Airless Tires ?
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,571 Times
I'm still highly skeptical of airless tires, but I could see run-flat tubeless tires making inroads at some point. They're offer (most of) the benefits of pneumatic tires, but a puncture would not be a show-stopper.
RUSA #7498
Originally Posted by noglider
Quoted: 18405 Post(s)
Liked 4,528 Times
I could imagine making a foam filled tubular (sewup) tire that would give it a little residual support in the case of a flat. But then one might ask what the benefit of filling it with air would be. Why not just give it enough strength to support the rider?
That brings up the Peram Never Flat Tube.
https://www.amazon.com/Peram-Never-F.../dp/B01CN73FUO
Use your normal outer shell, but put the Peram tube in, thus keep some of the characteristics of the tire. I am a bit skeptical about it though. Never tried it. It sounds like it would be a pain to get mounted right with the equivalent of full pressure.
Sr Member on Sr bikes
Now...regarding the weight. I can't recall all the exact numbers, but at the time I did the math. I compared the weight of the airless tires vs. the collective weight of pneumatic tires, tubes, 1 spare tube, rim strips, tire tools, seat bag, patch kit, and pump...all those things I wouldn't need with me while using airless tires. On that equation the advantage went to the airless tires. They weighed less than all the stuff related to the pneumatic tires.
But, as I mentioned above...I just didn't like the feel of them and reverted back to regular pneumatic tires.
Dan
Bikes: Trek Domane 5.2, Ridley Xfire, Giant Propel, KHS AeroComp
Quoted: 1648 Post(s)
I think there is a very good reason the solid tire concept has not ever got hold, it has been around for ever, went away for half a decade, has attempted a comeback for half a decade and other than dollies and carts, keeps failing.
Quoted: 1074 Post(s)
Liked 295 Times
I've seen a youtube video of some guys mounting a tire insert on a wheelchair wheel. It required generous applications of WD-40 as lube and several guys using motorcycle tire levers.
it's the drawback of the inserts. If you have an insert that will fill the tire well you have to pull real hard on the bead to get it into the lowest part of the rim and free up enough bead to get it over the edge.
