Tubeless road bike users: Tell us your experience.
Family, Health, Cycling
I have been on road tubeless for over 5,000 miles.
I started using them the last weekend of April, 2016.
They have been a game changer.
Fast, comfortable and amazing grip when I'm whipping it down Mt. Diablo.
I'm not going back to tubes.
I've only been an onlooker at tubeless in-ride disasters. No way for this kid. This thread demonstrates the obvious lack of industry standards in the tubeless market. For this reason, tubeless will be a passing fad. Road manufacturers will phase it out. Ride latex tubes and enjoy.
NYC
Quoted: 1169 Post(s)
Liked 107 Times
I think it is more likely that it will continue to improve and eventually everyone will be using the VHS version (instead of BetaMax) without even realizing there was/is a different standard out there.
The passing fad that I think will pass with time is the murdered out black on black on black bike. As the milk bar white bikes of 2008/9 have passed from this earth, so too will the murdered out specials. However, to be fair, Assos and Rapha with their all black kit, will cause them to remain as a "elegant european" well after the fad appeal has moved on.
It't got a way to go. I've switched over to tubeless tubulars - tubulars that have no inner tube. My flats from riding clinchers are down to being so low I can't remember the last time I had one (been three years without a puncture). That gives me the low weight of tubulars and the benefit of not having inner tubes.
J.
J.
Quoted: 18883 Post(s)
Liked 10,646 Times
I know I'll start another debate by saying this again but if you look at all of the threads started by someone having problems setting up their tubeless tires, what was the issue? 9 times out of 10 its something to do with the tape! It can be too much tape, not enough tape, wrong width tape, tape not sticking, or even an imperfection on the surface of the rim where the tape adheres? Easy fix, buy a wheel that does not need it like a Shimano or an Easton Certified Road Tubeless wheelset and you can almost guarantee a trouble free experience. Let me also point out that we're talking road tubeless here where the pressures are typically 80-100psi, not mtb's where you run much less air pressure which decreases the chance of issues.
My belief on why there's a reluctance to have a standard is it would require every other manufacturer of wheels including the smaller well known wheel builders to completely change their rim designs and building techniques to sell a Certified Road Tubeless wheelset which requires the use of double threaded spoke nipples that are installed from the outside of the rim in order to have a smooth sealed rim bed and no need for the problematic tape. I should also point out that this is especially important for carbon wheels because of their hollow rim cavities where escaping air and sealant can travel when the tape fails. An aluminum rim has a much better chance to work with tape because of its smooth surface but I still consider any tubeless wheelset that requires the use of tape to be a CONVERSION and will likely fail one day if not the first.
Bikes: i may have bike(s)
Quoted: 46 Post(s)
I think with some recent tests showing Crr being quite low for some options, tubeless will gain more traction with TTers.
I have been on tubeless for a few tens of thousands of miles and will not being going back to tubes. With modern sealant working so well, tubeless was a stepping stone for me to tubular but if I could afford the new Spec. wheels, I'd probably go back to tubeless.
Thread Killer
Quoted: 3147 Post(s)
Liked 1,712 Times
Thread Killer
Liked 1,712 Times
I'd have to disagree with your thinking that road tubeless is a "passing fad". Yes, the industry needs a standard mostly for safety reasons but also to help eliminate 90% of the frustration that stems from installation errors. Nothing wrong with riding on tubes if that's what you want to do but know that there's a puncture friendly almost tubular ride feel setup out there waiting for you if done right the first time.
Also, while taping troubles account for a lot of the problems, almost all of the issues people have are user errors, either trying to jimmy rig a solution or using the wrong stuff (like wrong tape, wrong rims, wrong tires, wrong pump, etc.)
Liked 10,646 Times
NYC
Liked 107 Times
My belief on why there's a reluctance to have a standard is it would require every other manufacturer of wheels including the smaller well known wheel builders to completely change their rim designs and building techniques to sell a Certified Road Tubeless wheelset which ....
I think the Stans style wheels and tires have pretty much become the defacto standard... but we could use some industry wide agreement on the exact rim bed diameter and clincher design.
MTB tubeless is going to a hookless design. Maybe road will be next. But that's yet another standards shift that everyone has to get past.
just another gosling
Quoted: 3889 Post(s)
Liked 1,938 Times
OTOH we had a rare flat on our tandem today. I put on a spare tire and tube (different tire and tube brand from what was on there) and we were gone in about 5 minutes. Gave us a nice rest is what it did. Tubed clincher standards are quite forgiving. Some tires are easier to mount on some rims, but they all work.
Results matter
Results matter
I agree completely, ordering tires or should I say tyres from the UK is the cheapest option. I got a set of Pro One's from Merlin delivered for less than $80.00 for the pair. I was just pointing out that local pricing has dropped quite a bit and if you happen to need one now it wont hurt the wallet as badly.
Bikes: Mikkelsen custom steel, Santa Cruz Chameleon SS, old trek trainer bike
Quoted: 70 Post(s)
Liked 6 Times
Love it. Been 100% tubeless since... 2009 I think, never going back.
Liked 10,646 Times
I use tubeless tubulars (Clements/Tufo) but this would apply to both. I saw this thing in Velonews and ordered one. This ought to make flat repair pretty easy and painless.
Reviewed: Dynaplug Micro Pro tubeless tire repair kit | VeloNews.com
The idea is that you force one of these sticky plugs through the hole without even removing the tire. Very similar idea to how car tires are repaired. Supposed to be fast and easy according to the review. Either way, I would think this would be an advantage for any tubeless setup.
Liked 10,646 Times
Bikes: BH, Cervelo, Cube, Canyon
Quoted: 212 Post(s)
Liked 6 Times
I got a puncture about 200 miles in. Sealant was sprayed all over my bicycle and person. The wheel flatted. I took the tire off and got goo all over my hands and shorts and there was nothing to wipe them on. I threw a tube in and rode home. Then I took the front off, cleaned out the sealant, and put in a tube. Then I cleaned my bike, then I took a shower.
Thus ends my tubeless road experience.
I've also carried a paper towel or two in my flat/tool kit for a while now, ever since a chain failure that covered me in grease during the repair.
Dan
Quoted: 686 Post(s)
Liked 5 Times
I was very cautious at first with my Pro1s and non tubeless ENVE 3.4s, worried that I might roll a tire on a high speed turn or something, but after 1000 miles or so I stopped even thinking about it. To be quite honest, I'm blown away by how well the tires work on the rims. Once I worked out a couple of kinks, they're probably one of the tubeless combo's I've come across. The tires stick to the rim better than some of my tubeless specific wheelsets (both road and mtb).
Liked 1,938 Times
Curious what you mean by "tubeless in-ride disasters" - like just a flat and not the proper items to fix it, issues with initial setup, or disaster as in damage happening to the rider?
Regular clincher flats, 2 or 3 of the stronger riders usually stop, we split up the tasks, someone produces a spare tire so we don't have to look for the object, and we're back on the road quickly. If there's enough ride left, we might be able to rejoin the group. But they're rare, so no big deal.
Results matter
Results matter
Non omnino gravis
Beyond that, aside from a few months of horror with Schwalbe Ones, I have not recorded a puncture on my Maxxis tubeless-- not one-- and I've pulled copper staples, bottle glass, and spring steel out of my tires. Ten thousand miles. Never even had to add air.
Quoted: 167 Post(s)
Liked 11 Times
If any color other than white is inside that tire, the person is either not running tubeless, or is an idiot. Latex sealant is white. Even Orange Seal is white. If you put Slime in a tubeless tire, you deserve what you get.
Also, just because a rider is tubeless it doesn't mean that its fair game to ride through any hazards on the road.
Two years here with tubeless on road and gravel (14,000 miles). The only flats I've had is from running a sharp rock though the sidewall.
FYI - American Classic Hurricanes for gravel and American Classic Argents for road. both have two seasons with no truing needed.
Bikes: '98 Rhygin SS road,'99 Fat Chance Ti Fat, '95 Azonic Mtn bike, '88 Giant Sedona.
I went Tubeless 5 years ago, when I got some Ksyrium SL's, and realized they were Tubeless friendly. Have had to use a tube once. Now running Schwalbe Ones 75/80 lbs. Love the comfort and grip.
