mounting plate, but was able to repair on the road.
#204
Liked 2,097 Times
If you've ever used Shimano's downtube or bar-end levers, or Campy's Ultrashift, then you should be able to get your head around it. An indexed non-escapement shift mechanism incorporating a counterspring is a pretty damn satisfying way to shift. You can feel what the chain is doing through the cable on upshifts (pulling the cable), and downshifts on non-escapement shifters feel so much better; think anti-SRAM.
I can't get my head around it. But I can't feel anything anyway.
Bottom line for me, I just want gears to change fast, easy, reliability, for a long long time. SRAM AXS and eTap fit that bill for me. All the old crap is up in the attic where it will die.
Likes For GhostRider62:
#205
Bikes: SL8 Pro, TCR beater
Quoted: 1006 Post(s)
Liked 588 Times
The maintenance issue is probably the biggest attraction .... I understand (from people who would know and whose experience i respect) that electronic shifts better but I can make mech shifters work just fine, so ... the idea of never having to index a derailleur or wonder how my cables are holding up or spin a barrel adjuster when the bike starts missing shifts ... I have no problem keeping batteries charged in cameras, flash units, headlights, tail lights, my phone, my laptop .... why would a derailleur battery be so hard to keep charged?
In fact, mine can easily last 2 months, but I charge it monthly with my power meter regardless.
#206
Advocatus Diaboli
Quoted: 4759 Post(s)
Liked 1,538 Times
Trying to picture.. you can shift while hard braking (therefore not pedaling)?
#207
Liked 2,097 Times
I only do bike maintenance about once every 2 weeks and during that hour, I wax the chain, charge the eTap batteries, wash the bike, and inspect the bike. I have no idea how many shifts a SRAM battery will last. Probably 400-1000 miles depending on terrain and shifting behaviours. The longest for me was about 40 hours and I just swapped it.
For busy people or scatter brains, charging batteries is a challenge
#208
Quoted: 1284 Post(s)
Liked 1,405 Times
What?
Liked 2,097 Times
Unless they are snipped off inside the ratchet mechanism on the older Shimano units, in which case a case of beer is needed, yes, it really is that easy. Fetch the 5 mm, push the old cable out, thread the new one in, connect, adjust and tighten. A couple of minutes? Ten? Whether one just takes one long one or a long and a short is personal pref, I always just carried one long. I always have tiewraps and duck tape.
#211
Liked 1,405 Times
Liked 588 Times
Would love to see a video of that. It's impossible to shift for obvious reasons when the crank is not moving, so the rider would need to continue pedaling slowly while downshifting and hard braking
#213
Liked 2,097 Times
If you want to fix a flat in the rain and in the dark, the first time should be blindfolded in your shower, naked with cold water running. Ok, maybe start without the blindfold
#214
Liked 2,097 Times
#215
Method to My Madness
Quoted: 2007 Post(s)
Liked 1,514 Times
#216
Quoted: 2524 Post(s)
Liked 3,010 Times
#218
Liked 1,514 Times
#219
Quoted: 1463 Post(s)
Liked 1,488 Times
I do this too if it's an expected slow-down, like rolling up to a stoplight. I think most experienced riders do this instinctively to avoid being in too tall of a gear once they start pedaling again.
Doing this while braking hard seems ridiculous though.
#220
Quoted: 3980 Post(s)
Liked 7,429 Times
The first step to doing anything is to get naked. (Except, maybe welding.)
#221
Liked 2,097 Times
#222
Liked 2,097 Times
If you are talking about braking during a descent, the front brake is all the business. Letting up on the rear for a quick shift a couple of sprockets takes what 500msec? Very easy to do with AXS. I actually think most this thread is ridiculous.
#224
Quoted: 1593 Post(s)
Liked 1,026 Times
I've only encountered this once, but the chain went to the bottom cog and I could easily ride home. I ride vintage with downtube friction but I don't see why that would make a difference.
#225
Liked 1,488 Times
If you are talking about an emergency stop as when a vehicle is about to kill you? Yes, totally agree
The rest of the time? I usually downshift.
