Marathon Plus/GT/Mondial/Energizer... ??!#*&@#$*$&%@#$
I was running 700x38 on an old Cannondale hybrid and the gyroscopic forces that those tires generated was surprising. I never had a flat on them but I haven't had a flat on Panaracer Paselas either at half the price and weight so for me the Plus is just unnecessary weight and expense.
Looking through the Schwalbe catalogue (thanks @acidfast7), I assume that the tires with the greenguard layer are all the same technology (for the greengaurd). Obviously, the tread, possibly sidewall, and other features will vary.
I just noticed that my rear really needs replacing, and I'm probably going to go ahead and swap the front out as well. I love the contis I have on there now, but I've been getting a lot of flats around here (and I run tire liners), so I'm looking for a decent compromise between the near slicks I've got, and the pluses that just seem heavy.
I'm leaning towards the Conti Top Contacts, if only because I'm sure they come in the sizes I need (I ride recumbent with a 32-559 on the rear and a 32-406 on the front).
a 32 supreme will be 2mm bigger on rim. and a 25mm gp4k will be 27-28 usually on rim. this is pretty much the best **** both makers make allover.
Last edited by cb400bill; 05-01-19 at 03:07 PM. Reason: Stop changing the spelling of censored words.
Likes For carlos danger:
Quoted: 212 Post(s)
Liked 83 Times
"Best" tires in the general purpose category imo is the schwalbe marathon supreme. they last longer than gp4k's but both are very very puncture proof. Both use the best rubber possible and then some kind of vectran/kevlar weave. The contis are usually the best from 28mm and below and the supremes 32 and above.
This year my commuter/hybrid is sporting GP4 season tires, which haven't flatted yet this year, and on my road bike, a GP5000 in back and GP4000 in front until it wears out.
But these aren't ideal commute tires if flat protection trumps speed and feel. If my hybrid seemed more prone to flats along my commute I would move to Gatorskin Hard Shells.
The OP seems to want more of a mixed surface tire. If that were my need I would probably go with Top Contact II in a 38mm width. Heavier, slower, but durable and capable of dealing with a pretty wide variety of surfaces acceptably.
Likes For daoswald:
Yeah me too i would also go more HD for bad commuting.
that being said i have no trouble with my gp4ks nor the marathon supremes. and i ride some distances that are gravel with them. so for me they work.
If going lets say 35mm or up then the supremes are nice imo but one might need beefier stuff. i dont though. top contacts seem very similar to supremes in build.
last resort would be "plus" tires imo.
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,437 Times
Here's my similar post, if it helps. There are probably 2x as many 'marathon' tires as back then. I think they should not put Marathon in the name, but make it a technology designator, like tubeless ready, or snakeskin, etc.
So many Marathons!
Problem is, you want all the things. You probably want it to be cheap too, right? You can't have all the things.
Marathon Supreme is the most comfortable and lightweight and expensive. It is quite flat-resistant, but not 'as flat resistant as possible'. I think Marathon Plus is 'as flat resistant as possible', and also one of the least expensive, but also reputed to be the heaviest and least comfortable.
I invested in a pair of Marathon Supremes (700x50), and they lasted me well over 10,000 miles. I weigh about 235 nowadays.
I thought they looked frumpy though, so I got myself a pair of Mondials 700x42? x46? I was quite disappointed that the rear tire wore away all the 'scallops' in about a year. Doesn't seem very 'Marathon'.
So many Marathons!
hoping to find a tire that can support my weight, be comfortable for 45 min trips, and not be ridiculously heavy (the commute is hilly and has about 25% gravel). It also needs to be as flat resistant as possible
GATC
Where I can most chime in here is as follows: my winter bike is a cyclocross frame running Marathon Extremes, which I think have evolved into the Mondial. The Extremes are identical to the Marathon Winters but minus the studs. So when it is black ice season I swap in the MWs. I use 35mm for both, the largest 700c tires I have. The tread of the extremes does a good job w/ the deep leaf mulch I need to ride through so much of. Decent with slush and the Winters' studs really nail the bike to the ground when it gets that much more slippery.
I have tried 700c 40mm marathon supremes but didn't like them. I love supremes at 32, I have a steel fendered roadbike with those.
cvandam
Commuting
8
08-21-22 11:21 PM
nstgc
Commuting
10
07-07-15 02:27 PM
