Tire size for a more comfortable ride on HORRIBLE roads?
Quoted: 4806 Post(s)
Liked 3,933 Times
Yes. OP, put the largest tires on that will fit. If you want a good ride, spend the bucks. (I ride the Vittoria Corsa G+ and G 2.0 on my good bikes, Panasonic Paselas on my city bikes.)
Ben
Likes For saddlesniffer:
Should Be More Popular
Quoted: 22609 Post(s)
Liked 8,932 Times
Just because the tires SAY max PSI is 110 or 115 does not mean that is the IDEAL pressure. Most cyclists don't quite get that.
FWIW I ride on pretty crappy roads sometime, chipseal and even occasional gravel. I am running 23mm front and 25mm rear tires, typically 75F80R pressure and it works pretty well. Heavier riders do need a bit more pressure, of course.
Likes For datlas:
Bikes: Specialized Tarmac SL5 Comp Disc
Quoted: 21 Post(s)
Liked 36 Times
I am 183 lbs. I typically ride 700x28's on my Tarmac at 95 PSI front and rear. Would I be safe at my weight to lower my front to 85 PSI and keep the rear at 95 PSI?
Liked 8,932 Times
Yes. I would even consider dropping to 80F and 90R. Try it and see how you like it.
Bikes: SuperSix Evo | Revolt
Quoted: 733 Post(s)
Liked 815 Times
+1 for 32mm GP5000s & latex tubes, love 'em! I'm 185lbs and have been playing with the pressure, ran them this morning at 58f/70r with no issues, very comfortable and still fast. In a group ride I'll ride a lil more pressure just in case someone doesn't call out a hole.
On Your Left
Quoted: 3004 Post(s)
Liked 2,434 Times
I have 2 bikes, a high end road bike with 25mm and a CX bike with 32mm tubeless.
The CX is my winter bike and it rides over Long Island winter roads like a Escalade... silky smooth while the road bike can be very jarring on the same roads.
So if you want a better ride, 32mm tubeless gets my vote.
David
