How much should my hi-end bike weigh?
Quoted: 1529 Post(s)
Liked 718 Times
Seems a bit heavy for a bike with rim brakes and tubulars.
This bad boy is 6.24kg / 13.75lb... fifteen years old, too.
These 49mm Caden tubulars are 1080g the pair, AU$1800
Likes For Kimmo:
Likes For Dean V:
Quoted: 6976 Post(s)
Liked 10,975 Times
Liked 10,975 Times
There's the joke about the old woodsman who brags that he's owned the same axe for 20 years: "I've only replaced the head twice, and the handle three times!"
Likes For Koyote:
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4394 Post(s)
Liked 3,018 Times
Quoted: 850 Post(s)
Liked 344 Times
Just looking at your build, I would say that, unfortunately, you have a bunch of fairly expensive and fairly light components all leading upto a fairly light bike. There's no silver bullet here.
Darimo T1 Loop Seatpost Aero/Not round ? Darimo Carbon
Darimo will make you a 95g seatpost that will probably save around 100g. You can also get their sub 200g bar-stem that they just announced. That will probably shave off a solid 100-200g.
The wheels seem to weigh 1470g. Quite portly for a set of tubulars. The cadens are a good choice if you want something aero. Their 25mm wheelset weighs 940g so you'd lose a solid 500g. ax lightness sells a similar wheelset for double the price that saves you another 100g.
You can save another 150g on the crankset. Maybe 50-100g on the saddle if you get a berk or something. You can get a one piece cassette that will shave off 70g. Ti/bolt-on skewer, at least up front. Etc etc. WeightWeenies is a better place to inquire about this.
so I just mentioned several thousand dollars in "upgrades" that will save you *maybe* 1.2kg. Is it really worth it?
Personally, the first upgrade I would make is a BBinfinite or hambini bottom bracket. A stiffer bottom bracket is both cheaper and more noticeable than any of these upgrades. Then I'd look getting nicer tires. Weight isn't everything. The rolling resistance, comfort and stiffness of a bike matter just as much, if not more and can usually be improved with a lot less money.
Likes For smashndash:
Quoted: 4428 Post(s)
Liked 4,880 Times
pan y agua
Quoted: 1452 Post(s)
Liked 731 Times
Varsinental project
IMG_0599 by Richard Mozzarella, on Flickr
It actually weighs less now with the heavy Race 28's safely on a hook in the garage & HED Belgiums installed instead. (Sorry the pics are upside-down. They're right at the Flickr site. 🤷♂️ )
Touring Geometry frame modification
This bike now wears a tandem fork with a more appropriate 50mm of rake & cantilever brakes. Also it's running GP5000TL clinchers & a standard Ultegra drivetrain instead of the JTek Shiftmate8 powered road/mountain mishmash. 6500 miles so far since that thread wound down. No issues. I haven't weighed it since the reconfig.
Edit: 28.4 pounds as ridden with the Velocity A23's. About a pound less with the Powertap Amp G3 wheel set that just aesthetically ugly AF on this bike. Not bad for a 47 year-year old size 58, hunk of gas-pipe. Even if I do say so myself.
After that effort and expense, you still have 28 pound bike with a gas pipe frame that rides like a turd. Same time and effort on any generic Chinese frame would be a dramatically better bike.
My first 10 speed was a Varsity and the bike had its place, but there’s no way that electoweld frame is worth putting coin and sweat into
You could get lost and die.
You could hit a tree and die.
I am potato.
Quoted: 1790 Post(s)
Liked 1,631 Times
for the love of god why?
The prompt for the 28 pound green one was because on another bike I commuted on, the fully weighted panniers made it ride like trash with the load necessarily behind the axle to avoid heel strike. The Schwinn was a low cost way to see how a long wheel based bike would ride with the panniers in front of the rear axle & still be far enough behind to avoid heel strike. The result was when fully loaded was the CG rested between the bottom bracket & the seat clamp. The 70 degree HTA, the effective 73 degree STA (from the zero setback post) & 66mm trail made for a brilliant stable gravel/touring bike that"ll support tubeless 42's. The 19-109 gear inch range never left me wanting for more gears. I did my first gravel century on that bike.
A Schwinn Varsity's geometry is not that different than that of dedicated gravel bikes now. It just goes to show that the more things change, the more they stay the same...What's old is new again.
The red bike that weighs 25 pounds is my wifes commuter bike. I did that one to prove it can be done. For the love of the project. Just to be different. To save an old thing. To indulge sunk-cost tendencies. Take your pick.
As an added bonus, her bike, being a Schwinn; It presents a low-theft risk in the bike rack at her work where it lives 13 hours a day, 4 days a week. People see the head badge & keep right on walkin'
As for my bike, I like showing up to group rides & dropping the hammer with out all the loaded expectations & bias that my Cervelo loads into people. That -ish got real old. The Schwinn is disarming & approachable.
Likes For base2:
Will have to consider these tips, although the question you ask "Is it worth it" is the most relevant here.
I'm leaning towards just keeping the bike as it is, maybe keeping it simple switching the tires and likewise considering a potential BB switch down the road (pun intended)
Liked 718 Times
There's the weight on the scale, and there's how light it feels.
A low number is nice, but what you really want is your bike to feel light. Tyres, rims, seat and post, levers and bars. Make those light and your bike will feel light.
Liked 4,880 Times
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
200g lighter than whatever yours currently weighs.
Likes For Kapusta:
Quoted: 3241 Post(s)
Liked 2,512 Times
First thing I noticed was the drop handlebar tree in the left of the pic. I didn't know such a tree existed.
Likes For seypat:
Liked 2,512 Times
Cheapest way to make your bike feel lighter is............do lots of pushups every day.
Bikes: Specialized Sequoia
Quoted: 446 Post(s)
Liked 63 Times
Personally, for as much as they cost, I think that modern high-end bikes should have a negative weight. Instead of a kickstand, they should come with a mooring line to keep them from flying off into the sky.
Seriously though, to the OP, nice job on the build.
Likes For bike eagle:
