Need Help: Looking for Garmin Gravel Worlds Vintage bike/frame
Quoted: 5902 Post(s)
Liked 3,521 Times
Likes For bikemig:
Likes For Sedgemop:
Bikes: old ones
Quoted: 26479 Post(s)
Liked 10,444 Times
Here is a start. Some one knows if there is room for 35s. I’ve never had one.
https://chicago.craigslist.org/chc/b...684303729.html
Those were relatively high quality frames, made in Asia by Panasonic (I think), the three mains are butted, and the rest of the tubing is unnamed. I enjoyed riding this one around for years, until I sold it on to someone.
Likes For 3alarmer:
Bikes: '72 Peugeot PX-10 '78 Motobecane Le Champion '83 Motobecane Grand Jubile '85 Trek 830 '88 Merckx Team ADR Corsa Extra
Quoted: 472 Post(s)
Liked 1,217 Times
I'd inquire about tire clearance on this one too.
FS: 1979 Mercian Campionissimo (24 inch, fully restored)
Likes For Sedgemop:
Bikes: 2017 Sage Skyline, 2015 Co-Motion Periscope Tandem, 2012 Soma Smoothie, 2006 Kona Jake, 1978 Richard Sachs, 1977 Peugeot UO18c, 1977 Peugeot PRN10, 1974 Allegro Schweitzermeister Model 76, 1972 Hugo Rickert Spezial, 1971 Fuji Finest
Quoted: 120 Post(s)
Liked 637 Times
Patience and sanding
If that is the case, adapting a more typical 22 stem just involves gripping the insert portion of the stem in sandpaper and twirling until you sand it down to the proper diameter. This has been done for years to deal with the French stem conundrum.
Liked 3,521 Times
I'd be concerned about taking that much material from a stem (22.2 to 21.15); with a French stem you are simply taking it down from 22.2 to 22.0.
Likes For bikemig:
Quoted: 3464 Post(s)
Liked 2,837 Times
Liked 2,837 Times
Likes For repechage:
Bikes: old ones
Liked 10,444 Times
...on the Voyageur frames, they definitely do not have a short top tube. That's why you see most of them with relatively short stems, which is how they were sold.
Regardless. I have a long torso, relative to my overall height and inseam length. The cycle shown in my photo fit me very well, even with that shorter stem.
But if you're dead set on a frame with a shorter top tube, that's not the frame you want to buy. But it does meet all your other requirements, at a bargain price. As you can see, for a while I had it set up with 27" wheels and 32mm Schwalbe tires. I can't recall exactly, but I think it might be fully chromed under that black paint.
Likes For 3alarmer:
Quoted: 3035 Post(s)
Liked 3,923 Times
Liked 2,837 Times
the radius of a 700c is 4mm smaller, looking at the brakes the pads are not crammed up, so that clearance should be
OK, the chainstays will be the limiting factor, I do not know if they are indented or round oval round. Sliding the axle back will assist also.
Inquire as to the chainstay metalwork about the current tire.
framebuilder
if I was looking for a gravel bike for myself, I would focus on 60's/early 70's frames when center pull brakes were popular (in other words before Campy regular reach 47/57mm brakes came on the market around 1970). Centerpull brakes had a longer distance between the attaching bolt and the brake shoes. This makes more room for fatter tires. Sometime in the late 70's, Campy started making shorter reach brakes and so did the Japanese. These were often 39 to 49mm (Campy short reach being a bit more). Frames designed for these brakes are what I would avoid. This group is going to be the big majority of what's available. Now it has become popular to use fatter tries necessitating longer reach brakes again. One thing to realize is that builders design a frame for the brake shoe to be either at the top, middle or bottom of the brake slot. That of course affects the available space to fit a tire. My solution would be to take a small 6" ruler with me to measure what space is available.
Likes For Doug Fattic:
Quoted: 802 Post(s)
Liked 760 Times
High trail is preferred for gravel, right? I imagine just about any 80s touring bike would work great. Japanese touring bikes often were shorter along the top.
Likes For Piff:
Liked 2,837 Times
Quoted: 120 Post(s)
Liked 637 Times
My starting point was from a French stem
Should have been more explicit that my suggestion was to start with a French stem which is significantly more available than the proprietary 21.15 stem used by Schwinn.
Liked 3,521 Times
Removing that much material from a quill stem, besides being a PITA, would scare the heck out of me. YMMV, though.
Liked 3,521 Times
You might be better off looking for a bike with a 58 cm top tube (which will quite possibly also have a 58/60 cm seat tube). You can get the height you need with the seatpost (there are plenty of tall seatposts out there) and you can get the handlebars up with a nitto technomic or a quill threadless adapter.
Too expensive at $365 (but prices will trend down during the winter) but this 60cm '73 Raleigh Super Course is in nice shape and has lots of clearance for fat tires,
https://www.facebook.com/marketplace...9-8acfdcef4eca
I linked to this earlier but my vote would go to this 70s era Fuji S12s:
https://www.facebook.com/marketplace...e-e42d9526a0e4
Vintage Fujis are very well made bikes and this will make an excellent platform for a gravel mutt. One potential downside to the Fuji, though, is that you may have to do a 650b conversion to get the tire size you want.
Here is a piece from Sheldon Brown talking about why top tube length matters more than seat tube length. I think he's right:
https://www.sheldonbrown.com/frame-sizing.html
Quoted: 1968 Post(s)
Liked 2,064 Times
If the intended use is to race on gravel, shorter chain stays are preferred. What is our budget?
Liked 3,923 Times
Just wondering, why does that matter one iota at all? Greater races with greater racers have been done with long chain stays. They had long chain stays when roads were were pretty much mostly gravel, why were they wrong then?
Likes For iab:
Bikes: I don't even
Quoted: 83 Post(s)
Liked 218 Times
If you're allowed to run non-original wheel size, I personally would be looking to do a 27 to 700c or 26 to 700c conversion. This is my 84 850 converted from 26" to 700c that I use as a gravel bike:
It's setup with barcons mounted on Paul thumbies seem to be legal as well?
1983 Trek 520 converted from 27" also clears the same 700x38c GravelKing Slick without any trouble.
Likes For theblackbullet:
